Panny ST30 Plasma user going to an LED TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-20-2012, 01:20 AM - Thread Starter
You a busta CJ's Avatar
I currently have a 42" ST30 Plasma and having too many issues with it and since this is my third one with problems I will just return it and get an LCD/LED TV.
The only thing is that the picture quality on the ST30 was pretty damn amazing and the way it handled motion was great for the most part.
So basically I want either a 42" or possibly a 46" LCD/LED that can match the PQ of the ST30 (or be even better) and same with the motion handling.
I watch sports like boxing, mlb, nba and I've been disappointed on how some of the LCD TV's handled the motion in sports back in the day but maybe now they have matched plasma?
Are there any suggestions? I do not want to settle for any cheap models but I have a budget around $1200 or so
You a busta CJ is offline
post #2 of 5 Old 02-20-2012, 09:27 AM
Guibs's Avatar
May I ask what is the issues you were having with the ST30?
Guibs is offline
post #3 of 5 Old 02-20-2012, 01:47 PM - Thread Starter
I have a July build so I have FBr, image retention and green blob on the left side.
My other ones had the same issues and the other had a dead pixel.
post #4 of 5 Old 02-20-2012, 02:22 PM
HTguru3's Avatar
You mentioned in your other post that you're past your 30 day return policy so what are you going to do with your Panasonic then? I doubt Panasonic will give you your money back.
HTguru3 is offline
post #5 of 5 Old 02-20-2012, 08:48 PM - Thread Starter
I have a burn in warranty thing from best buy and my TV is already starting to show IR of KCAL 9 logo so hopefully I can get my money back from that.
If not then looks like Im sticking to st30
Reply LCD Flat Panel Displays
