Official Samsung UNXXEH5000/UNXXEH5050 Owner's Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #271 of 279 Old 08-02-2014, 06:14 PM
Liked: 0
[QiUOTE=rcd765;22656032]I just purchased the UN50EH5000 for $699 during BF sale and was a little skeptical about it since I already own a Panasonic Plasma that I am very happy with (it has deep blacks and no motion blur, etc.). I am very pleased to report that the picture quality is great and I don't see any motion blur/lag in sports or fast action BUT that is only after I changed the default picture setup!
Since the standard mode (default) is really bad, you have to read this thread and get some decent picture settings. The trick is to turn OFF the LED motion plus and the Motion Lighting, and turn down sharpness. I don't know why Samsung would provide default options that actually degrade the picture (since they make motion flicker). TURN THEM OFF. Most people would probably just upgrade since they don't read forums BUT if you adjust the settings I think you can have the picture quality of a much more expensive panel.
I ended up with a "CH01" panel and quality seems good but then I haven't seen a "TS01" panel.[/QUOTE] I purchased the 32 version open box 200$ must say can't seem to get the picture where I want it been trying for a week
packaday is offline
post #272 of 279 Old 08-02-2014, 06:18 PM
Liked: 0
Purchased the base model 32 inch for 200$ at bb open box love hate thing going on can't seem to get it where I want it been trying for a week
packaday is offline
post #273 of 279 Old 08-04-2014, 11:25 AM
Liked: 0
UN46EH500F Screen random goes black/turns off - Fix?
Hiya,
I bought a 46" Samsung HDTV (UN46EH500F) about 2 weeks ago and I was really satisfied about how great it is for the price I paid. But about 1 weeks ago while playing on my Playstation 3, I paused the game, went to get a drink, came back and the screen was black, as if it turned itself off. I turned it back on and everything was fine. A few days after I was playing Xbox 360 (different console this time) for about 3 hours straight and while playing GTA5 the screen turned itself off again! Actually it wasn't really off, the screen went black because when I press the "Power ON" button on my remote, it would turn it off and I had to press the "ON" button a 2nd time to turn it back on! Then the same thing happened again a few days ago while playing PS3, I was playing Killzone 3 and the screen went black again in the middle of a 1-2 hour game! This is when I started to panic... for a few seconds.
You see, I had overheating issues with my PS3 slim and a 24" 3D Sony TV over a year ago. My PS3 would get so hot and occasionally crash after several hours of gaming! I read on a Sony support forum that if I plugged the power cord with the white text facing upwards into my PS3 (http://i57.tinypic.com/33w2uls.jpg), the positive and negatives would be connected correctly and it would resolve the issue. IT DID!!!!!!! Ever since I started plugging the power cord into my PS3 with the white text on the cable facing upwards, my PS3 slim isn't burning hot anymore and it hasn't crashed since!!! I did the same thing with my 24" 3D Sony TV by connecting the power cord with the white text facing up and it doesn't feel burning to the touch at all!
So guess what I did with my UN46EH500F. I plugged the power cord the other way!
Before:
http://i57.tinypic.com/2e2mj38.jpg
After:
http://i60.tinypic.com/2zyhipw.jpg
It's been about 3 days now, I've been forcing myself to play long sessions of games and watching 2 to 3 hours of Netflix videos in a row and so far the TV didn't get any black screen issues! Also I don't know if it's just me, but I felt the back of the TV and it doesn't feel as hot anymore!
Could it be that plugging the power cord in your TV the wrong way could cause overheating? It did with my PS3 and 24" 3D TV! So maybe it's the same thing with these Samsung HDTV's!
If any of you are having overheating issues or your Samsung TV randomly shuts itself off, can you give this trick a try to see if it fixes the problem because I really want to know if this fixes the issue or not! Because if it does, someone needs to smack Samsung on the back of the head for not being more careful about this kinda thing! Plugging the power cable the wrong way on my PS3 nearly broke it! I don't want to repeat the same mistake on my $700 TV.
j0hn4 is offline
post #274 of 279 Old 08-04-2014, 03:29 PM
Liked: 0
Originally Posted by Beeper View Post
Quote:Originally Posted by Daredevil_pt
And what about blurring and smearing that some users reported??
I wasn't using it for gaming, so I didn't have any issues with smearing.
It is a 60Hz refresh rate (sample and hold) frame, so it will smear just by quickly scrolling the screen on a PC. Any 60Hz LCD display will.
I brought the base model 32 5000 can't seem to set it the way I want got a good deal 200$ at bb open box faces look bad real dark scenes lose detail my first HD TV using over the air . please help
packaday is offline
post #275 of 279 Old 01-08-2015, 07:29 AM
Liked: 0
Hello,
I have the Samsung Series 5 5000 (hopefully un32eh5000.. that is what the TV showed somewhere in the menu or somewhere). So I downloaded the firmware upgrade from Samsung website (samsung com/us/support/owners/product/UN32EH5000FXZA).
I flashed the upgrade. It asked if I want to upgrade from version 1110 to 1024.
I accepted it anyways.
Now when it restarted, the AV Source picture is grainy and shifted to the downside.
It said the main board has been changed set the - type, local set, front color options.
The picture is fine when using the USB to play media.
I tried the factory reset from service menu. It didn't work.
Any help would be appreciated. If possible please link to the correct firmware files to be flashed.
anoops is offline
post #276 of 279 Old 01-08-2015, 11:33 AM
Liked: 0
Originally Posted by anoops View Post
Hello,
going from 1110 to 1024 sounds like a downgrade no? i mean i would think a newer firmware would have a higher number...now youve got me worried because my un46eh5000 is supposed to arrive today and i just downloaded the 1024 update to install when it gets here...
ToshFan is offline
post #277 of 279 Old 01-09-2015, 04:52 AM
Liked: 0
I know, I did it anyways because the update I was installing was released after I had bought the TV. So I assumed it would be an upgrade.
Even tried the EEPROM reset from the advanced menu. Still no luck.
Also the HDMI Ports are not working now.
anoops is offline
post #278 of 279 Old 01-19-2015, 10:52 AM
thomastern's Avatar
Liked: 0
factory reset
how do i do factory reset
thomastern is offline
post #279 of 279 Old 03-19-2015, 06:22 PM
Lindahl's Avatar
Quoted: 24 Post(s)
Is the only difference between the H5203 and the EH5000 the WiFi and Smart features?
Lindahl is offline
Reply LCD Flat Panel Displays
Samsung Ln46a750 46 Inch 1080p Dlna Lcd Hdtv With Red Touch Of Color , Samsung Un46eh5000 Led Hdtv , Samsung 40 Inch Lcd Hdtv Ln40a750 , Samsung Un40eh6000 40 Inch Led Hdtv , Xbox 360 250gb Console With Kinect
