Official LG XXLM7600 Owners Thread... - Page 134 - AVS Forum
post #3991 of 4006 Old 11-03-2014, 06:06 AM
waiting485's Avatar
Originally Posted by tampa8 View Post
Sorry to hear that. Doesn't sound good.
Did anything at all different happen before it would not come on? The only thing I can think of at the moment is unplug it like you did, wait about a minute or so then use the power button on the TV and hold it for about 10 sec. If nothing shows make sure that it's not on - Try changing inputs.
Nothing, my daughter was watching TV and it just went blank, she could not power on after that, I tried the above option you suggested but still the same issue.
I will contact LG support today, see if they can help.
waiting485 is offline
post #3992 of 4006 Old 11-04-2014, 07:29 PM
flhthemi's Avatar
Wow, maybe power supply died. Mine has emitted a very loud high pitch and the only way it would stop was to turn off the TV. I also watched it power itself off and back on all on its own. Bought mine in Jan 2013.
flhthemi is offline
post #3993 of 4006 Old 11-08-2014, 12:08 PM
waiting485's Avatar
I asked LG Support about the above problem, they asked me to contact a local TV repair shop, since TV is out of warranty I would have to pay all the charges.
Thinking that it must be the power board gone bad, I ordered one from ebay for about $30, installed it myself (super easy to do). Now TV is working again
post #3994 of 4006 Old 11-09-2014, 10:10 PM
JackN's Avatar
Quoted: 20 Post(s)
My LM7600 occasionally refuses to power up (and sometimes down), yet only via the magic remote. When I switch to an off-brand IR model and try again, it hasn't failed to do as told. To date, I've written it off as remote/battery strength issues. But I worry a capacitor may be going bad.
In case I wind up in the same boat, what are the board specs for this unit? And is it just a matter of swapping out the board, connecting the new one?
I also have an LG LA6200, and apparently a common issue with that model is the board connectors loosening up due to bad cable tape. The restraining tape comes loose and the wiring harness dangles from the cable connectors. Over time, gravity and thermal cycling result in broken connections. Some have found that simply ensuring a snug connection at all the fittings is enough to bring their sets back to life.
JackN is offline
post #3995 of 4006 Old 11-10-2014, 08:23 AM
waiting485's Avatar
Yes, board is attached by 6 screws and 5 cable connectors, remove those, put the new board, reconnect and you are all done.
Part number in my TV is
REV 1.0
PCB EAX64744301 (1.3)
LG P/N: EAY62512802
post #3996 of 4006 Old 11-10-2014, 09:54 AM
caloyzki's Avatar
Quoted: 162 Post(s)
Liked: 45
Hi guys.im glad this forum are still alive. Lol. I'm still enjoying my professional calibrated 55LM7600. Btw, what are you guys using cleaning your TV screen? My 1y.o.son finger prints are all over my screen.also while watching just regular cable show, which one better to use for pixel to pixel mode? 16:19,just scan, or set by program? any help woulb be appreciate. TIA.
caloyzki is offline
post #3997 of 4006 Old 11-11-2014, 10:05 PM
JackN's Avatar
Quoted: 20 Post(s)
REV 1.0
LG P/N: EAY62512802
Thanks much; very helpful. If my set ever exhibits the same symptoms, it'd probably worth a go to try a new board.
JackN is offline
post #3998 of 4006 Old 11-16-2014, 07:03 AM
flhthemi's Avatar
Looks like a new FW has arrived....V6.05.02....
flhthemi is offline
post #3999 of 4006 Old 11-17-2014, 08:47 AM
dbe425's Avatar
What's new with this FW.
dbe425 is offline
post #4000 of 4006 Old 11-18-2014, 01:40 PM
numberonekiwi's Avatar
I have a 60LM6450 almost the same as the 7600 and would like advise before ordering a new main board ( about $300 NZD )
The issue I had was I got a software update notification to what I think was 4.35.13. the usual message about a reboot appeared however when I did this the TV would flash the red LED twice then switch off and repeat the cycle so constant reboot issue.
There is no serial port / service port on motherboard so like to ask how to connect a PC to try flashing software or boot loader to the main board is there another way to connect Mstar isp utility or do I really need a new board.
numberonekiwi is offline
post #4001 of 4006 Old 11-18-2014, 04:34 PM
flhthemi's Avatar
Took the update,can't find anything different. Took screen cap of the list of installed apps and all still have the same version numbers. Beats me, sure would be nice to know.
flhthemi is offline
post #4002 of 4006 Old 11-22-2014, 03:20 PM
JackN's Avatar
Quoted: 20 Post(s)
One of the recent LG bulletins prompting a software updated suggested a tightening up of SmartTV security was underway. But who knows?
JackN is offline
post #4003 of 4006 Old 11-22-2014, 03:32 PM
JackN's Avatar
Quoted: 20 Post(s)
The first thing to try would be unplugging the TV from the wall outlet and leaving it for a few minutes (at least until the red, LED "off light" goes out). Then plug it back in and power on, see if that massages out a possibly buggy installation.
If you're out of warranty and considering failed components and you happen to have the unit opened, you could check that all your board and power connectors are snug. Some have reported power cycling when a cable has come loose. But the fact that this occurred immediately following a firmware update makes me wonder about a corrupted install. So start with unplugging... Failing that, I'm afraid I'm out of my depth.
JackN is offline
post #4004 of 4006 Old 11-23-2014, 09:02 PM
caloyzki's Avatar
Quoted: 162 Post(s)
Liked: 45
Are you not in engineering mode? My FW are already 9.x.x. version.
caloyzki is offline
post #4005 of 4006 Old 11-24-2014, 02:06 PM
flhthemi's Avatar
No, I'm not. Don't want to take the chance of it bricking my TV.
flhthemi is offline
post #4006 of 4006 Old 11-24-2014, 02:06 PM
Yes have tried unplugging for several days checked all power connectors / components connectors to the main board still waiting for a usb to 25pin parallel cable to arrive so I can make a simple interface between pin 11 and 15 of the DB25 to pin 12 and 15 on the DB15 monitor plug of the tv and using Mstar but I am not certain this will fix the issue. as I am noot sure if it is even loading the bootloader.
post #4007 of 4006 Old 11-25-2014, 12:23 AM
Leonheart's Avatar
Hi I w0uld like to know if u guys use CNETs 2D settings and if u have made any tweak also which 3D pic settings would u recommend? and last question: do u guys know what the bypass option on the AV sync do? Thanks...
Leonheart is online now
Reply LCD Flat Panel Displays
Lg Cinema Screen 55lm7600 55 Inch Cinema 3d 1080p 240 Hz Led Lcd Hdtv , Led Hdtv , Displays , Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver , Lg Nb3520a Sound Bar Audio System With Wireless Subwoofer Bluetooth Streaming , Samsung Un55d7000 55 Inch 1080p 240 Hz 3d Led Hdtv Silver
