Official Samsung UNXXEH6000 Owners' Thread - Page 73 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #2161 of 2591 Old 03-09-2013, 01:23 PM
demo23019's Avatar
Only motion issues I have is when watching 1080 interlaced *cable tv* content. 1080p is fine
even with AMP set to clear 1080i movement isn't always great.
I just went and set my cable box to only use 720p and TBH picture look better handles fast motion better, no smudging less noise i was getting with 1080i.
Only problem its not native but cant really tell unless you look very close its not as sharp but raising sharpness helps little.
demo23019 is offline
post #2162 of 2591 Old 03-09-2013, 02:34 PM
lm 808's Avatar
Originally Posted by absoluteczech View Post
hey guys i just posted this in the calibration forum but i figued id ask here since you guys have the same tv
Hello everyone,
Hoping someone can quickly answer this. I'm fairly new to all this. I bought a disney wow blu ray before I found the avs hd 709 (could have saved myself $18) oh well. Anyways I'm trying to configure my new samsung un40eh6000. After reading online a lot of people say to enable super white on the ps3.
When I enable super white my contrast gets all weird like below. Same goes for the disney wow cd, all the stars are visible even at 100% contrast. In order to get reference white or pure white i have to raise my brightness 10-15+ points so that i dont see any bars after 235 which then washes out black.
However, if i leave super white off it just clips it exactly where it needs to be and i adjust my brightness & contrast a few clicks (which seems like the right setting). Is the tv smart enough and just knows to clip everything after reference white & black and to know there shouldnt be anymore information? When super whites off if i just raise my brightness or contrast to the max the lines (hd 709) or stars (wow cd) never even show show up.
So should i leave super white on or off? I did also notice super white makes whites more "white" but when off, white becomes more "grey"
Don't know about super white on PS3 but I think you may be confused about calibrating contrast. You don't have to get it to clip at reference white. As long as you can see the bars or stars above reference white you are okay. So actually your fist photo looks fine. It is not like brightness where you want to get it to clip right at reference black. Take a look at the video on the AVS disk. I think they explain this. I was just as confused when I first calibrated contrast until I read the instructions more closely and watched the AVS video.
lm 808 is offline
post #2163 of 2591 Old 03-09-2013, 07:35 PM
absoluteczech's Avatar
Thanks! I ended up realizing that was the case.
absoluteczech is offline
post #2164 of 2591 Old 03-10-2013, 07:44 PM
mcap's Avatar
Could somebody provide optimal calibration settings for the Samsung UN55EH6000 tv? I just replaced my Panasonic Plasma and feel the picture isn't as nice as my older Panasonic. My room is usually on the brighter side with natural light but is also viewed at night. Thanks in advance!
mcap is offline
post #2165 of 2591 Old 03-10-2013, 09:26 PM
chicolom's Avatar
Liked: 47
Originally Posted by Skep1 View Post
I wish there was some way to disable auto-dimming on standard. I had the day off today and spent the better part of it fooling with settings. I had it looking great, but now that the sun has gone down, the picture does not look the same. Is there any way to get movie to be as bright as standard is during daytime? Anyway to disable the auto-dim feature all together?
You can't disable it on Standard, but you CAN calibrate Movie mode to look the same as Standard and just use that instead.
I assume when you say that movie mode isn't as "bright" as standard that you are referring to the differences in contrast.
Standard has a higher default white point (contrast) setting than movie mode. Viewing in Standard mode and setting Contrast to 100 is about the same as viewing in movie mode and having the contrast at 106! If you want to raise Movie mode contrast above the 100 limit, you need to simultaneously turn up the RGB gains, which has the same effect as raising the white point. If you set both sets to the same contrast setting, then go into movie mode's white balance and turn up each of the RGB gains up by 14 points, you will have equivalent contrast between movie and standard modes.
I have my movie and standard modes calibrated to look identical (see my sig).
Super white enables the PS3 to pass whiter than white information (above 235). Disabling it makes the PS3 hard clip any information above 235. This is why when you have super white off you can raise your brightness/contrast controls and still never see anything above 235. The PS3 clips off anything above 235 before your TV ever receives the signal.
Generally it's recommend to show that information if you can (Super White ON). You can't tell if your setting your contrast/white point correctly if the information is always clipped no matter what you set the control to.
With super white ON, you don't HAVE to clip everything at 235, but if you want to you can do what I said above and raise the RGB gains to raise the contrast above the 100 limit (I assume your doing this on movie mode, as Standard can already clip near 235 I think).
I suggest reading the AVS HD 709 "patterns manual" for more information about how to use that pattern and where to clip/set the white point.
By the way, hard clipping at 235 does NOT make your whites whiter. You can actually gets whiter whites by showing information above 235.
Here is an animated gifs showing the difference between hard clipping at 235 and showing whiter than white information. No settings were changed on the TV and the camera was in manual mode so it didn't compensate for the image differences. The only thing changed was whether the source output whiter than white or hard clipped at 235.
(Open them in a new window to see better....)
You can see that everything under 235 looks identical, but pay attention to what happens above 235. The hard clipped signal stays a constant shade of very light gray (235 will be your whitest signal), while the WTW signal keeps getting brighter and whiter as it continues to show the brighter signals up to 255.
