Help, Sony Bravia KDL65HX729 DEMO mode - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-02-2012, 04:07 PM - Thread Starter
eteller's Avatar
I've got a friend who bought a this TV as a floor model from BB, it's stuck in demo mode and it pops up every 5 minutes. The suspend demo mode option does nothing. Any ideas?
eteller is offline
post #2 of 7 Old 03-02-2012, 04:22 PM
dm145's Avatar
Quoted: 75 Post(s)
Liked: 43
call bb and ask them how/why they didn't take it out of demo mode
or reset to factory setting and choose "home"
dm145 is offline
post #3 of 7 Old 03-02-2012, 04:59 PM - Thread Starter
eteller's Avatar
Think we tried that. When you say 'home' do you mean the 'home' button or home as in house?
eteller is offline
post #4 of 7 Old 03-02-2012, 05:20 PM
HaRd2BeAr's Avatar
Liked: 36
Press home on the remote, scroll to System settings, press enter, then scroll to general set-up, press enter, factory reset select yes.
Not sure if it turns of and back on again or just off, when you turn on you then get the option to select Home or Demo, this is where you can get it out of Demo mode.
Aaron
HaRd2BeAr is offline
post #5 of 7 Old 03-02-2012, 06:36 PM
swolfcg's Avatar
Yep. When these tvs are initially turned on, it has an initial settings you are asked to set. One of the first is: Are you a commercial business or are you using this for your personal use. Your choices are Home or Demo.
It should be an easy fix. It's under Settings>Preferences>Initial Setup, for my NX720.
swolfcg is offline
post #6 of 7 Old 03-03-2012, 09:45 AM
SonyListens's Avatar
Hello eteller,
Good morning! My name is Amanda Maffei and I work for the SonyListens department. If your friend is still having issues with his Television, please have them click this link: www.esupport.sony.com for further assistance. And if you can't find a solution there, please call: 239-768-7547 Hours:
■Mon-Fri 8:00am-12:00am (Midnight) ET
■Sat-Sun 9:00am-8:00pm ET
This will direct them to our customer support. I hope this helps! Thank you! =)
-Amanda Maffei
SonyListens team
SonyListens is offline
post #7 of 7 Old 03-03-2012, 10:41 PM
cyclone1078's Avatar
I finally saw this fix posted on another site after trying for hours to correct the same problem. It's real simple. No remote, no scrolling through settings, just hold the lower HOME button on the side of the TV for about 5 seconds. A message appears on the screen "Demo Off". Done!
Hope this helps.
Ken
cyclone1078 is offline
Reply LCD Flat Panel Displays
Sony Kdl65hx729 240 Hz 65 Inch Class 64 5 Inch Diag Led Hx729 Series Internet Tv
