Official Sharp AQUOS LC-60LE847U & LC-70LE847U Owners Thread - Page 90 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #2671 of 2682 Old 03-06-2015, 04:38 PM
Basstrix's Avatar
Quoted: 53 Post(s)
Liked: 27
Originally Posted by greeno View Post
will do when I get home.
Greeno (and anyone else that may have the info I'm looking for), I'd like to compare my set's saturation tracking to others that have calibrated their sets. Have you posted any CIE plots which contain saturation sweeps of primaries and secondaries?
My set produces some very non-linear saturation sweeps. Green, cyan, and magenta are the worst offenders. I'll post up an image when I can get to the computer they're on.
If anyone's aware of how to eliminate or minimize this, I'm all ears (or eyes, rather).
Vizio M652i-B2....................HCFR 3.3.1
Vizio E600i-B3.....................i1 Display Pro
Sharp LC-70C8470U............ControlCAL Elite X5 Edition v2
Onkyo TX-SR606.................AVSHD-709
PS-3
Homegrown HTPC
Basstrix is offline
post #2672 of 2682 Old 03-06-2015, 05:26 PM
greeno's Avatar
Liked: 25
no i've not measured saturation sweeps. is that on a standard test disc, or are you using one of the specialty ones?
greeno is offline
post #2673 of 2682 Old 03-07-2015, 09:54 AM
Basstrix's Avatar
Quoted: 53 Post(s)
Liked: 27
I'm using the built in pattern generator in HCFR but the AVSHD709 disk has them for 0, 25, 50, and 100%. The advantage of the built in generator is that you can set 8 or 10 points along each axis and get a good image of saturation tracking.
PS-3
Homegrown HTPC
Basstrix is offline
post #2674 of 2682 Old 03-07-2015, 11:20 AM
Basstrix's Avatar
Quoted: 53 Post(s)
Liked: 27
Here are a couple of examples showing the issue with saturation tracking. The first image illustrates the non-linear sat-tracking when a calibration based on accurate primary/secondary points. Clearly, the pri/sec points are not particularly accurate, but the result would be much the same if they were dialed in. I've marked the Color Check points and their respective targets to show how far off these points are due to the tracking issue.
The second image is my best attempt, thus far, to calibrate based on lowest average dE on Color Check patterns. As is evident, green, cyan, and magenta are the worst offenders. Magenta is manageable, green causes some undesirable errors, but cyan results in huge errors.
I would like to see the results of what others have achieved in terms of saturation tracking and color check accuracy. If anyone has any tips on how to correct this, I'd very much appreciate it.
This cal was done with standard gamut...my next step is to use expanded gamut.
ID:	588922   Click image for larger version
PS-3
Homegrown HTPC
Basstrix is offline
post #2675 of 2682 Old 03-07-2015, 11:38 AM
Basstrix's Avatar
Quoted: 53 Post(s)
Liked: 27
For comparison, here are a couple of caps from 2 different Vizio models. While these have much better spatial (x-y) tracking, the distribution still lacks linearity. In my limited experience, spatial tracking errors are much more difficult to compensate for compared to distribution errors.
ID:	588970   Click image for larger version
PS-3
Homegrown HTPC
Basstrix is offline
post #2676 of 2682 Old 07-31-2015, 08:50 PM
nettad's Avatar
Error Codes
My beloved 3 yr old lc60c847ou shut off today and will not turn back on... I am getting one fast and 3 long blinks on the front power light....any ideas on what the codes might be? I am thinking power supply (which don't seem to be readily available) or possibly main board. I have tried all the reset tricks I know as far as holding the certain buttons down while powering up with no success. Thanks.
nettad is offline
post #2677 of 2682 Old 07-31-2015, 10:38 PM
Quoted: 16 Post(s)
Liked: 0
Unhappy
My Pioneer 42 inch model(2006) having same problem .
Tv can't open anymore. just blue light keep blinks on the power on-off section.
I try to open many way, but,no success.
Is my tv Dead ?
any advice please
ps:
sorry for the differ brand message .
reflections_ is offline
post #2678 of 2682 Old 10-31-2015, 11:14 PM
Thrill Killer's Avatar
Question Need TV Stand Help
I have a Sharp LC-60LE847U. And a Z-Line Madrid Flat Panel TV Stand (ZLN #ZL541-44MU ). I still have all of the original Hardware that came with the tv stand.
I want to mount my tv to the Hanging Bracket. Looking in the LC-60 manual, and the Sharp web sight. The only info I can find as far as which screw size/length to use. Are the screw size for Sharps own OEM Mounting Bracket. I have 4 each of M4, M5, M6, M8 15mm length screws. And 4 each of M4, M5, M6, M8 30mm length screws. Plus the associated Z-Line hardware. Washers, Spacers, Brackets, etc.
If anyone has done this with their LC-60LE tv, please let me know. I've tried YouTube and Google. I find general info. But nothing specific as to my situation.
Thank You,
TV: Sharp Aquos LC-60LE847U
Pre-Amp: Marantz Pre-Pro AV7702
Amp: Emotiva XPA-3
Speakers: L/R Martin Logan Motion 40 (1st Gen). C/ Martin Logan Motion 8
Cables: Blue Jeans - 5T00UP w/Locking Bananas L/C/R, Blue Jeans - Belden 1800F Balanced XLR's
Thrill Killer is offline
post #2679 of 2682 Old 11-01-2015, 10:23 AM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
not sure if you ever looked further at this or maybe it resolved itself. According to the service manual, it is a communication error associated with the main board. You might try reseating cables if the problem still exists.
budwich is offline
post #2680 of 2682 Old 02-25-2016, 07:56 PM
e30cabrio's Avatar
Quoted: 360 Post(s)
Liked: 150
I am really sorry for all the things going on and hope your baby and Wife are well.
This thread has the service manual and lots of info:
http://www.badcaps.net/forum/showthread.php?t=35841
I'd call Sears and act like I think the warranty is valid, see if there is a grace/some extension period.
Good luck!
e30cabrio is online now
post #2681 of 2682 Old 02-26-2016, 11:50 AM
e30cabrio's Avatar
Quoted: 360 Post(s)
Liked: 150
I had a 60before this 70 that needed a power board. The guy had a kind of huge bath mat he put on my dining room table. It has a bunch of small screws but the back comes right off. I really would call sears, tell them all that is going on, maybe they will take pity on you. Answer is no if you don't ask.
post #2682 of 2682 Old 02-26-2016, 01:38 PM
e30cabrio's Avatar
Quoted: 360 Post(s)
Liked: 150
The tech laid the set on a mat, on a very stable large table on the screen.
Reply LCD Flat Panel Displays
Sharp , Sharp Aquos Lc60le847u 60 Inch 1080p 240hz 3d 1080p Led Lcd Tv , Led Hdtv , Sharp Lc70le847u 70 Inch 3d Led Tv
