I need some help picking out a LED LCD for my mother - AVS Forum | Home Theater Discussions And Reviews
Old 02-25-2012, 06:53 PM - Thread Starter
Replacement's Avatar
So my mom is looking getting a new tv. Looking for around 50" w/local lighting (not edge lit) I have had good luck with samsung in the past and was hoping on getting her one if it works out. What models have these specs? It doesnt have to be a super nice tv.
"Having a smoking section in a restaurant is like having a peeing section in a pool."
Replacement is offline
Old 02-25-2012, 07:02 PM
8IronBob's Avatar
Quoted: 61 Post(s)
Liked: 24
This one claims to be Dynamic Edge LED with Local Dimming, so I'm not sure how to make heads or tails of this, but it should be good:
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
Living Room: Samsung UN46A750 46" ToC 1080p, Yamaha HTC-6160 AV Receiver, JBL Cinema 480 5.1 Speakers, Magnavox HDD/DVD Recorder, Scientific Atlanta Explorer 8300HD.
Master Bedroom: Sony KDL-55W950B 55" 1080p, Sony HT-XT1 Soundbar, Xbox One, Scientific Atlanta 8300HD
Basement: Toshiba 32TL515U 32" 1080p 3DTV, PlayStation 3, Xbox 360, Bose Companion II Series 2 2.1 Speakers, Panasonic DMR-EZ28 DVD Recorder
8IronBob is offline
Old 02-26-2012, 09:08 AM
sjetski71's Avatar
That Sony 55HX929 you linked is not edge-lit, it's the better one with a full array backlight + local dimming. It's exactly what the OP was asking for, but i suspect it's a higher end model ($$$) than what the OP was looking for.
From the Sony 55HX929 posted specs:
Sony 55HX929: Intelligent Peak LED backlighting with full-array local dimming for Sony's most precise contrast
On a side note to the OP: i don't think Samsung produces full array + local dimming any longer, pretty sure it's all edge-lit with Samsung now.
sjetski71 is offline
Old 02-26-2012, 09:19 AM
AMartin56's Avatar
Quoted: 995 Post(s)
Liked: 400
I love my mom and I'm sure you love yours, but I've never met a mom that would notice the difference with full array. I think Sony did some really nice things with the local dimming on the edge lit NX720 so something like that might end up being a better value.
Home Theater: JVC RS 420, Yamaha RX-V673, NHT Super Ones/Zeroes w/Ten Sub,
Sony BDP-S5500, Darbee Darblet and Monoprice 130 inch 2.35:1 White Material Screen
Living room: Sony 60NX720, VIZIO SB4051-C0 Other: Samsung 51F8500
Displays calibrated with HCFR, i1DisplayPro, and Colormunki Photo.
AMartin56 is online now
Old 03-09-2012, 01:20 PM - Thread Starter
I guess that local dimming would not be necessary, maybe she doesn't even need a LED one.
Are there any LCD's in the $1k range that are from a reputable brand like Samsung?
Old 03-09-2012, 03:04 PM
AMartin56's Avatar
Quoted: 995 Post(s)
Liked: 400
You can get a Sony NX720 in the $1k range if 46 inches isn't too small (you mentioned 50 in your original post). Edge lit but I think the local dimming is very effective (you should be able to get one with little to no clouding or flashlighting) and the monolithic design is really nice IMO. Also comes in a 55 if you are willing to stretch your budget a bit.
