Official Samsung UNXXEH6000 Owners' Thread - Page 86 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #2551 of 2591 Old 05-23-2014, 10:51 PM
mdneilson's Avatar
I'm sure I'll have to hide with embarassed shame after asking this. I recently picked up the 55" version of this tv for a good deal. I'm curious if it'd be possible to swap in the video main board from the FH6200 model so I can have smart features on it? (obviously case cutting would be required) The 6200 uses the same power supply, and has all the same connectors. The tcon is obviously different, since it is a different panel. Anyway, am I just living a pipe dream, or is this possible?
mdneilson is offline
post #2552 of 2591 Old 06-06-2014, 06:39 PM
mdneilson's Avatar
Well, after much research, I decided to take a $50 gamble and bought a whole set of 6200 boards on ebay. Well, it works! And it didn't even need case cutting! (I have the CH01 panel btw) biggrin.gif
nxsfan likes this.
post #2553 of 2591 Old 06-15-2014, 10:02 PM
Dendk's Avatar
7 months of ownership and I am still happy with this 65 inch 6000 series unit, the initial calibration made all the difference, also just upgraded firmware 1022 to 1024. For a sub $1000 unit it worked out well, only issue has been serious red dot screen issue when running it through my Harmon kardon reciever using pass through to my Xbox One solution was to take receiver out of the loop and run HDMI straight to the TV.
Dendk is offline
post #2554 of 2591 Old 06-17-2014, 07:16 AM
drl74's Avatar
Red face v1024 Firmware... anyone?
Hello all... It's been 3+ months soince it was released... I was wondering if anyone has upgraded to the v1024 firmware. I currently have v1022, and other than slow power up, and slow source input change speeds, I've been very please with this television. I don't want to screw up the TV, but if the firmware makes it better, I'll all for it.
Have there been any brave souls that have made the change? If so... what are the differences?
drl74 is offline
post #2555 of 2591 Old 06-18-2014, 01:00 PM
Zaxdad's Avatar
Quoted: 12 Post(s)
Hi All.
2 Questions. Have a big birtday today and my wife surprised me wit a Sony kdl-65w850a.( Guess if you leave certain web pages open they will get the message.) Is there somewhere in either the menu or the service menu that shows how many hours are on the set? Also,anyone have an idea what a fair resale price would be for a 19 month old 60" set. Have all the packaging.
Thanks for any help.
Howard
Zaxdad is offline
post #2556 of 2591 Old 06-23-2014, 11:50 AM
nxsfan's Avatar
Quoted: 24 Post(s)
I'll second this opinion. I have zero regrets about buying this set. Out of the box it's terrible, but once calibrated it looks terrific watching good content and it certainly prompted friends to consider upgrading their sets.
Thanks for trying the 1024 firmware. Did you see any changes in behaviour after upgrading. Is there any reason to upgrade? Any effect on the colour banding?
nxsfan is offline
post #2557 of 2591 Old 06-26-2014, 09:45 PM
amusementshark's Avatar
Liked: 1
I upgraded firmware on my UN55EH6000 on Monday. Everything seems to be working fine so far.
The Samsung site says the 1024 firmware "Corrects AMP setting to work."(!) Guess it wasn't working before? I actually enjoy SOE to some extent (I like that high frame rate effect in The Hobbit, for instance) so AMP was part of the reason I picked this TV up at Best Buy in February 2013. I hadn't been noticing much SOE with blur and judder reduction both on 10, but I was getting bad screen tearing (I think that's what it's called; fast-moving objects are surrounded by clouds of pixels), and haven't noticed this since upgrading. I think my old firmware was version 1017.