You can see the bars stand out more on the whiter than white signal. This is because their white backgrounds become whiter (because they're reaching their 255 potential and not being limited to light grey 235 backgrounds). So the bars have more of a contrast between them and the 255 background, which is why you see them more clearly. On the 235 clipped signal, the background itself is only 235 which is only light grey, so the bars have less contrast between them and the background and blend in more. All of the actual bars (below 235 at least) are identical on both images, it just that background is noticeably whiter on the WTW signal so they stand out more.
It may look like the WTW signal has darker grey bars, but it's just the whiter background that's fooling your eyes into thinking the bars look darker. If you zoom in and ignore the white background, the shades of grey on the bars are the exact same shade.
Here are more still images of showing WTW and hard clipping, if you want to compare those as well:
PlasmaPZ80U likes this.
chicolom is offline
post #2166 of 2591 Old 03-11-2013, 07:02 AM
Skep1's Avatar
Thanks! I will give that a shot when I get home. I noticed this weekend when trying to adjust my contrast using the AVS disk, that when playing through the WDLive I was able to see grey flashing well over 235, but when playing the same file on my mac mini, I could only see 233 max. I know that there is a problem with the 2012 mac mini and crushing whites, but I had the same issue with the beta update that apparently fixes this issue, and when using a mini dp/dvi adapter. I also forced the mini to run in RGB by using a script and found the same results. Perhaps it is just a limitation on the Mini?
Skep1 is offline
post #2167 of 2591 Old 03-11-2013, 01:53 PM
demo23019's Avatar
I'm confused with this auto dim feature .
If it cant be disable in standard what am i looking for i dont notice my screen getting dim.
I remember when i first got TV it would seem to happen
take movie credits or example the brightness on text would dim little
some times during credits you will see extra movie footage at same time its showing credits and at this time the text would be bright again.
but now i dont see this happening its always bright.
edit
nevermind i see it
wish they didn't lock out advance settings in service menu
post #2168 of 2591 Old 03-11-2013, 05:10 PM
Skep1's Avatar
I tried to up my movie white balance gains by 14 in movie and color by 12, and it still isn't quite right. The whites are still a little tan/warm. I am not sure if the white balance offset has anything to do with it. I have tried using default 25 and only adjusting the gains on both modes. Here are my current settings in standard. I think i might be able to live with these, but really hate any type of auto-dim feature.
Mode: Standard
Backlight: 18
Contrast: 92
Brightness: 42
Sharpness: 5
Color: 38
Tint: G51/R49
Color Space: Auto
White Balance: R-Offset: 23 G-Offset: 27 B-Offset: 22 R-Gain: 10 G-Gain: 26 B-Gain: 21
Gamma: 0
Dynamic Contrast: Off
Black Tone: Off
Flesh Tone: Off
Motion Lighting: Off
Color Tone: Warm1
Digital Noise Filer: Off
HDM Black Level: Normal (Grayed Out)
FIlm Mode: Off
Auto Motion Plus: Clear
LED Motion Plus: Off
Skep1 is offline
post #2169 of 2591 Old 03-11-2013, 07:14 PM
chicolom's Avatar
Liked: 47
Try setting Standard and Movie modes both exactly how I have them in my settings, and tell me if they still look different. If they look the same, then fine tune them from there, keeping the same ratios between standard and movie (so, if you turn color down by 3 on one, turn it down by 3 on the other, etc.)
chicolom is offline
post #2170 of 2591 Old 03-11-2013, 07:59 PM
Thanks for detailed information.
As I only have 4 days left for my return window (best buys new 15 day return policy sucks) I have two more questions. If I decide to keep the tv should I go for the extended warranty or no? Is samsungs 2 year good enough?
Last is sometimes when I'm fast forwarding on my cox DVR the screen will cut out and say no signal. Is that normal or some weird feature? Or is something wrong?
post #2171 of 2591 Old 03-12-2013, 02:51 AM
HellMystic's Avatar
Does anyone know anything about MH01 panel version? looking at buying a 65" but want a good panel. thx for the help!
HellMystic is offline
post #2172 of 2591 Old 03-12-2013, 07:54 AM
chicolom's Avatar
Liked: 47
I think it is MVA from AUO Optronics. The service menu for Mxxx shows "L."
chicolom is offline
post #2173 of 2591 Old 03-12-2013, 07:57 AM
fnly's Avatar
When I turn Super White ON, the bright whites turn pink. Am i doing something wrong?
fnly is offline
post #2174 of 2591 Old 03-12-2013, 12:35 PM
you on warm2 or warm1 ?
post #2175 of 2591 Old 03-12-2013, 12:39 PM
jonny-zed's Avatar
FWIW, I have an AU Optronics panel on my UN55EH6001 and have been very happy with it.
jonny-zed is offline
post #2176 of 2591 Old 03-12-2013, 10:41 PM
chicolom's Avatar
Liked: 47
You're seeing color shift at the very upper end of greyscale.
These sets tend to have a pinkish caste on the greyscale, which is why some of us have adusted the white balance and turned down the red gain to correct for it.
