Official Samsung UNxxES8000 Owner's Thread - Page 511 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
post #15301 of 16401 Old 05-22-2013, 07:26 AM
10k
10k's Avatar
Quoted: 1366 Post(s)
Liked: 1400
Originally Posted by eric3316 View Post
As a prior owner of the 60ST60 and now the es7500, do you know how that contrat ratio's and black levels compare from this TV to the ST60? I know you have the es8000 so it might be different then my 7500 but just curious on these numbers.
My prior TV was a panasonic g20 plasma. The black levels of the es8000 are not good in comparison but that is just a limitation of the LCD technology. Overall contrast is probably comparable though as the LCD can output a much much brighter picture than my plasma ever could. The difference is pretty striking if you watch TV during the day in a room with open windows. Overall I'm happy w/ the es8000 and consider it a worthy upgrade from my prior TV.
10k is online now
post #15302 of 16401 Old 05-22-2013, 11:25 AM
Jestered's Avatar
Liked: 38
Originally Posted by sillycargt4cs View Post
Just picked up a colormunki display new and sealed for £60.00 or $91.00 and look forward to really improving upon a already amazing picture.
10k and jestered prepare for a barrage of questions
I'd suggest reading through the stuff in 10k's links because that will give you a firm starting point. Once you get knee deep in it, which you will, feel free to ask any questions you may have.
sillycargt4cs likes this.
UPDATED: 04/05/2013 - My Colormunki/HCFR calibrated settings for 65" ES8000
LG OLED65E6P * Adcom GFA7000 Amp (FL/FR/C) * Marantz SR6010 AVR (Sur. x4 & FRH/FLH) * Polk RTiA5 (FL/FR) * Polk CSiA5 (C) * Polk FXiA6 (Sur. x4 & FRH/FLH) * SVS PB-1000 (SW) * URC MX-5000 Remote *
Jestered is offline
post #15303 of 16401 Old 05-22-2013, 11:29 AM
Jestered's Avatar
Liked: 38
Originally Posted by Mavinwow View Post
Look what came:
I was planning on being scientific about it, and take readings before/after. I won't have time to do that though for a few days, and not sure I can resist temptation :P
Great! I'm tempted to go ahead and order one now that they've come down in price on Amazon. The one thing I have to know is how far it sticks out the back of the TV. My TV is wall mounted and the back of the TV is less than an inch away from the wall. How far does the evo kit box stick out from the back of the TV?
Jestered is offline
post #15304 of 16401 Old 05-22-2013, 11:52 AM
sillycargt4cs's Avatar
Originally Posted by 10k View Post
Nice, enjoy the ride. I've got some informative links posted in the link in my signature. What size TV do you have? It would be interesting to see what readings you get on your set against those posted by users with meters here.
I have the European 55 ES8000.
not sure how long before posting my results as I will have to borrow a laptop,as HCFR will not work on my macs
sillycargt4cs is offline
post #15305 of 16401 Old 05-22-2013, 01:21 PM
Jestered's Avatar
Liked: 38
There's actually a Mac OS version of HCFR, but it won't let you do live meter readings, which in my opinion is a necessity. Especially when doing the CMS adjustments. I also only have Macs and the Windows version of HCFR works perfectly fine in bootcamp. If you have a Macbook you can simply install the HCFR software in bootcamp and run it that way. That's what I do anyway.
Jestered is offline
post #15306 of 16401 Old 05-22-2013, 02:49 PM
eric3316's Avatar
Quoted: 841 Post(s)
Liked: 959
Every time I am away from my TV I keep questioning if I should go back to an 60ST60. Then when I get home and turn on my es7500 I look at it and say, damn that is a nice picture.
I don't even know why I keep questioning my decision.
eric3316 is offline
post #15307 of 16401 Old 05-22-2013, 03:27 PM
Mavinwow's Avatar
Quoted: 416 Post(s)
Liked: 471
Ill take some pictures for you in a bit, trying to work up the motivation to hook up my meter and run a set of before/after numbers :P
Samsung 55ES8000
Vizio 70 P Series, Calibration settings
CalMAN 5 Novice Walkthrough
Denon X4200, 5.1.4 setup
Mavinwow is offline
post #15308 of 16401 Old 05-22-2013, 03:50 PM
10k
10k's Avatar
Liked: 1400
Doooo eeeet
gamermwm likes this.
10k is online now
post #15309 of 16401 Old 05-22-2013, 04:37 PM
Mavinwow's Avatar
Quoted: 416 Post(s)
Liked: 471
Alright, gonna play with this thing. Here are some pics to get you started. Sticks out a little bit.
Samsung 55ES8000
Mavinwow is offline
post #15310 of 16401 Old 05-22-2013, 05:58 PM
Jestered's Avatar
Liked: 38
Thanks for that! Looking at the pictures I didn't think there would be enough room using my current wall mount and don't have any plans to replace it. I looked up the actual dimensions of the evo kit and it's 0.63 inches deep, so that should fit behind my TV even with my current wall mount. I'm probably going to get one now.
