Official LG XXLM7600 Owners Thread... - Page 121 - AVS Forum | Home Theater Discussions And Reviews
Old 06-01-2013, 02:42 PM
JackN's Avatar
Quoted: 36 Post(s)
Originally Posted by Bumrush View Post
So another quick update.. I convinced myself to return the TV to Best Buy.. But, after watching several movies last night noticed nearly NO backlight bleeding or flashlighting.. The day before it was unbearable. This morning it is great again.. I've never seen random flashlighting.. Has anyone heard of this? Could it be related to the temperature in my house? I'm trying to figure out the cause. Here is a picture of what it looked like when it was bad.. Today, that same picture would yield no flashlighting in in all corners, and slight light bleed on the right side, which is bearable and makes the unit worth keeping. I am concerned about this popping up again though.
Do you have 'local dimming' enabled for all of your inputs, and at the same level? If not, as you cycle through different sources, your flashlighting issue could seem better--where dimming is off--or worse (where it's on, or on at a lower setting). It's hard to tell from a photograph...but with dimming off, the level of light bleed on my set could be in the ballpark of what you're dealing with. I use 'dimming' on 'low' across the board, so the issue hardly registers to my eye. It's definitely there if I seek it out--especially with widescreen films--but it's kept to an acceptable minimum without unduly darkening the image. But everyone's mileage varies with these features...
JackN is offline
Old 06-01-2013, 03:46 PM
Bumrush's Avatar
Yes - All inputs have the exact same settings, except for 3D settings.
Local dimming on high, black level on low.
The picture I posted was with local dimming set to high. The next day, no flashlighting, just some mild light bleed on the right side of the screen. Same exact settings. I also checked the settings to confirm that nothing was reset.
Bumrush is offline
Old 06-01-2013, 05:17 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
My isf pro calibrator set my local dimming to medium. Very nice result for isf day and isf night and also for 3d. Settings. Very worth it for what I paid.
caloyzki is offline
Old 06-01-2013, 06:16 PM
scoobywrx99's Avatar
Originally Posted by scoobywrx99 View Post
Tech called today. They received the new panal and will install on Sat. Fingers crossed its not worse then before.
So tech just left and I have a new panal. I was getting a little worried because he was so rough with everything. So far so good, it looks really nice. The real test will be tonight when it's dark. Hopefully now I can bring my black levels up a bit.
scoobywrx99 is offline
Old 06-02-2013, 12:11 AM
Ok
Ok new panel has some light bleeding but less then the old one. I haven't noticed any major flashlighting. Guess it was a good move but still not completely happy. Oh well.
Old 06-02-2013, 03:57 AM
JackN's Avatar
Quoted: 36 Post(s)
Weird. Same viewing angle? Are you viewing in a light controlled room?
What are your settings for Backlight and Contrast? I had some 3D on earlier and noticed that--with those values running higher (and with local dimming on low)--the flashlighting/bleeding on my LM7600 was more apparent and in roughly the same configuration as in your picture.
Regardless, the inconsistency you're seeing is certainly puzzling.
JackN is offline
Old 06-02-2013, 09:28 AM
alireza's Avatar
hi guys
i have lm76100 its like lm7600
i cant find its bluetooth with any mobile phone...
what can i do?
alireza is offline
Old 06-02-2013, 09:31 AM
Ok
Old 06-02-2013, 01:19 PM
Richard Perkins's Avatar
Ok
mine is about 98 percent perfect after replacing the panel.
LG 55 LM7600, LG BP 620, Yamaha RX-V 677, Direct TV HR24-200, NHT Classic Ten sub, TwoC Center, NHT Classic Three's Mains, NHT IC2 surrounds.
Richard Perkins is offline
Old 06-02-2013, 04:18 PM
JackN's Avatar
Quoted: 36 Post(s)
That's about as good as it gets. Looks like a keeper.
JackN is offline
Old 06-02-2013, 05:33 PM
Bumrush's Avatar
Sure is.. Using the CNET recommended expert settings. Backlight of 57, contrast of 80.
Bumrush is offline
Old 06-02-2013, 06:58 PM
tampa8's Avatar
Quoted: 221 Post(s)
Liked: 152
Originally Posted by alireza View Post
hi guys
what can i do?
