Official LG 47LM6700/55LM6700 "Passive 3D" Owners Thread - 2012 - Page 72 - AVS Forum | Home Theater Discussions And Reviews
post #2131 of 2149 Old 04-30-2014, 05:57 PM
dysqo's Avatar
I have been having issues where my tv will not remember my wifi network. I have to re-enter password after ever power cycle? Is there a way to get it to remember? I have looked everywhere and don't see anything that will help. Thanks.
dysqo is offline
post #2132 of 2149 Old 05-04-2014, 07:10 AM
lamplighter's Avatar
New LG update received today..6.04.03,,anyone know whats in it??
lamplighter is offline
post #2133 of 2149 Old 05-04-2014, 08:56 AM
Laughin9M4N's Avatar
Hello Lamp, AVS,
I just did this update without thinking (usually I wait a lonng time), they asked for an agreement (I couldn't say no) to their new terms and conditions. I skimmed through it and one of the things that pops out to me is they say if you agree they can gather data on what you are watching ( medialink, fileshares, TV, etc). I was looking for an online version of the terms but it is not on LG's site. There is also a liveplus setting (feature to add overlay ontop of what your watching) in the options menu I am not sure if it is new with this update.
I think this is related to what a blogger (forgot the site) found about viewing data sent over to lg un-encrypted. Is there any way to downgrade or block lg from viewing my data, without blocking netflix and youtube? For now I have turned off updates, which I should have done earlier.
Laughin9M4N is offline
post #2134 of 2149 Old 05-04-2014, 04:04 PM
Leonheart's Avatar
Quoted: 86 Post(s)
Liked: 25
Originally Posted by Laughin9M4N View Post
Hello Lamp, AVS,
can I just uncheck the legal documents?
55EG9100
PS4
Leonheart is offline
post #2135 of 2149 Old 05-09-2014, 06:39 AM
braub's Avatar
I got the same 06.04.03 update for my 47LS5700 and am experiencing the same wifi issue.  I have also lost my Applications (Netflix, YouTube, etc.)  They are there on the panel, but selecting them displays a blank screen, or a "service not available" message.
braub is offline
post #2136 of 2149 Old 05-10-2014, 08:21 PM
marshals's Avatar
any idea how I can get the Web OS software I see on the new 2014 lg tv's on the 47lm6700 or any home-brew software OS for that matter? dosent seem like 06.04.03 will get to the Web OS type.
marshals is offline
post #2137 of 2149 Old 06-14-2014, 04:14 PM
bronxborn70's Avatar
Liked: 0
I still haven't installed this 243 meg update on my 47LM6700 as of today.
Just wondering if the consensus has installed it on theirs, and is there anything in it worth the update.
bronxborn70 is offline
post #2138 of 2149 Old 09-18-2014, 11:12 PM
Leonheart's Avatar
Quoted: 86 Post(s)
Liked: 25
Has anyone here has their CNET settings tweaked for 2d and 3d? or can you share the best picture settings? Thanks.
post #2139 of 2149 Old 10-27-2014, 11:24 AM
Liked: 0
Unhappy LG 47LM6700 issues
Hi,
I am having some issues with my LG 47LM6700 for some time.
1. TV input selection window
I get TV input selection window which does not go off. Does not matter what I press the window comes back. Can not do anything else with the remote. Basically TV doesn't respond to remote and goes into loop when I try to select something.
2. Auto turn on
Earlier it used to turn on automatically after some time. Now I can't turn off using remote and even after turning off using power supply it turns on.
I did power cycle as suggested by LG customer service guy but that did not help.
Has anybody seen this? Any help is appreciated.
Kamlesh Sangani is offline
post #2140 of 2149 Old 12-21-2014, 12:11 AM
FreydNot's Avatar
I just picked up a used 55LM6400 (which I understand is essentially a 55LM6700 but branded for Costco / Sams Club).
I'd like to do a factory reset so I can start from the defaults, but there is a pin code set. The seller didn't know the pin code (he spent 15 minutes trying different codes).
So, what can I do to clear the code or fully reset the TV? I've tried 0000 and 7777 with no luck.
Is there some kind of procedure to reset the TV like holding down some buttons during power up? I searched but couldn't find anything that works on this model.
FreydNot is offline
post #2141 of 2149 Old 12-22-2014, 01:02 AM
FreydNot's Avatar
Replying to myself with the solution. I was able to use the Smart IR Remote app with my HTC One M8 smartphone to create a service remote (new remote, tv, LG, Remocon). I was then able to use the INSTOP V2 button to initiate a factory reset. I had to use the code 0413 but I understand 0000 should work if the first one doesn't.
You can also use the INSTART button to get into the service menus. Good stuff.
FreydNot is offline
post #2142 of 2149 Old 02-05-2015, 07:21 PM
Choptop32's Avatar
Quick question... I'm digging in the settings of my 6700 and I see the local dimming setting, but its greyed out. Is there some combo of settings that can/cant be on to allow using this feature? I've tried to turn it on in both ISF and Cinema set ups, but so far no joy.
