Official Samsung UNxxES8000 Owner's Thread - Page 223 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
post #6661 of 16399 Old 11-12-2012, 07:19 PM
turboman123's Avatar
Quoted: 24 Post(s)
Liked: 25
Originally Posted by kleno View Post
OK so I have a problem with my 40es8000,
I have connected my laptop with a HDMI cable to HDMI/DVI port
when I choose 1920x1080 60Hz or 59Hz I get artifacts like screen tearing on desktop and video playback
when I set the monitor (TV) resolution on 1600x900 60Hz or 1280x720 60Hz for example it runs perfectly normal
but that is not the solution since I sholud be able to run on 1080p 60 Hz without any problem
(got the same laptop hooked to a 32pfl7803d on 1080p 60Hz without any artifacts or issues)
the laptop is HP envy with Win7 x64 and HD5650 graphics card with latest Ati drivers
(playing with source/PC, source-DVI/PC and other mods did nothing, problem remains)
I would like to set the native resolution when hooking up my laptop and use it for video playback and some gaming
seems to me like a graphics driver issue but not sure...
Anyone ?
hello, recently I also had a problem connecting my laptop to a 55ES8000. I am using it for picture calibration.
First, everything worked OK when connected to HDMI1/DVI. Then, after a few days, things were different. I saw that I did not have the same picture modes anymore on the Samsung. Originally I had Standard, Movie, Dynamic, Natural, but after things went wrong I only had Standard and Entertainment. I tried playing with the graphics settings of the laptop, but that did not bring a solution.
Then I changed to HDMI3 connection. Problem remained.
Then I renamed the HDMI3 port to blu-ray, and now I got the picture modes I wanted (Standard, Movie etc).
So it seems the Samsung senses the PC and makes some setting, and the setting also depends on how you name the connection.
I am not a PC specialist, but could be worth trying out. Good luck.
turboman123 is offline
post #6662 of 16399 Old 11-12-2012, 08:27 PM
Catt99's Avatar
Originally Posted by gamermwm View Post
Yep me too using optical out from the tv to my Pioneer receiver - 5.1 All the way. I hadn't heard anything about this "smarthub fiasco" but my understanding was that you only get 2.1 when using the HDMI ARC unless the sources are channels that are OTA. Using Optical cables you should be fine
I have a vague memory but am not certain (so take this for what it is worth), but I think it is an HDMI standard limitation and that it only applies to components that are connected to the TV via HDMI so that once passed to the TV, it cannot then be passed again by non-HDMI connectivity. I.e., I think HDMI ARC would work fine -- the limitation, I think, is connecting a component to the TV via HDMI and then trying to get the audio back to an AVR via optical without a direct connection between component & AVR (limited to 2.1 channel audio).
My real world example: I have an older but still quite serviceable Yamaha AVR - but it has no HDMI connections. So my three components go to TV via HDMI, and audio to AVR via direct optical which gets my 5.1 channel audio to the AVR. Except for my older xBox, which doesn't have a seperate S/PDIF out, so xBox -> TV via HDMI, and audio from xBox content via TV -> AVR optical out. But that means I can only get 2.1 channel audio from content on my xBox. An upgraded AVR with HDMI inputs, or a newer xBox, and I could enjoy 5.1 sound from the xBox -- not really worth it to me so I live with 2.1 channel sound from that one component. Which, BTW, made the SmartHub update that included Amazon Instant Video so welcome to me, since now I can get 5.1 channel audio on Amazon video (via SmartHub) whereas before I was limited to 2.1 accessing AIV from the xBox (my Oppo blu-ray player doesn't have and won't get AIV even though it has a ton of other streaming apps available).
I don't subscribe to Netflix or Hulu but I have rented a few videos from VuDu with 5.1 channel audio, and that too feeds to my AVR from the TV optical out when accessing via SmartHub.
I guess if I ever want to set up a media server of some kind I'll bite the bullet and upgrade to a newer AVR with a sufficient number of HDMI inputs.
Catt99 is offline
post #6663 of 16399 Old 11-12-2012, 08:49 PM
EndeaverouX's Avatar
Liked: 27
I dont know bro....I have the ES7500 and no 5.1 sound using smart hub...even the samsung customer rep confirmed it......
he told me that the entire smart hub user interface is only outputing in 2 channels(stereo) both via HDMI or SPDIF/Optical, no difference either way. These are the FACTS... SADLY
Some people think that a stereo signal being upconverted/mixed to Pro Logic II is the same as 5.1 Dolby Digital or 5.1 DTS...It's like night and day. Big Difference....Apples and Oranges... are you 100% positive that u are not getting Pro Logic II conversion instead? thats what I'm getting, not the the crystal clear 5.1 DD/DTS...