There is no Bluetooth. What are you trying to connect between the mobile and the TV? Should be able to connect using a home network, Wifi, DLNA, etc...
tampa8 is offline
Old 06-02-2013, 07:26 PM
I know, I think I'm just hyper sensetive to it now. Thanks for the feedback.
Old 06-04-2013, 10:42 AM
tgm1024's Avatar
Location: Sorry, chances are excellent that you're an idiot.
Quoted: 2459 Post(s)
Liked: 2231
Keep in mind that you get a separate set of settings for each HDMI port----make sure you're not comparing HDMI1 to HDMI2 for instance.
Also, make sure you check this out at the same time every day.
Thought #EAA: I wonder how many people know that no one ever says "What we've got here is a failure to communicate." in the movie "Cool Hand Luke" (1967).
tgm1024 is offline
Old 06-04-2013, 03:10 PM
Abdul Rahman's Avatar
For people experiencing light bleed. use "led backlight kit' it helps a Lott in reducing light bleed. i had a bad light bleed,but after using led backlight kit, I barley notice the light bleed. smile.gifsmile.gif
Abdul Rahman is offline
Old 06-04-2013, 09:03 PM
MrT3010's Avatar
So quick update.. Of course the service techs now claim that LG rejected shipping a panel until they had more proof.
I thought everything was OK until today- When the clouding / flashlighting was the worst I've ever seen. All four corners were bright..
Has anyone heard of flashlighting randomly appearing then vanishing? This is rapidly becoming very annoying.
I didn't notice the problem as bad when the TV was sitting on my stand before I mounted it. Could mounting the unit effect flashlighting and clouding?
I have a replacement panel coming in hopefully next week for the technician to change out. Like you I debated a lot over getting it done.
But on the bad days it would drive me insane. I think it does vary in brightness, given the same conditions, very odd.
Of course there are the different inputs and settings attached to each, as mentioned by others here, to keep in mind. Also the basic input change and smart functions which
switch straight to vivid, depending on your external lighting when doing these the flashlighting can be between average or very bad.
Fingers crossed my replacement panel fixes my flashlighting...nervous wait.
MrT3010 is offline
Old 06-04-2013, 10:08 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
I don't see any light bleed on my TV. Here is the pic with flash and without flash.
caloyzki is offline
Old 06-04-2013, 11:19 PM
MrT3010's Avatar
^^^ dude there's terrible spotlighting right in the middle of the screen, how can you not see that? ........ smile.gif just kidding.
Hey count yourself lucky as I still think this TV has the best looking picture I have seen in the 55 inch LED market , if it has no spotlighting then you have a good TV....enjoy!
Oh was going to mention on my previous post also, I think hanging the TV does make a difference the strain and pressure on the display is different to on the stand. You can feel that the frame is not totally rigid when hanging it on the wall. I think my spotlighting got worse after hanging and any flexing in the frame was allowed to settle. I always thought a few extra dollars in the assembly process to keep things rigid and solid would perhaps help deliver a product less prone to the clouding and spotlighting? Just my thoughts anyhow.
MrT3010 is offline
Old 06-05-2013, 05:45 PM
MMcCraryNJ's Avatar
Quoted: 24 Post(s)
That's probably the case. Wasn't there a very similar model to this one that was kinda rare (LM7200 or LM7400, something like that) that was the same TV but the frame was slightly different? I recall people with that tv were able to completely remove any flashlighting/spotlighting by squeezing the frame with their finger until something sounded like it snapped into place. The frames on the mainstream LG models unfortunately don't give us that luxury. It was mentioned a lot earlier in this thread, somewhere.
55" Samsung KS8500/55" Sony XBR810C/PS4 Pro/NVIDIA Shield TV
MMcCraryNJ is offline
Old 06-05-2013, 05:51 PM
MMcCraryNJ's Avatar
Quoted: 24 Post(s)
Originally Posted by tampa8 View Post
Have you used Hulu plus before on a computer? I did and had the exact same issues, for some reason I don't with Hulu, just the +. Everyone can't be having the same issues or they wouldn't sell subscriptions but I did on my computer. (I too have a fast internet connection, I can stream anything...)
What's interesting is that I have both a 360 and PS3.
The LG Hulu Plus app has all of the issues mentioned previously.