You didn't see it while super white was OFF because you were only hitting 235, and the greyscales shifts more noticeably towards red AFTER 235 (between 235 and 255). So you can see it better when you're reaching those higher levels when super white is ON.
Try turning down your red gain. You should also be on Warm 1 or Warm 2, not Cool or Standard (which have even more red+blue = pink). If you look at my white balance settings, you will see I have turned down my red gain in relation to the blue and green gain.
chicolom is offline
post #2177 of 2591 Old 03-13-2013, 04:42 PM
PlasmaPZ80U's Avatar
Quoted: 2297 Post(s)
Liked: 706
if anyone is curious how auto and native color spaces compare on these sets, I've added some data from my TS01 46" EH6030
http://www.avsforum.com/t/1395734/official-samsung-unxxeh6000-owners-thread/750#post_22514527
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
post #2178 of 2591 Old 03-14-2013, 08:11 AM
fnly's Avatar
thank you! turning down the red gain did the trick.
fnly is offline
post #2179 of 2591 Old 03-14-2013, 12:59 PM
would buying an extended warranty from best buy be worth it on a UN40EH6000?
post #2180 of 2591 Old 03-14-2013, 02:23 PM
lm 808's Avatar
From what I've read Best Buy's extended warranty isn't the best. I'm still debating whether to get a 3rd party extended warranty.
This is my first lcd/led set. For those of you who have more experience with these sets, did you experience serious problems between years 2-5 or do most issues only pop up in the first couple of weeks?
lm 808 is offline
post #2181 of 2591 Old 03-17-2013, 11:03 AM
Anyone have any tips on how to raise the tv an inch? My Sony sound bar blocks the ir sensor when sitting on the sofa. So I have to stand or raise my hand up when I use my harmony one to turn the tv on. Any thoughts? No wall mount either.
post #2182 of 2591 Old 03-17-2013, 03:20 PM
demo23019's Avatar
Could try something like this.
http://i.imgur.com/hg695Hv.jpg
Or what i did.
I popped mine off all together its easy to remove.
Was in the way of my already mounted speaker. I wrapped in anti static bag and sits in back of TV you cant see it and he IR picks up remote no problem.
mine is mounted on wall and easy to hide not sure how it would look when on stand.
http://i.imgur.com/bHWDjb1.jpg
http://i.imgur.com/tAvCsf6.jpg
post #2183 of 2591 Old 03-17-2013, 03:29 PM
Cdinkha44's Avatar
I bought a Samsung UN60EH6050F yesterday from Costco. My problem is I'm having issues with the picture quality. The picture is gray and blurry when watching TV shows. Does anybody have a good settings for this model?
Cdinkha44 is offline
post #2184 of 2591 Old 03-17-2013, 03:51 PM
Demo thanks ill try just popping it off then. Just to confirm the ir is where the tv power button is right?
post #2185 of 2591 Old 03-17-2013, 07:20 PM
Cdinkha44's Avatar
Anybody can help?
post #2186 of 2591 Old 03-17-2013, 10:26 PM
chicolom's Avatar
Liked: 47
You could try some "furniture sliders" in each corner.
chicolom is offline
post #2187 of 2591 Old 03-18-2013, 05:10 AM
DarrellG's Avatar
Quoted: 90 Post(s)
Liked: 118
Originally Posted by Cdinkha44 View Post
Anybody can help?
Skep1's settings:
http://www.avsforum.com/t/1395734/official-samsung-unxxeh6000-owners-thread/2160#post_23069051
Mode: Standard
Backlight: 18
Contrast: 92
Brightness: 42
Sharpness: 5
Color: 38
Tint: G51/R49
Color Space: Auto
Gamma: 0
Black Tone: Off
Flesh Tone: Off
Color Tone: Warm1
FIlm Mode: Off
DarrellG is offline
post #2188 of 2591 Old 03-18-2013, 07:01 AM
dfp
dfp's Avatar
Try a nicely finished piece of wood, like a 1 inch shelf, under the stand.
dfp is offline
post #2189 of 2591 Old 03-18-2013, 12:57 PM
demo23019's Avatar
Yea its all in that piece.
Also just read some other advise before you go removing it might want to try some alternatives.
I had to remove mine so speaker would sit flush under the TV. Your TV just needs to be raised slightly and what others have said might work.
post #2190 of 2591 Old 03-18-2013, 01:04 PM
Skep1's Avatar
Don't make the mistake I did and judge based on a cable STB. Obviously different broadcasts are better than others. One thing that I did that made a tremendous difference, was swapping out my older HD DVR with a newer model that allowed me to set the resolution to native instead of default 1080i.
Skep1 is offline
Reply LCD Flat Panel Displays
Samsung , Samsung Un55eh6000 Led Hdtv , Led Hdtv , Samsung Ln37d550 Lcd Hdtv , Samsung Un55d6000 , Samsung Un46eh6000 Led Hdtv , Samsung Un46eh5000 Led Hdtv , Samsung 40 Inch Led 3d Hdtv Un40eh6030 , Samsung Ln46c630 46 Inch 1080p 120 Hz Lcd Hdtv Black
