Programming LG TV to turn-on and play a video from USB automatically - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-24-2012, 03:50 AM - Thread Starter
rodelius's Avatar
Hello.
I am building a simple digital signage display based on the LG 32LV355C.
I just need the tv to turn-on by itself and play a single file from USB continuously.
The TV can turn-on and off by itself automatically at a certain time and it allows to select any input... except USB.
I have been told by the sales rep that it would be possible to program the TV to do this through RS-232 but he could not provide any details about the process and necessary software to do the job.
Any help will be greatly appreciated.
Rod
rodelius is offline
post #2 of 4 Old 02-24-2012, 11:35 AM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
A remote with programmable macro and timer capability should do it.
MrBobb is offline
post #3 of 4 Old 02-26-2012, 01:19 AM - Thread Starter
rodelius's Avatar
Thanks for your reply. Are there inexpensive remotes able to do that?
rodelius is offline
post #4 of 4 Old 02-26-2012, 10:42 AM
topr's Avatar
A remote will have to remain within RF/IR distance. The easiest and cheapest may be an inexspensive portable dvd/ USB player you can tuck behind the display and just run it on repeat...other than that with rs-232 you are getting into control systems.
edit: with the portable player you could use a power sensing power strip that would allow the dvd/usb player to power on and off with the display.
topr is offline
Reply LCD Flat Panel Displays