Jestered is offline
post #15311 of 16401 Old 05-22-2013, 06:36 PM
gamermwm's Avatar
Quoted: 83 Post(s)
Liked: 93
There's a least one person on the UK thread who says he is using the F8000 settings with his Evo kit to great results. If that is truly the case then something indeed has changed. Looking forward to your results
What is the meaning of life?
www.iamsecond.com/films
gamermwm is offline
post #15312 of 16401 Old 05-22-2013, 06:44 PM
Mavinwow's Avatar
Quoted: 416 Post(s)
Liked: 471
The thing is, perception of picture quality can change even without greyscale or CMS changes. There is more to picture quality than the pure meter readings.
I ran a quick set of readings on Standard mode, and my gamma is much flatter at the lower levels than I am used to seeing for standard mode. I made a few changes to greyscale and CMS, nothing dramatic, a few ticks here or there. There continues to be color errors that I cannot calibrate out of, but all below dE of 2.
Far too early impressions: So far so good with the EvoKit. Picture looks wonderful on standard, tickers are crisp and sharp with AMP set to clear. CNN is stunning as usual. I need to watch a lot more content, but CE dimming seems refined somewhat.
Have not watched any movie-mode yet. It would take a lot though to get me back to Movie mode as I am quite pleased with standard.
Samsung 55ES8000
Mavinwow is offline
post #15313 of 16401 Old 05-22-2013, 07:42 PM
gamermwm's Avatar
Quoted: 83 Post(s)
Liked: 93
Interesting. I'm not nearly the biggest 1046 proselytizer but I do agree that it changed PQ for the better, so we knew it was possible they could tweak this set for optimization even without the kit. But as far as a higher zoning capability relevant to MDUltimate, you're right on because it wouldn't be seen as readily in movie mode. Perhaps this or a future update will increase the effectiveness of Black Enhancer in movie mode so that it will be more on par with the black levels of standard mode
gamermwm is offline
post #15314 of 16401 Old 05-23-2013, 03:26 PM
eric3316's Avatar
Quoted: 841 Post(s)
Liked: 959
If my whites have a heavy red tint in them what setting should I adjust to remove the red?
eric3316 is offline
post #15315 of 16401 Old 05-23-2013, 03:31 PM
Mavinwow's Avatar
Quoted: 416 Post(s)
Liked: 471
What settings are you using? What mode?
If standard mode, it is probably your contrast jacked up too high causing pink discoloration.
Try to download the AVS709 disc and burn a copy so you have access to some test patterns.
Samsung 55ES8000
Mavinwow is offline
post #15316 of 16401 Old 05-23-2013, 03:32 PM
Mavinwow's Avatar
Quoted: 416 Post(s)
Liked: 471
I always found black enhancer to not work very well. It seemed like CE dimming was rapid, but black enhancer was a slow dimming. My girlfriend kept asking why the picture was dimming when black enhancer was on, and if she noticed, I know its an issue :P
Samsung 55ES8000
Mavinwow is offline
post #15317 of 16401 Old 05-23-2013, 04:57 PM
Mavinwow's Avatar
Quoted: 416 Post(s)
Liked: 471
So, Im really missing the pivot feature lately with this TV. Has anyone tried putting the TV on a lazy susan so it can rotate? I would probably need a pretty beefy one to support the weight.
edit: apparently there is an entire market for these things. This one seems fairly nice:
http://www.amazon.com/TV-Swivel-Stand-14-Black/dp/B004A9FHBE/ref=cm_cr_pr_product_top
Anyone have experience with something like this?
Samsung 55ES8000
Mavinwow is offline
post #15318 of 16401 Old 05-23-2013, 06:09 PM
eric3316's Avatar
Quoted: 841 Post(s)
Liked: 959
It is in movie mode from some calibrated settings from the spreadsheet.
eric3316 is offline
post #15319 of 16401 Old 05-23-2013, 06:47 PM
Mavinwow's Avatar
Quoted: 416 Post(s)
Liked: 471
FYI: EK is back in stock at costcentral for $180 shipped, or Amazon is listing it for $192, not in stock though. I am very happy with my purchase, full review to come. Glad this thing is priced reasonably.
Samsung 55ES8000
Mavinwow is offline
post #15320 of 16401 Old 05-23-2013, 10:10 PM
Ripper64's Avatar
Liked: 25
I posted last week I bought the 60ES. I had a stuck red pixel looking directly at it. Under a magnifying glass it looked dark blue or black. It was off to the side a couple inches from the frame and decided I could live with it. I later noticed today a small red blotch the size of a quarter or more on a black screen switching inputs. I decided to return the TV at that point.
All the batteries were dead for all the items and the glasses batteries missing. Batteries are cheap so I didn't care. The chrome bezel had some light scuff marks. It looked like somebody had it previously, plus it was a demo for about 6 months. I asked if it was a return as I didn't care if everything checked out. They told me no, but the glasses had all the stickers on the lenses off and they were not wrapped up, just tossed in the glasses box. Things didn't add up. The red blotch was the final deal killer.