Choptop32 is offline
post #2143 of 2149 Old 03-16-2015, 02:50 PM
Leonheart's Avatar
Quoted: 86 Post(s)
Liked: 25
I want to enable the THX settings.................
post #2144 of 2149 Old 07-23-2015, 02:58 PM
Leonheart's Avatar
Quoted: 86 Post(s)
Liked: 25
Anyone has the Which magazine's settings? the lw550 Which magazine test looks great a guy posted them
post #2145 of 2149 Old 07-26-2015, 07:50 PM
Dellamorte13's Avatar
Hello everyone I have a question I hope someone can answer because I'm pulling out my hair to find a solution.
I have the LG 47LM6700 and about a week go I noticed when watching a Blu Ray in 2:35:1 there was a transparent grayish line above the bottom black bar that went from left to right. It's on Netflix and basically anything else I watch so I'm assuming it's the TV and not the media played on it. It's two years old so no warranty available and I'm really short on money right now. I'd rather fix this cheaply then buy another TV.
Please help me out. I really have grown to like this TV and I can't watch anything because it's so distracting.
Thank you
Dellamorte13 is offline
post #2146 of 2149 Old 07-30-2015, 06:14 PM
Bump
post #2147 of 2149 Old 02-25-2016, 12:12 AM
Leonheart's Avatar
Quoted: 86 Post(s)
Liked: 25
What do you guys think of these?
Energy Saving: Off Picture Mode: Expert 1 Backlight: 40 Contrast: 81 Brightness: 52 H Sharpness: 10 V Sharpness: 10 Colour: 50 Tint: 0 Expert Control - Dynamic Contrast: Off Super Resolution: Off Colour Gamut: Standard Edge Enhancer: Off Colour Filter: Off Gamma: 1.9 Colour Temperature: Warm Method: 2 points Points: High Red 0 Green 0 Blue -3 Points: Low Red: 0 Green: 0 Blue: -14 Method: 20 Point IRE IRE: 100 Luminance: 130 Red: 26 Green: 0 Blue: 0 IRE: 90 Red: 28 Green i Blue: 0 IRE: 80 Red: 18 Green i Blue: 0 IRE: 10 Red: 1 Green i Blue: -1 Blue: 13 Colour Management: Red Saturation 0 Tint 18 Luminance -4 Green Saturation 1 Tint 11 Luminance -6 Blue Saturation 0 Tint 0 Luminance 3 Cyan Saturation 0 Tint 2 Luminance -9 Magenta Saturation 0 Tint 0 Luminance -7 Yellow Saturation -6 Tint 0 Luminance -1 3D Energy Saving: Off Picture Mode: Expert 1 Backlight: 80 Contrast: 80 Brightness: 51 H Sharpness: 10 V Sharpness: 10 Colour: 50 Tint: 0 Expert Control - Dynamic Contrast: Off Super Resolution: Off Colour Gamut: Standard Edge Enhancer: Off Colour Filter: Off Gamma: 1.9 Colour Temperature: Warm Method: 2 points Points: High Red 0 Green 0 Blue -3 Points: Low Red: 0 Green: 0 Blue: -17 Method: 20 Point IRE IRE: 10 Red: -14 Green: -11 Blue: 2 IRE: 90 Red: 23 Green: 0 Blue: -2 IRE: 100 Luminance: 130 Red: 7 Green: 0 Blue: -20 Colour Management: Red Saturation 0 Tint 0 Luminance -18 Green Saturation 0 Tint 14 Luminance -2 Blue Saturation 0 Tint 0 Luminance 3 Cyan Saturation 0 Tint 0 Luminance -1 Magenta Saturation 0 Tint -2 Luminance -3 Yellow Saturation -11 Tint 0 Luminance -6
post #2148 of 2149 Old 08-23-2016, 07:23 AM
Liked: 0
LG 55LM6700: Annoying "only available in TV input" popup
I keep getting this annoying popup on screen saying "only available in TV input. Do you want to select TV input?".
Most of the time when i try smart remote pointer to click on No, the pointer would blink and won't go to no.
Clicking the physical button will remediate the blinking pointer issue.
Sometimes if i don't do anything popup disappears automatically.
Also sometimes TV will turn on automatically with the pop up.
I have already changed the magic remote with no help.
sanddeepkumar08 is offline
post #2149 of 2149 Old 01-22-2017, 05:34 PM
TimothyB's Avatar
Quoted: 14 Post(s)
Anyone know what nits these displays were? I don't think it was a hot topic back in 2012.
I have a 55LM6700 and curious how this older LCD stacks up against LG OLED. I also have a Panasonic VT25 which is obviously not as bright with the peak brightness limit. I'm imagining the OLED between the two.
TimothyB is offline
Reply LCD Flat Panel Displays
Lg Cinema Screen 47lm6700 47 Inch Cinema 3d 1080p 120 Hz Led Lcd Hdtv With Smart Tv , Lg Cinema Screen 55lm6700 55 Inch Cinema 3d Led Lcd Hdtv , Displays
