Official Samsung UNXXEH6000 Owners' Thread - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #211 of 2591 Old 05-25-2012, 12:32 PM
Pandemonium08's Avatar
Originally Posted by syntax53 View Post
I consider myself pretty darn critical of TVs (bought and returned *4* TVs before settling on this one) and I've noticed quite a bit of ghosting on various LCD computer monitors throughout my 20+ years of heavy gaming. I can honestly say that I notice literally zero ghosting or soap opera or any of those issues with this TV. Maybe I got lucky with my panel, but outside of the darker corners and some soft tones here and there (which I expect to be fixed once someone posts professional calibration settings), this TV is a winner for me.
I dont know if there is a panel lottery with the EH series but every one I've tried on different stores show the very same issue and also a limited horizontal viewing angle, depending on the image it may appear 'brighter' or to have more contrast on its left and right sections of the screen and when you center your head to the edge it shows you the actual 'contrast' of the image.
The limited viewing angle is more annoying compared to the very rare instances that I notice ghosting.
Pandemonium08 is offline
post #212 of 2591 Old 05-25-2012, 04:36 PM
syntax53's Avatar
I feel like the viewing angle on this TV is comparable or better than the $3,000 Samsung d7000 series TV I had at one point. Sub-optimal viewing angle and LCD's go hand and hand. You either go plasma and sacrifice brightness for better PQ and viewing angle, or get good brightness and decent PQ with not so great viewing angles in an LCD.
syntax53 is offline
post #213 of 2591 Old 05-25-2012, 05:16 PM
Grt
Grt's Avatar
I've had this set for about a month and the shadows in the lower left and upper right corners have almost gone away, and the other two corners seem to be getting better so I wonder if this might be a break in issue.
The lighter contrast that people are seeing on the left and right side of the panel also exists on the top and bottom. I happened to see a scene where the entire panel was filled with a light gray overcast sky. I have a 55" set and the lighter contrast clearly formed about a 2" band around the entire outside portion of the panel. I figured this was just the outline of the LED back light array. That is the only time I noticed it on the top and bottom, but it is there. I notice the lightness on the left and right sides only against light backgrounds when the camera is panning across the screen, and even then it's very minor and I don't really notice it anymore. I never noticed it when the camera was still. With that said, I think it's a great TV and it doesn't take away any of the enjoyment of the picture for me.
Grt is offline
post #214 of 2591 Old 05-25-2012, 06:59 PM
Jjaro's Avatar
Originally Posted by djjaeger View Post
True, but EH5000 isn't available in the larger sizes (only up to 46" from what I can tell on the sammy website). I also noticed a 6050 series which looks the same as the 6000 but with the touch of color (redish) frame.
I just did some research on this myself, (I just bought a 60" 6000 series) and was curious about the differences. According to Samsung's website:
-6000 series has a larger contrast ratio (5,000,000:1 vs 4,500,000:1)
-6050 has Dolby Digital Plus/Pulse (not sure how this makes a difference coming from the TV speakers, or how it works at all, maybe someone can clarify? Mine is hooked up through an AV system...coincidently also a Samsung)
-As stated above, the casing color is dark reddish, hard to tell in pictures though (My old 2008 Samsung had TOC red, I guess it's kind of like this).
-And last, the "Specs" page on Samsung's website has a few minor differences, like showing codecs listed for the 6000 series and not the 6050; also listed is "Typical power consumption" for the 6000 (70w) but it's not on the 6050 Page.
I am very happy with the TV, It's an upgrade for me from my old Samsung TOC 2008/2009 model (LN40A650) which was an awesome TV (although Using my PC or Mac on it though the HDMI ports looked like crap, when I did that I used the PC port).
Jjaro is offline
post #215 of 2591 Old 05-25-2012, 09:17 PM
mugabe's Avatar
Checked out the 60" at BB last night. Popped in my USB which had a 720p episode of Band of Brothers and an average quality hockey game on it.
Band of brothers looked good, except for the awful SOE that I couldn't get rid of in the menus. Tried setting AMP to off, and also to custom (0) and I still got SOE. I noticed some people here stating that they got rid of it completely. Is there anything settings-wise that I missed?