EndeaverouX is offline
post #6664 of 16399 Old 11-12-2012, 09:33 PM
kleno's Avatar
that is normal, if you set the hdmi/dvi to pc you only get standard and entertainment, *certain sources only support certain picture modes and options
my problem is different it has to do with the 60 Hz refresh rate (1080p) set on any source combination and always get screen tearing like artifacts, I really hate this
tmx anyway...
Im open to other suggestions:D
kleno is offline
post #6665 of 16399 Old 11-12-2012, 09:40 PM
eagle_2's Avatar
Quoted: 405 Post(s)
Liked: 293
Originally Posted by gtm73 View Post
I didn't realize that you had a lock on making unfounded, unsubstantiated claims. My forward looking speculation is definitely not fact based, I think most anyone here could tell that I wasn't claiming it as fact. Your claim that these panels suffer from greater failure than the industry norm seems equally unsubstantiated, however much less clearly articulated as your opinion.
I can say, with absolute certainty, that demanding a higher level of quality drives increased cost.
This discussion is over on my end. I will not continue moving forward with this line of discussion. It is bringing nothing good to the thread.
eagle_2 is offline
post #6666 of 16399 Old 11-12-2012, 09:46 PM
eagle_2's Avatar
Quoted: 405 Post(s)
Liked: 293
Originally Posted by EndeaverouX View Post
do these samsung smart tvs support 5.1 Dolby Digital over SPDIF/Optical output? or only Stereo Dolby Digital?
The optical out will only output 5.1 when the source is direct from the tv's built-in tuner, and perhaps the built-in media player. If you are receiving a 5.1 signal through the HDMI ports, it will not output 5.1 through its optical out. That's tied into legal reasons, and other companies are also stuck following those rules. The optical output is able to output 5.1 but is unfortunately limited to it's built-in sources only. Everything else gets output as stereo only.
eagle_2 is offline
post #6667 of 16399 Old 11-12-2012, 10:59 PM
prsut's Avatar
Liked: 57
EndeaverouX >
why so huge blue font ?
Panasonic TX-P42GT50E, Oppo 103, Schiit Vali, Denon AHD2000 + Moon Audio Blue Dragon V3, Phonak Audeo 121, Vsonic GR07, Fiio E17, Cowon S9, XLO cables :: CalMAN 5 Enthusiast,Chromapure Standard, i1D3, i1Display 2, TED's Calibration Blu Ray Disc v1.0 & v1.1
prsut is offline
post #6668 of 16399 Old 11-13-2012, 01:09 AM
mgh26's Avatar
Quoted: 45 Post(s)
Liked: 91
Kleno- On the esxx7100 forum, we all just had a 1080P 60FPS only (1080P 24FPS is OK) jitter and screen tearing issue crop up after a firmware update that added SyncPlus as a running in the background application located in the smart hub. The solution was to remove the agreement check mark located in the Licensing area within the application software. Now the application doesn't run and the 1080P 60FPS jitter/screen tearing is GONE. I know the es8000 has a different firmware version but mabye this application issue is industry wide for all Samsung models. Samsung is aware of the problem and is working on a solution. This issue HAS affected several models within the es series Tv's as reported within the es7100 forum. Well I don't know for sure if this is your issue but just thoght I'de mention it. Hope this helps, Mike
mgh26 is offline
post #6669 of 16399 Old 11-13-2012, 01:23 AM
gtm73's Avatar
Is there a way to mark this note for future reference?
HLdan likes this.
gtm73 is offline
post #6670 of 16399 Old 11-13-2012, 02:00 AM
kleno's Avatar
this is good stuff, only thing is I cant find the syncplus app
OK so I went for a drastic mesure and a longshot , did a clean instal of windows 8 on my laptop and that did the trick running 1080p on 60 Hz without any issues
playback even seems to be smoother
kleno is offline
post #6671 of 16399 Old 11-13-2012, 06:53 AM
Bladerunner1959's Avatar
Location: Pittsburgh, PA...Preferably the Virgin Islands....