It's really too bad. I loved the picture quality. I had a chance at the 65" for an extra $500 but it sold the day after I bought mine. Maybe I should have grabbed that one instead. I promised myself I would move to a 70" set since I had a 58 Panny plasma previously. Maybe its for the best. I was looking forward shoot'n the crap with you guys. Looks like I'll be moving on to something else. Maybe I might try the Sony 70" R550A since the price is right for a big screen. I had a quick look at it in a store out of town a couple weeks ago. I can say it isn't as nice as the ES8000, but might suffice for the time being. Unless I go plasma again.
Ripper64 is offline
post #15321 of 16401 Old 05-24-2013, 03:47 AM
Bladerunner1959's Avatar
Location: Pittsburgh, PA...Preferably the Virgin Islands....
Quoted: 13 Post(s)
Liked: 67
Best of luck with whatever you buy Ripper.
Love for all things Hi-def...Losing count; 200 plus bluray, 500 plus dvd, 30 plus HDdvd and a rapidly growing 50 plus in the cloud.
Bladerunner1959 is offline
post #15322 of 16401 Old 05-24-2013, 10:41 AM
Jestered's Avatar
Liked: 38
Well I just ordered the Evo Kit through Amazon for $179.10 out the door. I'll also run some before and after meter readings, but am not expecting there to be any real changes in the readings.
Jestered is offline
post #15323 of 16401 Old 05-24-2013, 11:06 AM
arenaman's Avatar
Liked: 33
I'm thinking about getting a calibration set, which one did you buy
It's been a while since I've been in this thread, I think it would take weeks to catch up.
Panasonic TXP65VT65B
arenaman is offline
post #15324 of 16401 Old 05-24-2013, 11:31 AM
I got a colormunki display which I will be using with hcfr
I had been watching them for a couple of weeks and this came up on a buy it now new and sealed.
They roughly sell for £60 used and 110 new.
post #15325 of 16401 Old 05-24-2013, 11:38 AM
arenaman's Avatar
Liked: 33
Is there only 1 model? £60 is a steal for a nice little toy to play around with smile.gif
arenaman is offline
post #15326 of 16401 Old 05-24-2013, 12:06 PM
Colormunki do other models but the colormunki display is based on the i1 display pro which is THE ONE to go for but a little more expensive.
post #15327 of 16401 Old 05-24-2013, 02:44 PM
Jestered's Avatar
Liked: 38
That's right. The ColorMunki Display is exactly the same meter as the i1Display Pro, which is a very widely used meter and considered one of the best you can get, but it's got a slightly slower meter read time. Other than that they are the exact same meter made by the same company. The difference in price between the two made my decision in which one to buy a no-brainer.
Jestered is offline
post #15328 of 16401 Old 05-24-2013, 08:02 PM
jimmyva's Avatar
Guys:
Help. I keep coming back to the UN60ES8000. The Aqous is nice, The Pannie ST60 is nice. Is this one, the one? It's a 2012 model? And hoping my old analog receiver will get the sound from it? Thanks, you guys rock when buying.
jimmyva is offline
post #15329 of 16401 Old 05-24-2013, 11:33 PM
gamermwm's Avatar
Quoted: 83 Post(s)
Liked: 93
Originally Posted by TonyaNorway;19051113
Hi!
Just got off the phone with Samsung, there are no plans to introduce the Cinema Black function on the ES8K series as it was decided it added more problems than it solved.
Some algorithms were enhanced to enable the user to get the same effect via the picture settings, as if properly adjusted, there shouldn't be any light bleed from the black bars whatsoever, which I tend to agree with
Will the EK affect the picture quality on an ES8K series?
Absolutely, but not dramatically was the definitive answer.
Enthusiasts will see improvements but the average user not so much.
As far as Samsung further tweaking the picture via firmware updates, one could say they are fanatically obsessed with doing so, which is why the sets have received so many updates in the last year and will continue to do so, which isn't a bad thing IMHO.
Just saw this on AVF (UK). Pretty much confirms what I've been saying sinice way back in this thread and what some others also thought would happen. Note the tweaking of algorithms and mention of at least a subtle picture quality improvement (probably through MDUltimate). Samsung would be crazy to publicly claim PQ improvement when the improvements are not drastic, which I'm sure is why they haven't. The person I quoted has some inside contacts and if you visit the UK thread you'll notice that his credentials are never in question. Now its just up to our expert calibrators to pick out the subtle improvements in picture quality as more firmware updates are released to take advantage of the kit
gamermwm is offline
post #15330 of 16401 Old 05-25-2013, 04:03 AM
eagle_2's Avatar
Quoted: 405 Post(s)
Liked: 293
I could use something like that for sure for my F8000, but due to the absurdly long dimensions of the F8000 stand, I would need a huuuge swivel, which even if they made one that long, would cost a lot of money. They really need to go back to a more basic style stand that is actually functional, with swivel, especially with the lousy viewing angles these sets have. It's crazy that these sets can't swivel.
eagle_2 is offline
Reply LCD Flat Panel Displays
color , Displays , firmware , Lcd Hdtv , Samsung , Samsung Un46es8000 Led Hdtv , Samsung Un65es8000 Led Hdtv , UN55ES8000 , un55es8000f