Then I tried the hockey game. That was an even worse experience. This is my first time seriously looking at an LCD (I'm coming off a Sammy plasma), so I'm not sure what all the terms are yet, but basically the players and especially the puck had trails behind them (ghosting??). The puck looked like it was flashing rapidly when moving around the screen. Granted, the actual source was rather poor and is just a random game I downloaded off the web, so that's probably why the image/motion was so bad. I'm gonna try going again with a better source this time and see if there are any improvements, but I'd like to know how hockey/sports fans are enjoying this set.
Other than that the image quality looked great on whatever was their own demo Bluray. Great blacks and adequate brightness.
mugabe is offline
post #216 of 2591 Old 05-26-2012, 05:03 AM
syntax53's Avatar
I'm a big hockey fan and have no issues watching hockey with this TV. Much more enjoyable experience compared to a plasma too, IMO. I like having white ice instead of gray ice. You want to set auto motion to clear, not off.
syntax53 is offline
post #217 of 2591 Old 05-26-2012, 07:51 AM
mugabe's Avatar
Thanks, that's re-assuring since bad hockey is what turned me away from another plasma (Panny ST50). That and SOE are deal breakers for me, so I'll try again at BB before deciding.
mugabe is offline
post #218 of 2591 Old 05-26-2012, 08:36 AM
Then that proves there is panel lottery on this TV.
post #219 of 2591 Old 05-27-2012, 05:46 AM
bandit390's Avatar
Quoted: 17 Post(s)
Anyone having any random issues with the sound cutting out and the picture flickering near the bottom for a couple seconds?
bandit390 is offline
post #220 of 2591 Old 05-27-2012, 09:43 PM
dantvreview's Avatar
Help help
Just I got the UN60EH6050F for Costco .
There are any settings to clear the motion for the live sport like basketball
Always I see a ghost and is very grainy
This TV has the worst picture when I am watching basketball; the picture is not sharp and is very grainy
I am using a high definition box for my cable company cox communications
When the game does not have a fast move the picture is ok but when they speed the ball the picture is really bad
Should I return this TV and buy a plasma TV instead?
dantvreview is offline
post #221 of 2591 Old 05-27-2012, 09:45 PM
go to the samsumg web page to upgrade the software
they have a patch for that issue
post #222 of 2591 Old 05-28-2012, 08:37 AM
dgregryc's Avatar
There is no new firmware for the 'auto motion plus won't stay off' issue for the UNEH6050 as of this posting. Only the Mar 20 firmware (original that shipped with my TV) is there. I've decided to return this TV to Costco and purchase a different brand, as I'm 90% sure that Samsung won't fix this until we're out of the 90 day return window.
dgregryc is offline
post #223 of 2591 Old 05-29-2012, 01:16 PM - Thread Starter
Test Pattern's Avatar
If you set the Auto Motion Plus to "custom," and then set the two parameters to "0," that should do the trick and keep the AMP effect off. You might also set AMP to "clear" and see if you like that setting (others have recommended the "clear" setting).
Test Pattern is offline
post #224 of 2591 Old 05-30-2012, 05:36 AM
gexxxy's Avatar
UN55EH6000FXZC anyone have the white points settings i have a beautiful picture so far but like to get it at tops thankz.. Great tv by the way better than the LG 55LV4400 i had picked up returned it in 5 days not happy at all, this one kicks ass...
gexxxy is offline
post #225 of 2591 Old 05-30-2012, 01:25 PM
smkstang1's Avatar
Looking to pick this one up tonight, but have a quick question... will be running a PC to this and am concerned about the audio portion. The video is DVI->HDMI, however I do not see an Audio input jack on this TV. Would it be possible to assign an audio input from the Red / White RCA cable to the HDMI (PC) Mode or this needs to be forced through a secondary processing unit (Soundbar / Receiver)...
Thank you
HD-A30 & PS3
HD-DVD: ~27
Blu-Ray: ~22
smkstang1 is offline
post #226 of 2591 Old 05-30-2012, 02:15 PM
gexxxy's Avatar
http://www.futureshop.ca/en-CA/produ...ad51d65427en13
hi there smkstang1 this is a picture of backside of tv
gexxxy is offline
post #227 of 2591 Old 05-30-2012, 05:08 PM
smkstang1's Avatar
Hey, thanks for the pic... I am still unsure though if I could do it. In the worst case scenario, I can get a soundbar for the house... got the TV anyhow. Lets see if anybody can come up with some good settings for it.