Quoted: 13 Post(s)
Liked: 67
Flashlighting: Gamma at -1 really minimized this. Maybe after a few months of use it had more effect but the effect is so much less noticeable. I dont know...at -2 I think i lose too much detail in dark material .... Clouding, I cant remember the last time I noticed it. Possibly when first playing with movie mode.
Love for all things Hi-def...Losing count; 200 plus bluray, 500 plus dvd, 30 plus HDdvd and a rapidly growing 50 plus in the cloud.
Bladerunner1959 is offline
post #6672 of 16399 Old 11-13-2012, 09:47 AM
eagle_2's Avatar
Quoted: 405 Post(s)
Liked: 293
Originally Posted by prsut View Post
EndeaverouX >
Probably so his question won't be lost among all the goofy arguments in here lately.
EndeaverouX and Coalminer955 like this.
eagle_2 is offline
post #6673 of 16399 Old 11-13-2012, 09:49 AM
eagle_2's Avatar
Quoted: 405 Post(s)
Liked: 293
I'll just leave this here:
http://www.customerservicescoreboard.com/Samsung
Just for reference. Interesting employee comments. I realize that other companies don't do much better, if any, so I'm not singling Samsung out. The employees comments are really what I found interesting there.
eagle_2 is offline
post #6674 of 16399 Old 11-13-2012, 09:53 AM
Liked: 27
exactly brother....i need answers, not endless debates...lol
post #6675 of 16399 Old 11-13-2012, 09:54 AM
thebignewt's Avatar
Quoted: 289 Post(s)
Liked: 92
Rico, are you basing your conclusion that there is a problem with the 65 on the discussion here or something broader? And as interesting as that would be, the real question is one of relativity. Is the Samsung relatively worse or better than industry norm? Any thoughts on that?
What is the Samsung return ratio? Are "all these" returns 1% of panels or 25%? We keep talking about it here like there is a problem and I just don't know how anyone is coming to that lconclusion in a logical, reasonable, fact base way. From the vehmence and strong commentary here there must be some fairly conclusive evidence behind it....
I've been on a lot of product forums (mostly smartphone, but auto too), and as we all know persons who have problems are overrepresented in forums. Forums also have a lot of fanboys, as well as persons who are new to the product (that would be me). That being said, I always wondered what was up with Blackberry users who returned 3 or 4 phones for "dead pixels" and screen issues. The odds of getting a defective screen 3 times in a row seems very low unless they all came from the same bad batch of phones at a retail store's back room (like bad ice cream out of the same container).
Samsung ES8000 65", Evo Kit installed, Yamaha AVR with Paradigm speakers, iMac, iPad, Apple TV and HTC One phone.
thebignewt is offline
post #6676 of 16399 Old 11-13-2012, 10:40 AM
7011jrs's Avatar
Thanks for clarifying, that is exactly how I understood it to work as well. I don't like it, but at least I know I am not crazy!
7011jrs is offline
post #6677 of 16399 Old 11-13-2012, 11:06 AM
MMakoto's Avatar
Quoted: 37 Post(s)
hi, was anybody able to connect the logitech dinovo mini bluetooth keyboard/mouse with their tv? the tv was able to see it, but just wouldn't connect. any ideas or work around? this keyboard/mouse of mine is currently connected to my old pc via a usb dongle. tia.
MMakoto is offline
post #6678 of 16399 Old 11-13-2012, 12:51 PM
Op's Guy's Avatar
Liked: 34
Going to see how Black Ops 2 looks and plays tonight.
Op's Guy is offline
post #6679 of 16399 Old 11-13-2012, 01:04 PM
prsut's Avatar
Liked: 57
Clouding is most visible with movie + 3D mode...
prsut is offline
post #6680 of 16399 Old 11-13-2012, 01:29 PM
Liked: 27
if they are using the same game engine as black ops 1, it will suck no matter what....threarch blows when compared to Infinity Ward....So dont expect ur ES8000 to do any miracles. you cant turn crap into gold just like that....lol..
post #6681 of 16399 Old 11-13-2012, 04:48 PM
Ricoflashback's Avatar
Quoted: 649 Post(s)
Liked: 349
Today's comment on the HX950 AVS Forum and the status of Sony panel returns/exchanges:
Just thought I would give you guys an update on my XBR 950 saga. After having swapped out a few TV for my bedroom and living room on the 65" 950, of which one was by Sony and this one was good, I called sony today. After asking they replace my living room set for a 4-5" banding in the middle, which I asked the guy in National Customer Relations if he knew what banding was (and he did), he said that Sony would not allow any more replacements of the set. Even if Sony verified the defect. Instead, they would only buy back the tv at purchase price minus taxes. So the short of it is that Sony knows about the banding on the sets and would rather lose a customer rather than own up to the issue and just refund the purchase money.
