Black consistency in LG 55LW5700 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-08-2012, 11:58 PM - Thread Starter
thefarmdog's Avatar
I recently upgraded from an older CFL-lit LCD to the LG 55LW5700 (LED edge lit). Once I calibrated it, the picture looks amazing in bright scenes. However, in any extra dark scene, or if I plug in my PC and project an all-black screen, it's clear that the black level is not consistent. If I'm facing the tv head on (or at any angle really), it's clear the upper left corner is brighter than the rest (about a 4 by 6 inch triangle area). The far right side's edge is also a bit lighter black than the rest of the screen. I only notice it in dark scenes though, so it's not severe (and still better than my past CFL LCD).
Is this kind of black consistency expected in LED LCDs? Or should I think about trying out another one to see if it's just this set? Thanks!
thefarmdog is offline
post #2 of 10 Old 03-09-2012, 08:15 AM
aod
aod's Avatar
The 55LW5700 does not have local dimming, the 55LW5600 does. There is a way to enable it through the service menu, but do it at your own risk. That is why you are seeing the fluctuation. To a point, it is going to be that way with all edge lit tv's. Are you able to take it back and get a 55LW5600?
aod is offline
post #3 of 10 Old 03-30-2012, 01:51 AM
Felipe Stalvey's Avatar
I was just at Lowes and I saw some Sylvania Led light bulbs that were about 20 bucks with a color temp around 3000K according to the box (I couldn't find a link online). I use compact flourecents for home lighting right now, but I wouldn't mind switching to LED if the "beam" and CRI are ok. Whats the best led bulb? What about the Cree bulb that was announced in January? Any information is appreciated, I'm a newb with flashlights and a bigger newb in this area. Connector / Power Wire LED Controllers LED Power Supplies
Felipe Stalvey is offline
post #4 of 10 Old 05-20-2012, 03:50 PM
wprager's Avatar
How can you have local dimming with an edge-lit backlight? Local dimming can only happen if you have grid lighting, no? What am I missing?
I'm now looking at a Dell web page describing the 5700 and it specifically mentions "local dimming". Does it or doesn't it?
wprager is offline
post #5 of 10 Old 05-20-2012, 04:42 PM
PlasmaPZ80U's Avatar
Quoted: 1962 Post(s)
Liked: 559
Unfortunately, this happens all too often... not much you can do other than buy a different TV or try another unit of the same model.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #6 of 10 Old 05-20-2012, 04:45 PM
Liked: 559
you can, but it's not as effective as with a full-array LED backlight since you have much fewer dimming zones
post #7 of 10 Old 05-20-2012, 04:46 PM
Liked: 559
this post belongs elsewhere in the forum
post #8 of 10 Old 05-21-2012, 12:04 PM
aod
aod's Avatar
The 55LW5600 has LED plus local dimming with 16 zones. Check out the official thread. 5700 doesn't have LED plus but owners stated they have enabled via service menus. I don't have a 5700 so I can't attest to this. There is also an official thread for the 5700 sets also. You may be getting full array local dimming confused with the LED plus local dimming. Dell is most certainly wrong if they advertise the 5700 as local dimming. The 55LW5600 is a fantastic bargain and great buy.
aod is offline
post #9 of 10 Old 06-19-2012, 07:15 PM
wprager's Avatar
Actually I had read somewhere that the LW5700 was sold with different features enabled in some markets. So it's possible that the ones sold in Canada have local dimming available without tweaking. I guess I'll find out first hand in a couple of days (order is listed as "shipped", although there's no tracking number yet).
wprager is offline
post #10 of 10 Old 06-20-2012, 03:32 AM
Tapioca Cold's Avatar
Sir/Madame, to answer your question, yes this "kind of black consistency" IS expected in ALL edge-lit LED LCD TV's. Even if they contain features like LED PLus which will dim certain areas of the screen (from the edge). But do not be fooled and do not let anyone fool you into thinking the 5600 or the 5700 have local dimming. They don't.
Now people in this thread are confused. "Does it have local dimming?" No.
This is what you see with local dimming!
337
Tapioca Cold is offline
Reply LCD Flat Panel Displays