Also, my panel is a CH02. How does that compare to other panels out there for this TV?
bewlaybrothers likes this.
amusementshark is offline
post #2558 of 2591 Old 06-30-2014, 06:17 AM
bewlaybrothers's Avatar
(snip)
Thanks for your post. Both it and release notes that were FINALLY posted on Samsung's site in the (recent?) past allowed me the gumption to upgrade the firmware on my 46" model. So far, playing Netflix, blu-ray, HBO GO and broadcast HDTV I notice no issues and possibly better brightness under Eco Mode, although it's hard to tell. I notice no improvement in AMP however, and to my knowledge it was always working fine under the 1012 firmware (previous official release on the Samsung site) using my preferred Blur 10/Judder 0 under Custom in order to supposedly do proper 5:5 24p pulldown. The annoying "Netflix jerk" effect remains every few seconds so I have to disable it for that, still, but I've learned to live with that inconvenience.
So in short, I doubt there's much risk in updating and perhaps possible benefits.
bewlaybrothers is offline
post #2559 of 2591 Old 07-04-2014, 12:41 PM
nxsfan's Avatar
Quoted: 24 Post(s)
I upgraded the UN65EH6000 firmware from 1022 to 1024. It saved my settings.
No perceivable changes (so far) and it didn't fix the banding issues.
nxsfan is offline
post #2560 of 2591 Old 07-28-2014, 01:49 PM
tylerk86's Avatar
Quoted: 38 Post(s)
Originally Posted by nxsfan View Post
I'm glad you are happy lightforce18. That must be some beastly mount you are using.
<hr class="bbcode_rule">
I discovered tonight that something strange happens when you label the input as "PC" or "PC DVI". I see this has been discussed somewhat by other Samsung holders.<br><br>
With the input labeled as PC you get a new mode "Entertain" (but I stuck with Standard), you automatically get 1:1 pixel mapping without selecting "Screen Fit".<br><br>
Color, Tint and most of the post-processing settings are disabled, but I ended up with a decent picture without changing much.<br><br>
Mode: Standard<br>
Backlight: 12<br>
Contrast: 100<br>
Brightness: 45<br>
Sharpness: 50 (this needs to be very low when the input is not labelled as PC)<br><br>
White Balance: Untouched<br>
Gamma: -3<br>
Color Tone: Standard<br>
HDMI Black Level: Normal<br><br>
One downside is that the TV jumps out of this special mode when it receives 1080p24 so for now I'm outputting blurays at 1080p60.<br><br>
Some of the stuff I watched tonight really looked incredible. EDIT: I added photos of the TV with these settings to my lengthy post <a class="bbcode_url" href="http://www.avsforum.com/t/1395734/official-samsung-unxxeh6000-owners-thread/2400#post_24027452"><b>here</b></a>.<br><br>
Unless the banding issue drives me mad, this TV is definitely a keeper.
Did you change anything except the Gamma? All the other settings you posted seem to be the standard configuration for PC input. Any reason to keep the Gamma and backlight as low as you have them?
tylerk86 is offline
post #2561 of 2591 Old 08-09-2014, 04:33 PM
nxsfan's Avatar
Quoted: 24 Post(s)
Hey tylerk86, I'm sorry it took so long for me to reply.
I just checked my settings and I have made a couple of changes after further playing with the Disney WOW disk.
Contrast: 90
Color Tone: Warm1
Gamma: -2
Backlight: 12, is plenty bright enough for daytime viewing in a well lit room. If it seems dark to you I imagine you have a different panel.
nxsfan is offline
post #2562 of 2591 Old 08-16-2014, 08:51 AM
tylerk86's Avatar
Quoted: 38 Post(s)
Thanks for the reply, nxsfan. HDMI level is grayed out for me with these settings; any thoughts?
tylerk86 is offline
post #2563 of 2591 Old 08-19-2014, 07:03 AM
onetontomato's Avatar
The 65" version of this TV is on my short list right now. I saw it at Wal-Mart and although it looked crappy there I trust user reviews and they look favorable. I wanted to get some info from users if possible.
How is it with bright rooms, light reflections and wide viewing angles? My TV will be in a corner angled to both a living room and a breakfast nook. The breakfast nook will be viewing it from a wide angle so I want to make sure the screen accommodates this. Viewing from the living room there are a few windows in the kitchen that will reflect off the screen and the whole room can be bright in the daytime.
Also how does it look with SD content? Most of what I view will be HD but I do have an old DVD player that we occasionally use and some of the content on the Roku that the kids watch is SD.