I can honestly say that I'm surprised by this. Samsung and their quality have never been a surprise, but I had a sony xbr 3 CRT from back in the day that was magnificent. Lasted well over a decade. I knew sony outsourced their panel production, but this is truly sad to see this is what it has come to. Just a heads up to prospective buyers.
I also reached out to sony listens on Facebook. Never got so much as a peep out of them in return. Next sets I buy are going to be difficult to choose with the small selection available on the market. Truly a shame that it's come down to picking the least defective set instead of the one with the most appropriate feature set all in the name of the manufacturer saving a buck.
Buyers be ware when you buy your new set. If you get a winner it's great. But the lottery system and Sony's support should you need assistance are a bad joke at best.
I'm not sure whether this is Sony's new policy or just the response that a Sony rep gave to his buyer, but it's pretty alarming.
If you have a good panel or one you can live with - - enjoy it and I hope you purchased extended warranty for piece of mind. A large purchase of this nature should be fun.
prsut likes this.
Home Theater Setup
Samsung UN65ES8000 LCD/LED & BenQ W1080ST & Vizio M43C1
Pioneer SC65 (Pre-Amp) & Emotive XPA-3, 200 WPC
OPPO 103, Comcast Infinity X1, Darbee Darblet
ALL Paradigm - 7.1 - Studio 60's, V.2 (FL/FR) CC-690, V.5 (C)
ADP 590 V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub
Ricoflashback is offline
post #6682 of 16399 Old 11-13-2012, 09:33 PM
smooth tha boss's Avatar
Quoted: 28 Post(s)
hear about these things at my job everyday
smooth tha boss is offline
post #6683 of 16399 Old 11-13-2012, 10:08 PM
Catt99's Avatar
Posted in your "fiasco" thread but the short story is that I was wrong and it certainly appears that SmartHub apps are outputting only 2 channel sound even when the source is 5.1 channel. Check the other thread for a fuller explanation, but it certainly seems to me that streaming content through SmartHub apps results in downmixing to 2 channel via the audio out jack when there really is no reason to do so (the audio out is clearly able to pass a 5.1 channel signal if the source is the TV's coaxial input).
This strikes me as a serious shortcoming, and really an unforced error on Samsung's part -- there appears to be no legal or standards-based reason to downmix - it looks like a software implementation choice. I've enjoyed a few VuDu streams via my blu-ray player and the kids have watched some free HD movies via Amazon Instant Video -- I had high hopes that with AIV in the SmartHub, I could make better use of the free streaming content and started building out a watchlist, but I'm pretty disappointed that for no good reason I am still stuck with a downmixed 2 channel audio feed from Amazon unless I upgrade my AVR or my xBox, all because of some mystifying choices made by Samsung engineers. Just goofy.
Catt99 is offline
post #6684 of 16399 Old 11-13-2012, 11:31 PM
MMakoto's Avatar
Quoted: 37 Post(s)
SO is it only sammy's smart hub that is outputting 2 channel audio? If so, then I assume their bluray players are the same? How about other manufacturer's? Would their AIV or Netflix app output 5.1? I'm in the market for a new bluray player, and it's sad to have a beautiful picture but no DD 5.1 sound.
MMakoto is offline
post #6685 of 16399 Old 11-14-2012, 06:27 AM
eagle_2's Avatar
Quoted: 405 Post(s)
Liked: 293
Somehow I don't think allowing an average of 6 minutes per call is adequate for expecting an actual resolution of an issue. Again, I'm not suggesting that it's just Samsung. But just because it's the standard level of phone support today doesn't mean it's right. People here should really read that article on arstechnica a few weeks back about technical phone support - it did a great job of pointing out exactly where the blame lies with such poor phone support, and why.
