Big green cloud Sharp 733u(after mounting) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-20-2012, 02:31 PM - Thread Starter
cuthroatclark's Avatar
So I tried to hang my Sharp 733u to my TV stand (its a mount and a stand). When I got it all together I noticed a big green looking cloud in the middle of the screen. I immediately took the TV off the mount and the spot was still there. I didn't over tighten the bracket or anything. I rubbed the spot very gently and it went away. Does anyone know what this could of been and should I try to hang it again? I dont want to risk damaging it.
cuthroatclark is offline
post #2 of 4 Old 02-20-2012, 02:48 PM
DaGamePimp's Avatar
Quoted: 411 Post(s)
Liked: 445
Make sure your mounting bolts are not too long and that the mount itself is not shifting in any way causing the display to flex (if it's a larger set then the mount needs to be very sturdy).
Was the spot on the screen directly in front of one of the mounting locations?
Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro / Xbox One S / WiiU / PS3 / 360 / Wii / 1080TI game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is online now
post #3 of 4 Old 02-20-2012, 05:51 PM - Thread Starter
Yeah it was def around the area of the mount I think this TV is just too big for my old mount. Do you think i should be worried about that green spot on the tv?
post #4 of 4 Old 02-22-2012, 07:43 AM
JB426's Avatar
My 70" 632U had some green clouding in the middle of the screen on dark or black scenes. What I did was turn the TV off, then wipe the entire screen inside to out with a microfiber cloth applying very light pressure, similar to what you did. The green clouding completely disappeared. I got the idea from someone here on the forum with a similar problem. Mine has been fine ever since. So if it went away I wouldn't worry about it.
JB426 is offline
Reply LCD Flat Panel Displays
