Official Samsung UNxxES8000 Owner's Thread - Page 544 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
post #16291 of 16399 Old 01-29-2015, 07:37 AM
BFJ 96's Avatar
Quoted: 62 Post(s)
Liked: 36
Originally Posted by myst4ry View Post
I just bought a X-Rite ColorMunki Display calibrator to calibrate this. I use this TV with an HTPC, so I'm guessing that the software will be able to change all the settings required, without me having to fiddle with the TV menu settings?
You will need to fiddle with the TV menu settings in order to achieve the desired calibration settings.
The software from the X-Rite adjust as you tweak to get you closer to industry standard than doing it by eye
Sent from my G2 via Tapatalk
BFJ 96 is offline
post #16292 of 16399 Old 02-08-2015, 07:48 PM
Quoted: 164 Post(s)
Does the ES8000 pass a 5.1 (or greater) signal though the optical or coax audio out?
MiniBones is offline
post #16293 of 16399 Old 02-08-2015, 08:49 PM
as in "O.G." Alonzo
galonzo's Avatar
Quoted: 568 Post(s)
Liked: 588
Yes, but only from the built-in tuner or app that supports it.
galonzo is offline
post #16294 of 16399 Old 02-08-2015, 10:35 PM
Quoted: 164 Post(s)
So if I have three different sources connected by HDMI to the ES8000 and then an HDMI out to a soundbar the out to the soundbar is just stereo?
post #16295 of 16399 Old 02-09-2015, 12:46 PM
poppagene's Avatar
Quoted: 604 Post(s)
Liked: 387
No HDMI out. wrt optical out from the manual:
When the receiver (or home theater) is set to on, you can hear sound output from the TV’s optical jack. When the TV is receiving a DTV signal, the TV will send 5.1 CH sound to the home theater receiver. When the source is a digital component such as a DVD player / Blu-ray player / cable box / STB (Set-Top-Box) satellite receiver and you connected it to the TV via HDMI, you will only hear 2 CH audio from the home theater receiver. If you want to hear 5.1 CH audio, connect the digital audio out jack from your DVD / Blu-ray player / cable box / STB satellite receiver directly to an amplifier or home theater.
So only stereo from the 3 you connected to the TV with hdmi.
poppagene is online now
post #16296 of 16399 Old 02-09-2015, 03:59 PM
BFJ 96's Avatar
Quoted: 62 Post(s)
Liked: 36
Are you turning off the TV Speakers in the Menu, then setting the Audio setting within the TV to DOLBY DIGITAL/DTS
BFJ 96 is offline
post #16297 of 16399 Old 02-09-2015, 07:27 PM
Quoted: 164 Post(s)
I haven't tried it yet because I haven't bought the soundbar. The soundbar I buy is contingent on whether or not the TV has the functionality of passing the 5.1 signal via an optical or coax out.
post #16298 of 16399 Old 02-09-2015, 08:10 PM
Quoted: 164 Post(s)
Has anyone upgraded from their ES8000? It might be time to move it to another room and get something bigger and new for the spot where the ES8000 currently resides.
If anyone has upgraded what did you go with?
post #16299 of 16399 Old 02-10-2015, 05:25 AM
as in "O.G." Alonzo
galonzo's Avatar
Quoted: 568 Post(s)
Liked: 588
still use my es8000 (got the 1st evo kit), but I did upgrade my "theater plasma" to a HU9000
galonzo is offline
post #16300 of 16399 Old 02-12-2015, 10:26 AM
Quoted: 164 Post(s)
So does this mean the es8000 can pass DD and DTS via the optical out? Provided such audio comes in from the source?
post #16301 of 16399 Old 02-12-2015, 11:43 AM
thebignewt's Avatar
Quoted: 289 Post(s)
Liked: 92
I don't think it will, because there's really no point to it. DD or DTS will likely originate only from a BD or DVD. In order to hear that sound you need an AVR. If you have an AVR you don't want to connect your sources to the TV, you connect them directly to the AVR, and use a single HDMI cable to HDMI 2 on the TV. That's the ARC input. That way the apps on the TVs Smarthub pass the 5.1 sound to the AVR. For a soundbar it doesn't matter if it's 5.1, DD, or DTS it's gonna pretty much sound the same.
