sharp LC70Le632U or LC70Le732U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-21-2012, 11:25 AM - Thread Starter
socal swagger's Avatar
Quoted: 54 Post(s)
Liked: 25
Cant decide between the both
same price so cost isnt a factor. I know the 732u is newer with the yellow coloring but i beleive i read mixed reviews and i cant find the posts
Looking for guideance...
socal swagger is offline
post #2 of 3 Old 02-21-2012, 12:29 PM
psw757's Avatar
I was just a best buy an hour ago. I went there planning to buy 60 inch 831 model. I then looked at the 70 inch 632 and 732 and bought the 732. The 632 had some motion issues going on. There was a football highllight and the ball literally disappeared from the blur, talk about weird. Immediate no-go for me. The 732 same scene, no blur.
Keep in mind bestbuy doesn't have true hd feed, they told me they are 720 and signal is split with most tvs having only component hookup. He showed me all the sharps as they were on stands, not one was hooked up with hdmi. Im sure this was part of the issue. Good luck, I hate buying tvs!
psw757 is offline
post #3 of 3 Old 02-21-2012, 02:01 PM
gordon7's Avatar
there should be no difference between 632 and 732 in terms of motion blur. Judging TV performance by the store display is a big NO NO since TV settings are unknown. If price is the same then go with 732 otherwise go with 632, save few $$$.
gordon7 is offline
Reply LCD Flat Panel Displays
Sharp Lc 70le732u Aquos 70 1080p Led Hdtv , Sharp Lc 70le632u Led Hdtv
