Unsupported audio format in MKV file on LG 47LW5600 TV. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-22-2012, 07:44 PM - Thread Starter
kompulsive's Avatar
I have an LG 47LW5600 TV which I am connecting an external hard-drive to in order to play video files. I've come across an MKV file that I'm getting an "Unsupported audio format" error with. The file contains DTS audio. I'm assuming that I will need to convert the DTS audio in the file to another format and remux the MKV file with the converted audio file. What is the simplest course of action to achieve this?
"To experience oneself honestly, not lying to oneself, and to express myself honestly; now that...is very hard to do."
- Bruce Lee
kompulsive is offline
post #2 of 3 Old 02-22-2012, 09:05 PM
fireballz's Avatar
try mkv2vob, great little program. Under configuration check "always transcode DTS"
i think this is what you're looking for.
fireballz is offline
post #3 of 3 Old 02-25-2012, 09:48 AM
pete4's Avatar
audioconverter.exe worked for me great.
pete4 is offline
Reply LCD Flat Panel Displays
Lg Infinia 47lw5600 47 Inch Cinema 3d 1080p 120 Hz Led Lcd Hdtv