The 360's Hulu Plus app doesn't have any streaming issues, but the picture is generally very lousy/grainy, with slight motion artifacts and a quarter to half second delay in audio that I could not fix with any AV Sync method I have available. Also, transitions between commercials and content produce very audible clicks and pops and visual artifacts, like the TV and my receiver is resetting the signal each time.
The PS3's Hulu Plus app has no issues...quality is the same or slightly better than the LG app, no audio delay, no streaming issues, commercials run as fluid as they do on a television broadcast with no stopping or stuttering between transitions and no clicks/pops.
I ran each app for an hour each on back to back days, and the top two had the same issues persistently, while the PS3 app had no issues. Both the 360 and PS3 are connected via HDMI using the exact same picture and audio settings each time.
It's just so weird how the same app on different platforms can perform so differently even when run on the same internet connection using the same picture settings and connection method.
So, it seems as though the app is coded terribly on everything but the PS3.
tampa8 likes this.
Old 06-05-2013, 06:30 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
While watching escape from planet earth!
caloyzki is offline
Old 06-06-2013, 03:36 PM
tampa8's Avatar
Quoted: 221 Post(s)
Liked: 152
I don't have a PS3 but I have heard others say what you and I are about other platforms.
tampa8 is offline
Old 06-08-2013, 05:31 PM
Mayjer's Avatar
Originally Posted by Leonheart View Post
Hi, can you share your ISF day and night settings please?
I don't have the day/night settings available....why would that be?
Mayjer is offline
Old 06-08-2013, 06:35 PM
tampa8's Avatar
Quoted: 221 Post(s)
Liked: 152
Do you have ISF 1 and ISF 2? After calibrating you can set it so changes can not be made without a code being entered, and when you do that it changes to ISF day and ISF night. (There are other codes for other menu items as well)
tampa8 is offline
Old 06-10-2013, 06:11 PM
Mayjer's Avatar
I do have isf 1 and 2. I always use my own settings on 2. How is it set to need a code...this is news to me.
On an unrelated note:
For everyday viewing/listening I use HDMI out of cable box into Denon receiver out to TV....nice sound.
For viewing Netflix and Cinemanow I run optical from TV to Denon.
Up until recently I got surround sound....last night I watched "Parker".....I only got sound via center channel and sub.
Any suggestions?
Mayjer is offline
Old 06-10-2013, 09:02 PM
Any suggestions?
I had to go into the service menu and enable ac-3 pass through on the optical output. If you search this thread you can find the exact instructions on how to do this. You'll need a harmony remote or something like that. Hope this helps.
Old 06-12-2013, 11:14 PM
Mayjer's Avatar
Thanks....I have a Harmony 650 I think it is.....I think the LG should be able to find it easier than a Harmony though
....but how do I get into the service menu?
I watched Netflix last night....surround was operating. Maybe some Cinemanow releases don't have surround.....but I've watched a number of movies on there that do.
Mayjer is offline
Old 06-13-2013, 07:34 AM
You need a harmony or URC to access the service menu. Search this thread, the password and instructions for fixing surround on optical output.
Old 06-13-2013, 12:17 PM
Mayjer's Avatar
Why wouldn't I be able to get into the service menu with the LG remote?
This thread is miles long btw.....
I've tried "search"...choosing the wrong words I guess
Mayjer is offline
Old 06-13-2013, 01:20 PM
tampa8's Avatar
Quoted: 221 Post(s)
Liked: 152
One of the huge discussions in this thread is about LG changing how you get to the service menu, and that very limited changes that can be made even then and even by a tech using a tech's remote. (Unless a programming computer is used) My quick search just now of the forum brought up tons of posts about it. Remote Service Menu.... Since you can screw up your TV better to read the posts and maybe learn the pitfalls and what not to do.
And you would be wrong on using a Harmony for this, the Harmony is the easiest way of all to get to the service menu.
tampa8 is offline
Lg Cinema Screen 55lm7600 55 Inch Cinema 3d 1080p 240 Hz Led Lcd Hdtv , Led Hdtv , Displays , Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver , Lg Nb3520a Sound Bar Audio System With Wireless Subwoofer Bluetooth Streaming , Samsung Un55d7000 55 Inch 1080p 240 Hz 3d Led Hdtv Silver
