Official Samsung UNxxES8000 Owner's Thread - Page 526 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
post #15751 of 16399 Old 09-06-2013, 01:00 PM
thebignewt's Avatar
Quoted: 289 Post(s)
Liked: 92
You guys are nuts. I'm still using a Yamaha sub I bought for $400 in like 1993, when subs were new. It's got 2 four inch drivers and a crossover knob. You had to bleed the front speaker wires through it because there was no sub output on AVRs then (Dolby Digital was the format, VHS the source). It still sounds good, but maybe it's time to upgrade? (I think I know the answer)
Samsung ES8000 65", Evo Kit installed, Yamaha AVR with Paradigm speakers, iMac, iPad, Apple TV and HTC One phone.
thebignewt is offline
post #15752 of 16399 Old 09-06-2013, 01:12 PM
SoundofMind's Avatar
Liked: 166
^ROTFL
Yes, I still like playing with Dalis.
SoundofMind is offline
post #15753 of 16399 Old 09-06-2013, 01:20 PM
Ricoflashback's Avatar
Quoted: 649 Post(s)
Liked: 349
Originally Posted by SoundofMind View Post
Either would be a fine sub and a good value. I don't know what a coupla Hz difference in F3 pointtranslates to in real-world listening.  You're right, 20-25 is felt, not heard.  Note that by placing a sub closer to a corner you can gain considerable sub performance with "room gain". The VDR is a 12" and has more sophisticated electronics w/ DSP and presets.  I personally use that feature all the time.  For ex., the music setting gives me accurate, smooth yet punchy bass, the Action Movie setting rattles the walls.  smile.gif
Hey, here's an idea.  If still available, order two of the Velos.  Same price as 1 SVS, way more power/headroom, WAY more speaker area-and you'll gain low freq extension.  if you like you can situate two subs to help cancel room modes created by either one for smoother, punchier bass.  Two subs is crazy good, especially at that price!
While you're at it, why not buy the "Butt-Kicker" chairs with the Sub connected.
Two subs, one on each side of the room with "Butt Kicker" lounge chairs to boot. That way, you'll really feel the movie....smile.gif
Home Theater Setup
Samsung UN65ES8000 LCD/LED & BenQ W1080ST & Vizio M43C1
Pioneer SC65 (Pre-Amp) & Emotive XPA-3, 200 WPC
OPPO 103, Comcast Infinity X1, Darbee Darblet
ALL Paradigm - 7.1 - Studio 60's, V.2 (FL/FR) CC-690, V.5 (C)
ADP 590 V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub
Ricoflashback is offline
post #15754 of 16399 Old 09-06-2013, 01:40 PM
Liked: 166
^My HT is on a suspended hardwood floor over a crawlspace so when I put my two Velodyne DD10s (combined 2500 W RMS) in "Action Movie" mode I get my "butt kicked" pretty good already.  :D
post #15755 of 16399 Old 09-06-2013, 07:48 PM
10k
10k's Avatar
Quoted: 1278 Post(s)
Liked: 1333
Originally Posted by zaria View Post
I also read that 3D tvs like ours can accept 120hz and display 120hz; is this true?.
When I output from HTPC I get 1080p 60hz; using Totalmedia Theatre 6 when I play a 3DBD it updates the refresh rate to 1080p 30hz and when I play using PowerDVD 13 I get 1080p 24hz on 3D discs; this is only on 3D content; is that normal and does the same thing happen if I had a external commercial 3D blu-ray player using this tv?
I couldn't find it on google but if you look in your manual you will see that the TV input is limited to 1920x1080@60hz, or 1080p60. All the marketing about 120hz and 240hz is around the processing that gets performed by the TV itself on the 60hz signal before displaying it (ie, the smoothing features etc). I dont know about TMT vs PowerDVD but if they are switching to 30hz and 24hz when you are playing bluray, it is doing that because that is the framerate of the source content. If it got it wrong and was playing 24fps content at 30hz (or vice versa) it would look terrible, so dont worry, it's doing what it is supposed to.
In terms of displays that accept greater than 60hz input, I think you need to look at PC gaming monitors for that. As far as I know no television accepts anything higher than 1080p60 (except the handful of 4k 30hz displays out there).