Samsung ES8000 65", Evo Kit installed, Yamaha AVR with Paradigm speakers, iMac, iPad, Apple TV and HTC One phone.
thebignewt is offline
post #16302 of 16399 Old 02-12-2015, 03:04 PM
BFJ 96's Avatar
Quoted: 62 Post(s)
Liked: 36
I would say Yes. I have an optical running from the TV into my AVR. Anytime I turn my TV Speakers OFF and just run sound from my AVR my AVR reads DTS.
When I don't do that, I get PCM from my AVR
BFJ 96 is offline
post #16303 of 16399 Old 02-12-2015, 09:21 PM
Quoted: 164 Post(s)
Newt, the point for me would be that DD or DTS could make it an output via optical from the TV to a soundbar which could use the signal. I don't the the ONLY use for a Dd or DTS input is strictly in an AVR. From what I have read some TVs can do it but most can't.
BFJ, thanks for sharing your experience n
post #16304 of 16399 Old 02-17-2015, 10:33 AM
Quoted: 164 Post(s)
Is your AVR connected to the optical out from the es8000?
post #16305 of 16399 Old 02-17-2015, 03:57 PM
BFJ 96's Avatar
Quoted: 62 Post(s)
Liked: 36
Yes. Optical out from the ES8000 directly into the AVR
I then go into the ES8000 sound settings and set speakers to External from TV Speakers.
Then I believe the next setting after you exit out from settings to External is where you set set the Optical from the ES8000 to output in DTS
BFJ 96 is offline
post #16306 of 16399 Old 02-17-2015, 06:34 PM
Quoted: 164 Post(s)
I know where you are talking about. It is odd that the quick start guide specifically says the es8000 will not pass along 5.1 to the optical out for connected devices.
This does, unfortunately, directly impact my plan for a soundbar. I guess I will just have to test this on the weekend.
post #16307 of 16399 Old 02-18-2015, 05:03 PM
Quoted: 59 Post(s)
Do you see a large difference between the es8000 and HU9000? Worth upgrading?
myst4ry is offline
post #16308 of 16399 Old 02-18-2015, 05:19 PM
as in "O.G." Alonzo
galonzo's Avatar
Quoted: 568 Post(s)
Liked: 588
I haven't even scratched the surface (no 3d) yet, but my family and I think the difference is substantial. Even though my HU9000 is much larger, (so you would think 1080p upscaled to 4K and made that much bigger might look soft or not as crisp), we were in awe watching Monster University on BR. My 10yr old made the comment that he knows it's fake [the environment], but he feels like he's there. I showed my sister-in-law (not easily impressed with technology) some 4k content, and she said she felt like she could reach out and touch what she was seeing (again, not even 3D yet).
As a background, I followed this thread when I purchased my ES8000, and didn't get a professional calibration, but I tried the settings from someone who did their own (with the same exact panel) and adjusted settings a little more using the AVS test patterns. Everyone was happy, still love watching 3d or regular BluRay on it. I set the HU9000 to Movie and made a few tweaks here and there (so not even using any tools yet), and we absolutely love it.
UN78HU9000FXZA(TS01)/SEK-3500U || UDP-203
Denon AVR-X4200W || Atmos/DTS:X 5.1.4:
Fronts = Klipsch R-3650-WII (x2), Surrounds = Klipsch G12 (x2)
Center = Klipsch RP-160M, Sub = HSU VTF-3 Mk 5,
TFs = Klipsch R-2650-C (x2), TRs = Polk RC80i (x2)
UN65JS9500FXZA (TS01) || UBD-K8500 || Chromecast Ultra
galonzo is offline
post #16309 of 16399 Old 02-22-2015, 02:49 PM
Quoted: 164 Post(s)
So when I turn off the speakers on the tv I have the option with SPDIF of either PCM or DTS Neo 2:5. Both DTS and Dolby Digital are greyed out. I don't have an optical cable connected so perhaps that is why??