HD-A30 & PS3
HD-DVD: ~27
Blu-Ray: ~22
post #228 of 2591 Old 05-30-2012, 06:54 PM
gexxxy's Avatar
settings if anyone interested:
Mode: standard
Backlight-14
Contrast-100
Brightness-46
Sharpness-28
color-43
Tint G45/r55
Advanced settings::
colorspace -auto
White Balance:
R-offset 30
G-offset 30
B-offset 30
R-Gain 38
G-Gain 34
B-Gain 33
Gamma -1
Dynamic contrast med
Blacktone off
Flesh tone 0
Motion lightning off
Picture options
Color tone cool
size 16:9
Digital noise off
HDMI level normal greyed out
film mode off
Auto motion clear 9 Blur Judder 10
Led off
smkstang1 these are my settings for now they work great...
gexxxy is offline
post #229 of 2591 Old 05-30-2012, 06:55 PM
syntax53's Avatar
Are these settings from using a calibrator?
Dynamic contrast high
Blacktone Darkest
Color tone cool
... are all big no no's in the world of tv calibration.
syntax53 is offline
post #230 of 2591 Old 05-30-2012, 07:22 PM
gexxxy's Avatar
Blacktone Darkest
Color tone cool
no just my settings,,,,just passing these on they look good so if anyone wants they can use them there not from a calibrator,,,from my personal settings..
gexxxy is offline
post #231 of 2591 Old 05-30-2012, 07:24 PM
syntax53's Avatar
You'd probably have more uniform contrast if you set dynamic contrast to medium and turn black tone off.
syntax53 is offline
post #232 of 2591 Old 05-30-2012, 08:20 PM
gexxxy's Avatar
syntax53 thnkx made the change looks better...
gexxxy is offline
post #233 of 2591 Old 05-30-2012, 09:11 PM
wolfgang armbru's Avatar
Agree...pix looks better.
Thanks for the settings.
wolfgang armbru is offline
post #234 of 2591 Old 05-31-2012, 10:27 PM
labk888's Avatar
Has anyone done a real CRT test to determine the actual input lag on this set? I am really interested in purchasing this TV but I am hesitant to pull the trigger unless the input lag is at most 16ms.
labk888 is offline
post #235 of 2591 Old 06-01-2012, 01:57 AM
gexxxy's Avatar
i havent had any problems with this set so far motion clear runs great hockey looks amazing fast scenes dont jidder so far runs great made some more color tweaks and all i have to say it runs great its a fat babe but it hasnt let me down so far i dont know about this lag thinggy,,,but i made a great investment for my part...
gexxxy is offline
post #236 of 2591 Old 06-01-2012, 04:32 PM
Zasekamoz's Avatar
Which models have better PQ D6xxx or ES6xxx or EH6xxx? I would like to buy 55inch TV and there is a big money difference.
- Samsung UN55ES6100 is $1,579.99
- Samsung UN55D6000 is $1,259.00
- Samsung UN55EH6000 is $909.93
Any recommendations or suggestions will be welcome.
Zasekamoz is offline
post #237 of 2591 Old 06-02-2012, 07:52 AM
Jim1348's Avatar
Quoted: 124 Post(s)
My Panasonic 42 inch Plasma TH-42PD50U went out of service yesterday and I am looking for a Samsung 46" LED or LCD to replace it. Can anybody point to any good wwebpages or other sources to help me select which 46 inch Samsung LED or LCD would be a good choice for me?
Jim1348 is offline
post #238 of 2591 Old 06-02-2012, 09:18 AM
gexxxy's Avatar
Jim1348 http://www.futureshop.ca/en-CA/produ...ad51d65427en13
go here and look around..i own this model very happy with it.
gexxxy is offline
post #239 of 2591 Old 06-02-2012, 06:41 PM
Jim1348's Avatar
Quoted: 124 Post(s)
I get:
HTTP 404 Page not found.
Can you please post it again.
Jim1348 is offline
post #240 of 2591 Old 06-02-2012, 09:00 PM
gexxxy's Avatar
gexxxy is offline
Reply LCD Flat Panel Displays
Samsung , Samsung Un55eh6000 Led Hdtv , Led Hdtv , Samsung Ln37d550 Lcd Hdtv , Samsung Un55d6000 , Samsung Un46eh6000 Led Hdtv , Samsung Un46eh5000 Led Hdtv , Samsung 40 Inch Led 3d Hdtv Un40eh6030 , Samsung Ln46c630 46 Inch 1080p 120 Hz Lcd Hdtv Black
