DVI>HDMI PC>HDTV No Signal - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-18-2012, 08:57 AM - Thread Starter
hollatbk's Avatar
I'm not sure if this is the right forum for this question because there's a good possibility that it is a computer related issue. However, I just purchased a new 55lw5700 and I'm trying to connect my computer to the TV via DVI>HDMI. For whatever reason the TV is not getting a signal from the computer and just displays "No Signal" on the screen. I thought there may be an issue with the HDPC compatibility but before I purchased the LG I had the same computer hooked up to a 32 Phillips LCD with no problems. I've tried updating drivers and and changing the computer back to its native resolution. Any help would be appreciated.
hollatbk is offline
post #2 of 7 Old 02-18-2012, 11:02 AM - Thread Starter
hollatbk's Avatar
I hooked my DVI>HDMI cable into my Sony BDV e580 home theater system and boom it shows up. So there must be some sort of issue with my TV.
hollatbk is offline
post #3 of 7 Old 02-18-2012, 12:17 PM
walford's Avatar
What resolution are you sending over HDMI to your new TV? Is it a resolution that the new TV's user manual says it will accept over HDMI?
Were you using HDMI also with your previous TV?
Have you tried different HDMI input ports on the TV?
walford is offline
post #4 of 7 Old 02-18-2012, 12:43 PM - Thread Starter
hollatbk's Avatar
it works on the Phillips LCD and it also works when connected to the Home Theater system that is hooked to the new TV. Both via dvi>hdmi cable. The resolution is being set automatically when windows detects the device. The TV is not getting a signal from the PC because when i switch it to the hdmi input it just says "No Signal". im wondering if its a windows 7 problem.
hollatbk is offline
post #5 of 7 Old 02-18-2012, 03:32 PM
sitlet's Avatar
You didn't answer these questions. Just because windows sets the resolution automatically, doesn't mean it's a resolution the tv can accept.
sitlet is offline
post #6 of 7 Old 02-18-2012, 07:50 PM
sjetski71's Avatar
What refresh rate are you sending over hdmi to your new TV?
Have you tried different HDMI input ports on the TV? <<<--------- Most TV's have one specially programmed hdmi port to be used with PC's.
sjetski71 is offline
post #7 of 7 Old 02-19-2012, 08:11 AM
walford's Avatar
The "No Signal" alert is also often used to when the TV can not process the resolution that is being received.
walford is offline
Reply LCD Flat Panel Displays