I currently have a Sony R60XBR2 that has finally succumbed to the green cast from the optical block failing. The entire screen has a heavy green tint now. This TV when tuned properly looked better than any TV I have ever seen. The lamp is at the end of it's life also. I figure time for a new TV instead of replacing the lamp and trying to find out how to get the optical block fixed. From what I gather warranty replacement is out of the question. And the optical block isn't made anymore.
Thanks for any replies.
onetontomato is offline
post #2564 of 2591 Old 08-22-2014, 08:38 AM
Penetronn's Avatar
Picked up a UN50EH6000 at Best Buy yesterday to replace a PN51E550 I bought last year. I loved the PQ of the plasma but it burned in like a beast even after over 500 hours of low contrast/low brightness settings. They had the 6000 advertised in the store on sale for $699 but they honored their website price of $639 and I pulled the trigger. I was shocked to find out that the 6000 does not have an RBG Only setting to adjust color and tint during calibration. Anyone know if this is accessible via a firmware update, service menu? I'd hate to have to purchase THX blue filter glasses for this, but I'm afraid there may be no other way.
Otherwise, good PQ - though nothing like the glorious PQ the plasma offered. A shame burn-in is such an issue still.
Penetronn is offline
post #2565 of 2591 Old 08-30-2014, 06:54 PM
Dendk's Avatar
A Little update on this TV...started having shutoff issues after a few hours....Samsung technical was superb, on time and replaced three components, the mainboard, daughter board and an updated longer cable from board to display.
They claim it is a known issue with the cable being to short causing separation/shutoff when the unit gets hot...but they also replaced all the boards to be sure, only two component boards behind the panel took all of 10 minutes.
Dendk is offline
post #2566 of 2591 Old 10-11-2014, 07:27 AM
PlasmaPZ80U's Avatar
Quoted: 2070 Post(s)
Liked: 594
added updated calibration/settings for my UN46EH6030 in my sig (first link)
Current Setup REW measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is offline
post #2567 of 2591 Old 10-16-2014, 05:48 AM
ganzhimself's Avatar
Does anyone happen to know the size of the screws that go from the pedestal stand to the back of the TV? I'm selling mine and can't find the screws that I thought were in the box. I've been able to determine that M3 screws go from the pedestal to the back plate, but I don't know what size goes from the back plate to the TV. Samsung tech support said they were all M3 6mm, but IDK.
ganzhimself is offline
post #2568 of 2591 Old 10-16-2014, 06:05 PM
The base screws are not M3 either. Don't know what Samsung tech support is smoking. IDK. The search continues.
post #2569 of 2591 Old 10-17-2014, 02:41 AM
Liked: 1
Originally Posted by iBrad View Post
Quote:Originally Posted by marshall110
For those of you who are satisfied with your EH6000/6001/6003/6050, no need to read the rest of this post as it may ruin the set for you. Maybe not. If you're still evaluating and do not see this issue in these scenes, please report back if possible.
I have two separate UN60EH6050 from Costco and both exhibit the purple/violet ghosting issue. Very minor but it is there and it is consistent with dark edges on light backgrounds. In previous posts, another member used the scene in The Return of the King where Gollum goes nuts with Sam in the swamp as a test scene. When I originally watched this scene, I saw zero ghosting on Gollum's edges. This is because I didn't know what to look for and now that I have seen it, I can detect it in the Gollum scene, but he moves so quickly that it just isn't a very good scene for detecting if your set has this issue. I think the scene right after is much better. Aragorn is silhouetted and walks out onto the balcony. You can see slight purple ghosting on the edges of his silhouette. Another scene that jumps out at me is in X-Men Origins Wolverine near the end right when he gets the top of the reactor just before he fights Deadpool. He's climbing with his claws and then jumps up on the ledge. I can see it plain as day here. During the battle, watch the edges of Victor's coat while they battle Deadpool. All in all the ghosting is minor but it is there on my sets. The Walking Dead episode "Killer Within" shows it as well in the dark scenes in the prison where there's a lot of movement. I think any dark scene with fast moving characters will exhibit the ghosting. The ghosting is not present when you pause the scene or step through it, only when it's playing. I'm wondering if Samsung could at least update the firmware to have the ghosting grey scale if not eliminated altogether.
