47lk520 now 46d630 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 03-02-2012, 10:52 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Lg-incredibly excellent on hd sports and anything with bright screens.Reddish color especially on dark screens.not dark enough blacks.cinemazoom makes it fill more screen(cut more bottom than top adjusted).Not good on dark movies and when there is black bars.Super smooth on hd.
Traded for
Samsung-incredible blacks,bit more black crush than lg.looks Better than lg on sd unfortunately no adjustable cinemazoom like lg.Better sound than lg,has equalizer.Got good colors after adjusting although bit of red push in skin tones.looks like my old Sony CRT.Not as Prominent picture as
lg on hd.More stuttering and not as smooth as lg.
Is there a way to adjust the screen position in samsung service mode?
Vic12345 is offline
post #2 of 16 Old 03-02-2012, 11:09 PM
CaTaSTrOphiK's Avatar
Quoted: 14 Post(s)
What are you trying to adjust for the black bars on sd content?
CaTaSTrOphiK is offline
post #3 of 16 Old 03-03-2012, 04:39 AM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
I want the video to fill as much of the screen as possible.
Other thing on lg I didn't really like was the dirty screen effect.Dirty screen more noticable on angle.The samsung has better viewing angles.It's a sq01 panel.
Vic12345 is offline
post #4 of 16 Old 03-03-2012, 10:10 AM
pibb100's Avatar
There should be a way, like the ratio button on the LK520 remote...I can only assume Samsung would have this feature.
Are you saying your D630 has no dirty screen effect?
pibb100 is offline
post #5 of 16 Old 03-03-2012, 11:21 AM
PlasmaPZ80U's Avatar
Quoted: 2315 Post(s)
Liked: 716
read the owner's manual, the picture size function is what you want and some modes of it allow you to set position
no need to access service menu, such a control doesn't even exist there in the first place
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
post #6 of 16 Old 03-03-2012, 02:18 PM
Liked: 716
any vertical banding on that sq01 panel? I had the same panel version on a D550 and it had vertical banding that was present on uniform gray and white screens
it also created a DSE effect of sorts when the camera panned
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #7 of 16 Old 03-03-2012, 02:48 PM
JoshZH's Avatar
My(briefly) D550 also had vertical bands. And both LK450 VAs.
I've also seen Sony EX500(in store) with the exact same vertical banding.
Could it be related to *VA technology ?
JoshZH is offline
post #8 of 16 Old 03-03-2012, 02:51 PM
Liked: 716
could be, the samsung is a S-PVA (I believe)
what type of *VA is the LG?
the sony?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #9 of 16 Old 03-03-2012, 02:52 PM
JoshZH's Avatar
My LGs were A-MVA.
Sony uses Samsung panels, i think.
JoshZH is offline
post #10 of 16 Old 03-03-2012, 02:58 PM
JoshZH's Avatar
JoshZH is offline
post #11 of 16 Old 03-03-2012, 03:01 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
On lg I used cinema zoom(which let you zoom it bigger AND you could move it up and down which I did so the TOP of the picture is NOT as cut off).
Lg was ips.Sammy does fade lighter softer when off angle(Sammy),but its better than lg.If there is dirty screen it's not as bad.
Sammy The zoom1 and 2 just stretch it up and down,which make people 10 ft tall.
I haven't noticed any vertical banding,but have some little sparkling white dots on some dark scenes.(think that is not normal).The jittery screen I'm not liking.i don't remember the lg doing it but I only owned it 1 month.
Vic12345 is offline
post #12 of 16 Old 03-04-2012, 04:47 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Could be wrong but the Sam might be a bit clearer on NON moving image,but a moving image like a hockey game the lg is smoother and clearer at least on he channels.
Vic12345 is offline
post #13 of 16 Old 03-04-2012, 07:17 PM
pibb100's Avatar
Smoother if you can live with the DSE
pibb100 is offline
post #14 of 16 Old 03-05-2012, 04:59 AM
John4721's Avatar
As for the black crush, you might be able to reduce that by making sure the "black tone" option is set to off.
John4721 is offline
post #15 of 16 Old 03-05-2012, 03:57 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Vic12345 is offline
post #16 of 16 Old 03-08-2012, 01:16 AM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Not sure if there is something broke on my Sammy,as the lg is a lot clearer on hd,but Sammy better on sd).
an amazing tv with below average black level(lk520) vs a very good solid tv with a great black level(d630).Of course after properly calibrated.
Vic12345 is offline
Reply LCD Flat Panel Displays
