Tilting TV Downward using Stand - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-09-2012, 09:40 AM - Thread Starter
Spleen's Avatar
Quoted: 152 Post(s)
Liked: 66
My 32" Samsung bedroom TV sits up high on top of a tall stereo cabinet and I want to angle/tilt the TV downward a bit for a more centered viewing position when watching TV in bed.
I placed a 1/2" H x 1.5" W x 17" L piece of wood under only the rear rubber feet of the TV's built-in plexiglass stand. The stand's non-elevated front rubber feet have so far prevented the TV from sliding forward and off the 1/2" high wood block.
The TV is not angled so much that it should tip over; there is no place to install a TV-holder kit. A wall mount kit is not an option.
Does anyone foresee any long-term problem with this set up? Could this eventually place too much stress on the stand or the plastic bracket (guide stand) that connects the TV's plexiglass stand to the back of the TV?
It seems to me this setup should be okay but I am curious if anyone here has experienced a similar setup.
Spleen is offline
post #2 of 9 Old 03-09-2012, 10:39 AM
Otto Pylot's Avatar
Quoted: 1668 Post(s)
Liked: 1042
Earthquake country? Experience has shown me that it doesn't take much to move things Is there anyway you could attach a cable tie or something similar to the base and then attach that to something more solid like the wall behind it (to a stud or mollie)?
Otto Pylot is offline
post #3 of 9 Old 03-09-2012, 10:50 AM
Sgooter's Avatar
Quoted: 130 Post(s)
Liked: 103
I don't think you have any problem with the way you've tilted this TV. I essentially have done the same thing with a 50lb 47" TV atop a chest of drawers in my bedroom, and it's very stable just sitting there.
As for not having a place for a TV holder kit, I certainly don't know your physical lay out , but there are likely to be 1-4 VESA-standard screw holes in the back of your TV panel that could be used to improvise a way to secure the TV to the back of your cabinet, if it's really a concern.
Otto Pylot's above comments are indeed worth noting, depending on where you're located.
Please enter password to view this signature.
Sgooter is offline
post #4 of 9 Old 03-09-2012, 10:58 AM - Thread Starter
Spleen's Avatar
Quoted: 152 Post(s)
Liked: 66
The TV also sits atop a table-top swivel stand which precludes me from tying it down to anything. I swivel the TV up to 90+ degrees side-to-side everyday depending on which part of the room I am in. Maybe I could figure out a way to tie it down to the swivel stand.
Earthquakes are not an issue in this part of the country.
Spleen is offline
post #5 of 9 Old 03-09-2012, 11:13 AM
wxman's Avatar
Quoted: 4526 Post(s)
Liked: 3114
You will be fine. My 70 inch tv is sitting on a 27 inch high table which is sitting too high when seated such that I lose seeing detail at top of LED TV. So I put a 1/2 inch wedge under the back of the stand of tv so that top of screen is actually tilted 2 inches closer than bottom of screen. Very stable.
LG 65E6P FW 05.30.02
LG 65EF9500
wxman is offline
post #6 of 9 Old 03-09-2012, 11:18 AM - Thread Starter
Spleen's Avatar
Quoted: 152 Post(s)
Liked: 66
If it is stable with your large TV then I should fine.
I am curious, where did you get your 1/2 inch wedge or did you make it? I am just using a flat 1/2" board.
Spleen is offline
post #7 of 9 Old 03-09-2012, 11:30 AM
wxman's Avatar
Liked: 3114
I had some old baseboard left over and is a perfect 1/2 inch wide high wedge that i cut to the size of the base length. The tv's weight keeps it very stable
LG 65EF9500
wxman is offline
post #8 of 9 Old 03-09-2012, 11:34 AM - Thread Starter
Spleen's Avatar
Quoted: 152 Post(s)
Liked: 66
A wedge shape piece might be better than my flat board. That gives me a good excuse to visit Home Depot.
Spleen is offline
post #9 of 9 Old 03-09-2012, 12:37 PM
Otto Pylot's Avatar
Liked: 1042
That's good! Seems that you'll be fine then according to some of the responses.
Reply LCD Flat Panel Displays
