New LCD help UN46D6900W vs UN55D6000S - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-29-2012, 04:13 PM - Thread Starter
egartin's Avatar
Looking for an new Tv to replace our Samsung LN46A550.
Purchased the
Samsung UN46D6900W
Samsung - 3D Wi-Fi Ready Blu-ray Player Model: BD-D5500ZA
2 Samsung - 3D Glasses SSG-3050GB/ZA
for $1,270.
Have not picked up the order yet.
Went in the store today and they had an open box UN55D6000S for $999.
What do this is the better Deal. I really do not need 3D or internet.
Or if you can recommend another TV for under $1,300 would be definitely considered or one closer to $1,000 would be great.
egartin is offline
post #2 of 2 Old 02-29-2012, 05:41 PM
sage11x's Avatar
Quoted: 1095 Post(s)
Liked: 1056
The difference between 46" and 55" is substantial. I go with size unless there is an egregious drop in PQ.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
Reply LCD Flat Panel Displays
Samsung Un55d6000 55 Inch 1080p 120hz Led Hdtv Black 2011 Model , Samsung Un55d6000 55 Inch 1080p 120hz Led Hdtv Black