http://arstechnica.com/features/2012/10/what-the-chronicles-of-george-can-teach-us-about-technical-support/
The post above about how Sony hadled that defective panel points out that it's not just Samsung that has these problem panels and lousy support. But again, that doesn't make it okay. I can't count how many big-box stores I've watched close over the last few years in my area - I mean close like bankrupt, gone for good. Circuit City, CompUSA, and Ritz Camera all come to mind as large chains that offered poor support and poor service, and look where they ended up. Best Buy is in serious trouble. Panasonic, Sharp, and Sony are all hurting in their tv division. At this point, the tv landscape is very poor, and I am seriously concerned about what we are all going to be buying for a tv 5 years from now, and where. Too many quality issues, too many unhappy customers, not enough care by companies to make things right, and too many returns. When I think back to the 80s and how many different brands of tv sets you could purchase, and most of them were pretty descent quality - some certainly would provide a better image than others, but it wasn't nearly as common as it is now to get a "bad" set. Now, buying a tv is a gamble, and the odds are stacked against you. And there are very few brands left to choose from.
eagle_2 is offline
post #6686 of 16399 Old 11-14-2012, 06:59 AM
Quoted: 649 Post(s)
Liked: 349
If your Bluray player is connected to a receiver that is capable of processing 5.1, DTS or even 7.1 channels - - you will get the full soundtrack.
Obviously, if you're playing your audio through your TV or a soundbar - - you will not get the full soundtrack and the audio will be matrixed to the highest level your audio supports.
I can confirm that OTA (Antenna Broadcasts) send out a 5.1 signal to my receiver via optical link. I have not streamed anything from the TV (Smart Apps.) since I stream everything through my Sony BDP S-790 Bluray player - - which passes full Dolby Digital and more when I stream from Amazon Prime to my TV via the receiver.
Quick question - - what is your home theater setup?
Home Theater Setup
post #6687 of 16399 Old 11-14-2012, 07:06 AM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
everytime i am watching Netflix from my PS3, my receiver codec is Dolby Digital +.
caloyzki is offline
post #6688 of 16399 Old 11-14-2012, 07:09 AM
7011jrs's Avatar
If your blu ray is connected via HDMI to the TV, and you are using optical out to ANY receiver, it will only transmit 2 channels, and your receiver will then upconvert. You are not getting the full audio.
From everything I have read, the only way to achieve this coming from the TV itself is through the OTA input.
I think Eagle confirmed that as well in an earlier post.
7011jrs is offline
post #6689 of 16399 Old 11-14-2012, 07:21 AM
Quoted: 649 Post(s)
Liked: 349
If you have a receiver, it doesn't make sense to not route your audio to your receiver (audio & video via HDMI to the receiver from your bluray player and then one HDMI from your receiver to your TV). If you have NO HDMI video from your receiver to your TV, then you still can get full audio if you have a Bluray player like the Sony BDP S790 that has two HDMI capability for audio and video.
Again, my preference is to stream through my Bluray player - - it just works better for me and I do not worry about any limitations on the Sammy applications.
And...I just haven't confirmed the two channel via optical to your receiver from the TV (streaming applications) - - if Eagle says so, then that's fine. I just haven't tried it yet but it's more of a moot point for me since I like to stream from my Bluray player.
Home Theater Setup
post #6690 of 16399 Old 11-14-2012, 11:09 AM
Catt99's Avatar
The issue is not earth-shaking, but it is a really unfortunate unforced error on Samsung's part (or they have some reason to limit the capabilities that I can't seem to make out).
Yes, the workaround is to use a streaming app from another component like a blu-ray player, game consle, etc., but for those users who do not have access to one or more streaming services through other components, or don't have the necessary connectivity, the choice is to use the Samsung app and live with two channel audio when there is seemingly no good reason why Samsung would implement it this way. In the end, it just makes the SmartHub less attractive and useful, and consumers will have an incentive to use other components for the same content.
I'd like the convenience of using the SmartHub, and I'd like to not have to upgrade any other home theater components; but as it stands, I cannot get 5.1 channel audio through Amazon Instant Video because of my set-up, and because of Samsung's implementation, I won't use SmartHub for other streaming content like VuDu, etc. because I'll go through a blu-ray player or a game console to get 5.1 channel audio. Again, it's not earth-shattering, but it is mystifying why Samsung would limit the functionality of SmartHub apps this way when there seems to be no good reason to do so.
Catt99 is offline
Reply LCD Flat Panel Displays
color , Displays , firmware , Lcd Hdtv , Samsung , Samsung Un46es8000 Led Hdtv , Samsung Un65es8000 Led Hdtv , UN55ES8000 , un55es8000f
