Suggestions for Best 37-40' Gaming LED LCD TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-18-2012, 02:47 PM - Thread Starter
fociz's Avatar
Hi folks.
It's time to upgrade my PC/Xbox gaming panel to something that displays text well and has as little latency as possible. My budget is in the $500 or less range.
Is that realistic?
I'd like to stay between 37 to 40 inches. I'd also prefer low glare and I don't need 120hz, unless someone here can enlighten me how it would benefit gaming.
It's been years since I've looked at tv's, is plasma a good choice at all?
Thank you for any advice.
fociz is offline
post #2 of 7 Old 02-18-2012, 04:15 PM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 565
Originally Posted by fociz View Post
Hi folks.
Is that realistic?
Look for an IPS panel set, which means LG or Panasonic. That budget is more suitable for a CCFL-LCD, which is my opinion is preferable to a edge-lit LED-LCD anyway.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #3 of 7 Old 02-19-2012, 12:06 AM - Thread Starter
fociz's Avatar
Thank you.
Any current models you can suggest?
Also what is 4:4 and does it help with displaying text correctly?
fociz is offline
post #4 of 7 Old 02-19-2012, 12:38 AM
Injected Sin's Avatar
Westinghouse @ Bestbuy $329 40"
http://www.bestbuy.com/site/Westingh...&skuId=3054153
XBL GTÂ vFLOODv
Injected Sin is offline
post #5 of 7 Old 02-19-2012, 11:15 AM
Liked: 565
Thank you.
A good CCFL-LCD is the LG 37LK450 or 42LK450 with the S-IPS panel.
post #6 of 7 Old 02-19-2012, 03:44 PM
John4721's Avatar
Seconded.
Regarding the the 4:4:4 support, the short answer is, you do want it if you're running the display as a PC monitor. It improves text clarity. The longer answer I've quoted below.
Originally Posted by thepoohcontinuum View Post
The general consensus is that without 4:4:4 capability, only red/orange/yellow colored text will be blurry. However, in my personal experience, *everything* looks blurry and slightly off without 4:4:4. Picture quality is obviously subjective, but based on my A/B test (A = LG LD450 with 4:4:4, B = LG LD450 without 4:4:4), there is a clear night-and-day difference between the two.
Source
Another good source of info.
I'm using an older LG 32LD450 myself as a PC monitor and enjoy it quite a bit.
John4721 is offline
post #7 of 7 Old 02-20-2012, 04:50 PM - Thread Starter
fociz's Avatar
Awesome.
Thank you for the replies.
We actually have an LG 42LD450 in the family room I may have to replace with my 40' Sony.
The wife wont notice will she? Naw!
Although my thinking is if i can find a decent 37' the dot pitch will be a bit more dense. I wish we could have more info on the pixel density of current panels today.
fociz is offline
Reply LCD Flat Panel Displays