Quote:Originally Posted by chicolom
The purple ghosting issue seems to be isolated to Sharp panels FWIR. And AFAIK the 60" models only use sharp panels. So other EH6000/6001/6050/etc owners may not see any symptons of it unless they also have a sharp panel.
Since the problem is likely with the panel itself and not with any software, I wouldn't expect a firmware update to fix anything.
Quote:Originally Posted by PlasmaPZ80U
I believe you're right about this, though it seems the 60Hz (Sharp) panels are more affected by this than the 120Hz (Sharp) ones.
There is a workaround solution for this purple/dark-red smearing/ghosting, it's probably caused by the minimum brightness bias-level for the "lcd pixel Response Time Compensation (RTC) / pixel overdrive circuit".
Its overdrive influence the Samsung panels also, happens on my UE40EH6030 with Samsung 40A1AF0D panel, this was discussed somewhere in thread "The *OFFICIAL* 2012 Samsung EH4000/EH5000/EH5300 Owner's Thread"
To get rid of purple smearing:
- set BRIGHTNESS at 45 or above, lower the backlight to compensate the black level.
- set BRIGHTNESS at 50 or above, when LED MOTION PLUS = ON
To get rid of dark/black screen dimming/muting:
- set BRIGHTNESS at 44 or above.
Someone gonna report these to Samsung, so they can fix it with new firmware?
Hi , I have same exact problem my new 60h7000 model ... please look at the topic below and suggestions please
Samsung 60h7000 red tracing issue ?!!!
veram is offline
post #2570 of 2591 Old 11-29-2014, 10:15 PM
nozerider's Avatar
Just replaced my PS3 with a PS4 for gaming and blurays. Can anyone recommend rgb and y/pc/br settings? Auto/limited/full?
nozerider is offline
post #2571 of 2591 Old 12-06-2014, 02:57 AM
Liked: 0
It seems like auto would be the best choice according to Playstation Support. Here is what they say:
"RGB Range: Change this only when you use an HDMI device that does not send RGB range information correctly. [Automatic] is the default and recommended setting. If you'd like to change this setting, check your TV's capabilities before doing so.
Y Pb/Cb Pr/Cr Range: Change this only when you use an HDMI device that does not send Y Pb/Cb Pr/Cr range information correctly. [Automatic] is the default and recommended setting. If you'd like to change this setting, check your TV's capabilities before doing so."
I don't know what it is, but seemingly out of nowhere I noticed the banding others have been commenting on. I have the UN40EH6000. It seemed fine for the longest time, but now its all I notice. I'm already debating to get a new set although I wanted to wait.
Does anybody happen to have the latest firmware ver.1024.0 they can share? It seems it can't be downloaded from Samsung currently, but maybe it's an issue they will work out.
divlyfein is offline
post #2572 of 2591 Old 12-25-2014, 07:19 AM
lovingdvd's Avatar
Quoted: 2761 Post(s)
Liked: 586
1. I'm looking to purchase the 46" H6203 from Best Buy. How is this unit different from the 60XX and 61XX?
2. Am I correct to assume the 6203 has 10 point white balance control and CMS cintrol for calibration?
3. Most importantly - how well does this TV track for color saturations? Has anyone measured and posted this from CalMAN? I'd love to see a saturations chart in 25% steps for RGBCMY as well as the avg and max dE for the ColorChecker CalMAN workflow and graph if anyone has seemed/posted it.
Thanks!!
lovingdvd is offline
post #2573 of 2591 Old 12-26-2014, 01:13 PM
Liked: 0
Can't change the spdif?
So earlier today I bought a Magnavox sound bar for my samsung. I notice in the audio settings it wont let me change it to dolby digital even though the sound bar supports it.. I have it hooked up to my tv through a optical cable. Any ideas what is going on?