10k is online now
post #15756 of 16399 Old 09-07-2013, 05:25 AM
stefuel's Avatar
Quoted: 25 Post(s)
Liked: 24
I have occasional stutter. It happens on a irregular basis on all HDMI inputs. I have read a few posts that suggest changing "AMP" setting to "clear". I am not home to check but don't recall seeing this in the menu. What is it and what am I changing? I won't be able to look at it until tomorrow. Other then this I love the set.
Current owner of the last/best AmPro on the planet. The mighty 4600HD, and it's still running...better than Barco's, especially southern ones.
stefuel is offline
post #15757 of 16399 Old 09-07-2013, 01:33 PM
Jestered's Avatar
Liked: 38
Yep. You likely need to change that to clear to resolve the studder problem. Here's where you'll find it:
Picture-> Picture Options-> Auto Motion Plus
UPDATED: 04/05/2013 - My Colormunki/HCFR calibrated settings for 65" ES8000
LG OLED65E6P * Adcom GFA7000 Amp (FL/FR/C) * Marantz SR6010 AVR (Sur. x4 & FRH/FLH) * Polk RTiA5 (FL/FR) * Polk CSiA5 (C) * Polk FXiA6 (Sur. x4 & FRH/FLH) * SVS PB-1000 (SW) * URC MX-5000 Remote *
Jestered is offline
post #15758 of 16399 Old 09-07-2013, 05:26 PM
sterlingma1's Avatar
Quoted: 21 Post(s)
This is EXACTLY what was wrong with mine. Took three repairs to identify it. The connection cable had a short, and one of the ends actually looked burnt when it was taken off. First two techs didn't notice it. 3rd Tech indicated that there was a service bulletin posted about this being the potential problem.
sterlingma1 is offline
post #15759 of 16399 Old 09-08-2013, 07:25 AM
stefuel's Avatar
Quoted: 25 Post(s)
Liked: 24
Well so far so good. "AMP" (Auto Motion Plus), changed it to "clear and all seems well. I have not seen any stutter. I'm not 100% sure but the picture looks a tad softer in clear. Anyone else notice that. It could just be my old eyes playing tricks on me.
stefuel is offline
post #15760 of 16399 Old 09-08-2013, 08:32 AM
cityinruin's Avatar
Are you guys able to get dualview (or whatever its called) working with the Galaxy tab 2(or galaxy s3 for that matter)? My TV came with one as a bonus but I've never actually ben able to make it work, not sure what the deal is.
secondary note- im still extremely disappointed that allshare-cast (aka miracast) doesnt work without a silly dongle despite the TV having all needed technology already built in.
cityinruin is offline
post #15761 of 16399 Old 09-08-2013, 09:54 AM
bigraytk's Avatar
Dual view only works for non HDMI connections.
bigraytk is offline
post #15762 of 16399 Old 09-08-2013, 10:26 AM
cityinruin's Avatar
do any other connections actually exist?
post #15763 of 16399 Old 09-08-2013, 11:35 AM
bigraytk's Avatar
You could do component, but HDMI looks the best.
bigraytk is offline
post #15764 of 16399 Old 09-08-2013, 03:13 PM
cityinruin's Avatar
i'm crazy confused. are you saying that SmartView only works if im using a connection that doesnt exist ?
Alls i want is to connect my fios box to my un60es8000 and watch the game when i have to run t he pooper. what am i doing that is wrong ?
post #15765 of 16399 Old 09-08-2013, 06:01 PM
Bladerunner1959's Avatar
Location: Pittsburgh, PA...Preferably the Virgin Islands....
Quoted: 13 Post(s)
Liked: 67
SteFuel, i agree that clear does soften the pic slightly. I use standard. I dont have stutter but the occasional blur...but imho its easy to live with for the sharper punchier picture. Well worth the trade off.
Love for all things Hi-def...Losing count; 200 plus bluray, 500 plus dvd, 30 plus HDdvd and a rapidly growing 50 plus in the cloud.
Bladerunner1959 is offline
post #15766 of 16399 Old 09-08-2013, 10:18 PM
JDenham's Avatar
I use to have my AMP setting set to Clear cause I would get bad stuttering in STANDARD. But lately after latest update FW 1057 I have it set to STANDARD and it's perfect smile.gif
JDenham is offline
post #15767 of 16399 Old 09-08-2013, 10:21 PM
JDenham's Avatar
Does anyone have or herd about the Samsung wall mount ? Supposly hangs the tv really close to the wall ??
