Deciding between a plasma tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-27-2012, 07:48 AM - Thread Starter
Mike1527's Avatar
Hey guys,
Im in the market for a plasma (I do a lot of gaming/movies) but I'd be fine with an led/lcd as long as it has higher hZ. Was looking into panasonic plasmas (because the deals right now are insane) I know it's a little difficult to grab hands on one so I'm either leaning towards the sony hx729 or the nx729, either samsungs 7000/8000 series plasmas (which I'm unsure of the differences. Any other ideas for a good plasma (that might be in stock during this time) would be awesome . The smaller the size (40-51) the better because this is moving to a bedroom and in going to be wall mounted. Any suggestions would be great!
Mike1527 is offline
post #2 of 3 Old 02-27-2012, 08:26 AM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
Did you post this in the plasma forum?
BoilerJim is offline
post #3 of 3 Old 02-27-2012, 08:54 AM - Thread Starter
Mike1527's Avatar
It has to do with both, but i didn't notice it until you mentioned it! my fault i posted it on here.
Mike1527 is offline
Reply LCD Flat Panel Displays