Matthew Baucom is offline
post #2574 of 2591 Old 12-26-2014, 07:06 PM
lovingdvd's Avatar
Liked: 586
Guys - I just picked up the 46" 6203 from Best Buy. I like it, however it has one significant issue... There is a cloud-like shadow in parts of the right-hand side of the image. It is particularly noticeable in bright scenes and definitely not in the source. Is this a known or common issue with this set? I don't mind exchanging it, however if the odds are that my next set will also have the issue than I may just return it instead of exchanging it. Thanks!
post #2575 of 2591 Old 12-26-2014, 07:11 PM
lovingdvd's Avatar
Liked: 586
Also - I read there are some complaints about the "cheap stand" on these units. Mine has an issue in that the TV leans forward when on the stand (even thought I'm sure the table is level). Perhaps I did not put the stand together right because there are no instructions. It came with 8 screws but I only saw a way to use 6, so maybe I did something wrong...? I screwed 4 into the base that goes into the back of the TV, and 2 into the "pipe". Did I miss something or is the TV being "top heavy" and learning forward a known issue?
post #2576 of 2591 Old 12-26-2014, 09:51 PM
lovingdvd's Avatar
Liked: 586
I will answer my own questions for posterity purposes now that I have the unit and have calibrated it.
Yes - it has 2 and 10 point white balance, as well as RGBCYM adjustments for custom CMS calibration. The calibration controls work well and are very responsive with little interaction between points (a good thing).
Thanks!!
The color tracking on this TV is excellent, especially for a $600 TV. There are very slight color errors, but nothing that would stand out without a direct A/B comparison with a reference set.
Unfortunately I have some very significant "clouding" on the top right side - basically a permanent "shadow" on the picture, particularly noticeable on bright scenes. Hopefully someone will let me know if this is just a fluke or if this is a common problem. I'll return it no problem and exchange it, but if its a very common issue I may be hesitant to try another set.
Here's a picture of the "cloud" in action. This is a photo taken of a golf shot in the sky on a cloudy day, so disregard the dot on the left - that's just the golf ball. You can see the "cloud" on the right in a bow-like shape. And yes I am certain it is not actually a cloud. That shadow is overlayed on all pictures. There is some on the left too but its not as prominent. Is this a fluke or common issue with these sets?
post #2577 of 2591 Old 12-26-2014, 10:37 PM
lovingdvd's Avatar
Liked: 586
Here's another example of the clouding.
post #2578 of 2591 Old 12-28-2014, 07:34 PM
lovingdvd's Avatar
Liked: 586
I exchanged the set for a new one. Glad I did - the clouding in the other one was definitely a defect and the new set does not have any trace of such clouding (and has rather good uniformity overall). Very pleased with this 46" TV for just $600 (tho this TV is for casual viewing so I wouldn't hold it to the same standards I'd be looking for to use it for critical viewing).
post #2579 of 2591 Old 12-31-2014, 07:08 AM
rlichtefeld's Avatar
I'm looking at purchasing this set also. Can you confirm if it has HDMI-CEC (Anynet+)? I contacted Samsung and they said yes, but I've seen several posts that says it doesn't.
Thanks: ijprest, waynethedvrguy, Remmer99, hdonzis, gduprey, LeeThompson, j.m., archdog99, FlipFlop, The Dreamer, chriv and all the other Replay Hackers out there.
rlichtefeld is offline
post #2580 of 2591 Old 12-31-2014, 07:13 AM
lovingdvd's Avatar
Liked: 586
Sure. I'll let you know in a couple of hours.
rlichtefeld likes this.
Reply LCD Flat Panel Displays
Samsung , Samsung Un55eh6000 Led Hdtv , Led Hdtv , Samsung Ln37d550 Lcd Hdtv , Samsung Un55d6000 , Samsung Un46eh6000 Led Hdtv , Samsung Un46eh5000 Led Hdtv , Samsung 40 Inch Led 3d Hdtv Un40eh6030 , Samsung Ln46c630 46 Inch 1080p 120 Hz Lcd Hdtv Black