JDenham is offline
post #15768 of 16399 Old 09-09-2013, 03:02 AM
Samsung UN46ES8000F TV, Samsung WMN350M mini wall mount, Samsung VG-KBD1500 bluetooth keyboard, Samsung HT-E6730W home theater
Highland Logan is offline
post #15769 of 16399 Old 09-09-2013, 08:07 AM
JDenham's Avatar
Hey
Originally Posted by Highland Logan View Post
There are 2 types; the Slim Mount and Mini Mount. I have the WMN350M Mini and it's great.
Frank
hey frank, what's the diff between the two ? I had bought a mount from best buy but I want a mount that sets the tv as close to the wall. Is there any heat issues being so close to the walls ?
JDenham is offline
post #15770 of 16399 Old 09-09-2013, 08:12 AM
zaria's Avatar
Regarding SmartHub apps; is there a difference between the availability of the apps for US to Canada?
zaria is offline
post #15771 of 16399 Old 09-09-2013, 09:42 AM
post #15772 of 16399 Old 09-09-2013, 09:57 AM
zaria's Avatar
Yes there is quite a difference. I'm happy with what was offered for the Canadian apps. I get my channels (only 3) from OTA, so I'm not too hard to please. The only thing that got me was the lack of PVR/Timeshift, but I took care of that problem.
Frank
@Frank, thanks I just read your signature post on PVR, WOW, never knew you could do that. I need to see what other features are missing from my CDN version.
zaria is offline
post #15773 of 16399 Old 09-09-2013, 10:45 AM
chrisjmccord's Avatar
So my UN60ES8000 got stolen out of my house last week with a home break in, and I'm probably going to replace this TV with something different, maybe even plasma.
Not sure what brands or what right now, I just know that I'm going to rethink my original decision on this TV itself.
They didn't steal the EVO Kit remote or the TV Remote that came with it, nor the IR Blaster.
If anyone is looking for a back up to these devices, or wants extras, we can work out a deal, just PM me.
chrisjmccord is offline
post #15774 of 16399 Old 09-09-2013, 02:18 PM
gamermwm's Avatar
Quoted: 83 Post(s)
Liked: 93
Wow that sucks. Did they actually take it off a wall mount or was it on a stand? Also, couldn't Samsung locate the set if the thief tried to use any of the smart features...I mean they probably wouldn't go into all that, they would just expect you to carry home insurance. But still if a cellphone has the technology to be located at a thief's address I'm sure a smart tv could be as well
Perhaps they will use the internet with the kit and the S-Recommend will suggest such shows as Law & Order and Cops...
What is the meaning of life?
www.iamsecond.com/films
gamermwm is online now
post #15775 of 16399 Old 09-09-2013, 02:20 PM
It was just on a stand here in the house. I don't know if the TV has GPS features in it? And they would have to connect it to the internet for anything else to work, so I doubt it can be tracked.
Its ok, I'm happy to go shopping again.
post #15776 of 16399 Old 09-09-2013, 02:54 PM
gamermwm's Avatar
Quoted: 83 Post(s)
Liked: 93
Yeah I don't think it has GPS but couldn't they see the serial number etc. if connected to the internet and track down the IP address and find where its located exactly? Anything that is connected to the internet can be located. And it doesn't hurt that the tv has a camera and facial recognition. Anyways, I'm just saying....I know Samsung is not likely to do anything of the sort...just thinking of possibilities
post #15777 of 16399 Old 09-09-2013, 03:17 PM
Sure, thats if they do connect it to the net. Seems like a big hassle to me though, calling Samsung etc. More work and headache for me.
post #15778 of 16399 Old 09-09-2013, 03:21 PM
post #15779 of 16399 Old 09-09-2013, 05:30 PM
Quoted: 649 Post(s)
Liked: 349
Chris - major bummer. Sorry to hear about it.
But - shopping for a new one should be fun! I think Vizio has an 80" 3D, 240Hz with Internet apps. I got a promo on it the other day.
Home Theater Setup
post #15780 of 16399 Old 09-09-2013, 05:49 PM
lol, I don't have room for 80", 65" is my limit, so I'm deciding tween the PN64F8500, or the Panny 65" ZT60
I really liked the LED, but after a bit, I was disappointed in the angle viewing and the IQ from that.
Reply LCD Flat Panel Displays
color , Displays , firmware , Lcd Hdtv , Samsung , Samsung Un46es8000 Led Hdtv , Samsung Un65es8000 Led Hdtv , UN55ES8000 , un55es8000f
