Official Sharp AQUOS LC-80LE844U Owners thread - Page 123 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #3661 of 3673 Old 03-27-2016, 07:47 PM
shpitz's Avatar
Quoted: 70 Post(s)
Liked: 57
Does anyone have any idea what type/size screws are used for the base?
I had the tv mounted in my house, but not i've moved and renting, and can't hang it.
I have the base/stand, but no idea where the screws are (if I ever had them...).
shpitz is offline
post #3662 of 3673 Old 03-28-2016, 04:50 AM
rjruby's Avatar
Quoted: 24 Post(s)
Liked: 26
I don't know the screw sizes but according to the service manual, the part number for the set of screws for the stand is CSAKKA011WJ01.
You can buy them at www.partstore.com and www.encompassparts.com
shpitz likes this.
rjruby is online now
post #3663 of 3673 Old 03-28-2016, 09:50 AM
shpitz's Avatar
Quoted: 70 Post(s)
Liked: 57
Thanks, yeah, found that part # yesterday while googling for an hour. Called Sharp they were clueless.
I'll wait to see maybe I was smart enough to thread the screws to the TV before I hung it years ago. If not, I'll have to purchase them.
shpitz is offline
post #3664 of 3673 Old 03-29-2016, 02:46 AM
Liked: 0
I have a problem, hope someone can help. My TV overnight began flickering on and off with the chevron light flashing. I disconnected all the hdmi cables did a reset (thanks to google) and the TV turned back on, but now if I plug in an hdmi cable to some of the hdmi outlets the TV stays on and can't turn it off until I unplug the hdmi cable. Can anyone help?
ebzbldr is offline
post #3665 of 3673 Old 03-29-2016, 08:14 PM
shpitz's Avatar
Quoted: 70 Post(s)
Liked: 57
Can anyone be kind enough to try and measure the base/stand screw? I ordered the set but it'll take a week to get here I was hoping I can find a quick replacement @ HomeDepot or something...
ebzbldr, Is this happening with the same source? same cable? Try different source and different cable.
shpitz is offline
post #3666 of 3673 Old 03-29-2016, 09:38 PM
shpitz's Avatar
Quoted: 70 Post(s)
Liked: 57
Got it!
This guy is a saint!
Missing sharp aquos screws...help?
The screws needed to connect the TV to the base are M5-16mm, went and got them @ HomeDepot, along with some M5 washers.
shpitz is offline
post #3667 of 3673 Old 10-13-2016, 02:55 PM
GMUGNIER's Avatar
Ive had my 844U ever since it was released, been a great tv for us. Does anyone know if there is a ip remote control app that will work properly with this unit?
GMUGNIER is offline
post #3668 of 3673 Old 10-13-2016, 03:00 PM
shpitz's Avatar
Quoted: 70 Post(s)
Liked: 57
ip? you mean IR?
I use an Harmony One, works perfect.
shpitz is offline
post #3669 of 3673 Old 10-13-2016, 03:10 PM
GMUGNIER's Avatar
ip? you mean IR?
No not infra-red - IP remote control that uses an IP address.
GMUGNIER is offline
post #3670 of 3673 Old 10-13-2016, 03:56 PM
shpitz's Avatar
Quoted: 70 Post(s)
Liked: 57
There's this one, but didn't try it...
http://www.myuremote.com/website/net...olled-devices/
shpitz is offline
post #3671 of 3673 Old 10-13-2016, 04:26 PM
shpitz's Avatar
Quoted: 70 Post(s)
Liked: 57
shpitz is offline
post #3672 of 3673 Old 10-16-2016, 01:13 PM
GMUGNIER's Avatar
Thanks for the efforts shpitz, but both of those apps are pay to use, I'm just looking for a basic ip remote app that will allow tv control. I.E. input, power, volume up, etc.. etc..
GMUGNIER is offline
post #3673 of 3673 Old 10-16-2016, 09:09 PM
shpitz's Avatar
Quoted: 70 Post(s)
Liked: 57
Yeah, sorry i can't be more of a help, I've never used such app, only using physical remotes...
shpitz is offline
Reply LCD Flat Panel Displays
Sharp , Sharp Lc80le844u 80 Inch 3d Led Tv , Led Hdtv , Sharp Lc 70le632u Led Hdtv , Sharp Lc70le847u 70 Inch Lcd 70 Class Quattron Led Smart 3d Tv , Sharp Aquos Lc 80le844u 80 Inch Led Hdtv , Sharp Aquos Lc60le847u 60 Inch 1080p 240hz 3d 1080p Led Lcd Tv