post #16310 of 16399 Old 02-22-2015, 03:38 PM
BFJ 96's Avatar
Quoted: 62 Post(s)
Liked: 36
DTS Neo is the only DTS Surround Sound offered by the display via optical
BFJ 96 is offline
post #16311 of 16399 Old 02-22-2015, 08:15 PM
Quoted: 164 Post(s)
Hmmmm. So I have the TV set to external speakers and DTS Neox 2.5. I have set up the associated soundbar and the optical output is indeed shining a red light. But no sound.
Then in the course of messing with things I found that if I changed the speaker setting to TV Speakers that I get sound from the soundbar. Limited to PCM.
Any thoughts?
post #16312 of 16399 Old 03-04-2015, 06:52 AM
poppagene's Avatar
Quoted: 604 Post(s)
Liked: 387
Originally Posted by toomanytvstosee View Post
so I am dealing with no wifi and it seems the module on these tvs tend to die. even with the service manual, I cannot locate where the module is for the life of me.
Can any one help
Did you ever find out where the wifi module is located?
post #16313 of 16399 Old 03-12-2015, 01:02 PM
10k
10k's Avatar
Quoted: 1277 Post(s)
Liked: 1333
Anyone upgrade their ES8000 to OLED yet? Those LG's are getting pretty cheap and I'd love to upgrade if it bought me better screen uniformity and significantly increased blacks.
As an aside, I recently moved and the TV is in a light controlled environment now. I switched back to Movie mode and am now able to set backlight at 7 and still get plenty of brightness. At 7 even in dark scenes the clouding is mostly invisible, but still there if you look for it.
10k is online now
post #16314 of 16399 Old 03-12-2015, 03:05 PM
xvfx's Avatar
Quoted: 408 Post(s)
Liked: 225
Some of it doesn't sound too hot.
Calibration Anomaly on Newest of the New LG OLED!
http://www.hdtvtest.co.uk/news/55ec9...1412163962.htm
Screen Uniformity
Once we peeled our eyes away from the addictive contrast and started to analyse critically though, we unearthed a number of interesting issues on the EC930 OLED. First was the presence of varying degree of discolouration on different parts of the screen, notably a magenta tint along the left and right sides on our review unit. This was compounded by the image taking on a slight greenish cast when not viewed straight on. Whilst this tinting was largely invisible with most content we watched, black-and-white films and a uniform grey/white backdrop would show it up, which may irk owners depending on their viewing habits and individual tolerances.
Magenta tint along the sides on a 50% stimulus full-field grey pattern
Loss of detail along the left and right edges in a low-APL scene
Intrigued, we fed some full-screen near-black patterns to the 55EC930V, and saw the same vignetting effect: Low-APL vignetting on a full-field 2% above black pattern
xvfx is offline
post #16315 of 16399 Old 03-12-2015, 03:32 PM
10k
10k's Avatar
Liked: 1333
Wow what a disappointment. Thanks for saving me a couple thousand bucks
Bladerunner1959 likes this.
10k is online now
post #16316 of 16399 Old 03-29-2015, 11:44 AM
Bladerunner1959's Avatar
Location: Pittsburgh, PA...Preferably the Virgin Islands....
Quoted: 13 Post(s)
Liked: 67
I've had my un60es8000 since about May 2012. I'm still extremely happy. None of the panels come without flaws.
Regarding OLED and the LG; I'm definitely interested in this but not for about 2 more years. At that time price will be way down, many issues will have surfaced and been resolved.
The LG does show some insanely inky blacks as I casually look at it from time to time... Who know what 2017 will have but...I'm confident that the selection for the 65-80" class will be exceptional.
Still, Samsung, Sony and LG are the top dogs in picture quality right now on the show room floors.
10k, galonzo and Ricoflashback like this.
Love for all things Hi-def...Losing count; 200 plus bluray, 500 plus dvd, 30 plus HDdvd and a rapidly growing 50 plus in the cloud.
Bladerunner1959 is offline
post #16317 of 16399 Old 03-29-2015, 11:57 AM
Quoted: 13 Post(s)
Liked: 67
16, 316 post...crazy!
So i'm still on firmware 1046.2 (aka the Bladerunner FW...LOL thanks Anthony ...)) and have never experienced any odd behavior in my 8000. I still do all smarthub and streaming from my Samsung bluray player and have left the 8000's brain off.
I've never done the EVO upgrade and don't regret it as I've never read enough data to suggest i'm missing anything.
I currently use Movie mode as it seems to provide a slightly more accurate color and sharper detail than Standard mode. Slightly.Yes, there is occasional flashlight and clouding but its so rare and easy enough to flip to Standard.
Looking back, I paid about 2700 for the tv and it's sound bar and haven't remorse a penny. Today i'm going shopping about possibly upgrading the soundbar to a Klipsch.
Cheers mates.
galonzo likes this.
post #16318 of 16399 Old 03-30-2015, 09:53 AM
10k
10k's Avatar
Liked: 1333
Blade, if you have the room, a 3speaker setup would have significantly higher sound quality than a soundbar. Even a 2.0 setup could be better if your AVR is good at downmixing 5.1>2.0/1
I moved last year and had to ditch the surround sound, I'm using KEF eggs as front left and right and a KEF 3005 center channel speaker, its way better than the soundbars I have heard at my friends places. I'd like to upgrade to a set of KEF LS50's or R300's, but that is pretty far down the list at the moment.
best
10k
galonzo likes this.
10k is online now
post #16319 of 16399 Old 04-09-2015, 06:40 AM
Ricoflashback's Avatar
Quoted: 649 Post(s)
Liked: 349
OLED sounds enticing but the price point is a real deal breaker for me. And after having the 65" Sammy set, I would not want to buy anything less than 75". I just can't see going down in size or staying the same. With the bigger panel size, I might be able to retire my 100" projector - - although for letterbox movies, it's great!
As Blade says, all TV's have issues. I get incredible dark blacks (stinky inky) on movie mode with the Darbee Darblet. Zero clouding - only visible when the TV has long pauses with no picture being projected.
I'm still on the Anthony firmware release (R.I.P. Anthony, oh where have you gone??) and I never looked at the upgrade kit as it doesn't do anything for PQ. I do not use any of the apps - - in fact, it's not even connected to the Internet.
All in all - - still a great panel with incredible razor sharp images and vivid colors. I'm not looking to upgrade for at least 3 or probably 5 years from now. By then, hopefully, 4K/OLED/HDR and all the HDMI standards will have sorted itself out by then with a price point I can afford.
Best,
Rico
Home Theater Setup
Samsung UN65ES8000 LCD/LED & BenQ W1080ST & Vizio M43C1
Pioneer SC65 (Pre-Amp) & Emotive XPA-3, 200 WPC
OPPO 103, Comcast Infinity X1, Darbee Darblet
ALL Paradigm - 7.1 - Studio 60's, V.2 (FL/FR) CC-690, V.5 (C)
ADP 590 V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub
Ricoflashback is offline
post #16320 of 16399 Old 04-11-2015, 07:21 AM
Liked: 4
Best,
Rico
Well, there reliability is questionable.
I have had the 55ES8000 now for about 18 months. The 1st one went faulty in just a couple of weeks and took more then double the time to have it resolved. As a matter of fact, Samsung was very little help and it was the shop I purchased it from who replaced it on their own accord, as they got sick of the stall practices by Samsung.
Now the 2nd panel has just become faulty. Vertical streaks on the LHS. You see this often in PC Monitors and at our work, I have never seen one repaired yet. Either a write off or replacement required.
Not looking forward having to deal with Samsung again.
Alfred02 is offline
Reply LCD Flat Panel Displays
color , Displays , firmware , Lcd Hdtv , Samsung , Samsung Un46es8000 Led Hdtv , Samsung Un65es8000 Led Hdtv , UN55ES8000 , un55es8000f
