Official LG XXLM7600 Owners Thread... - Page 135 - AVS Forum | Home Theater Discussions And Reviews
post #4021 of 4042 Old 12-22-2014, 02:48 PM
dennphill's Avatar
Worst TV I've ever had in my life. Lousy (non) Smart TV, crappy browser, poor options except for 'for-pay' sites that work better with ROKU, my BD player, etc. Poor LG support...mostly non-existent. But then, if you've had this LM 7600 series TV for a month or more you already kkonw that.
dennphill is offline
post #4022 of 4042 Old 01-17-2015, 07:40 AM
Liked: 0
Capture image from mobile application
Does anyone else have issues trying to capture images with the LG TV remote app?
When I try to capture a image I receive a green pixelated screen, I already test in different phones (Android and ios) and also reset the tv settings.
briganty is offline
post #4023 of 4042 Old 01-22-2015, 01:35 AM
octav59's Avatar
Originally Posted by octav59 View Post
Quote: Originally Posted by rahaziel
Hi guys,
its me again i just found a bug on latest firmware updates, auto power-on option is enabled by default. Please advice if you experience electrical downtimes in your house....this may cause your TV to power on without human interaction.
You can disable this option on In-Start Menu.
best regards,
I know I'm quoting and old post, but I couldn't find a newer one mentioning this problem.
I want to disable this auto power-on feature. My TV uses HDMI ARC to a Marantz receiver, and when I start the TV, the receiver also powers on to play TV audio. Very nice and convenient feature of HDMI CEC, for every day use.
But at night, after a mains power failure (220 V) which is relatively frequent in my country, believe me it's not a pleasure when the TV powers automatically on, together with the receiver and I'm hearing the news coming from the living room.
I've got a Harmony remote so I can access service menu (EZ Adjust, In Start).
If someone could share the necessary settings to disable this auto power-on feature, I'll be more than grateful.
Thanks in advance
Solved !
Digital board replacement - under warranty, hopefully.
LG technician said all settings were OK, the board is damaged.
Worth to mention that the TV worked like that out of the box.
Now it works as it should, remember last power state after a power break.
Hope it helps.
octav59 is offline
post #4024 of 4042 Old 01-23-2015, 11:44 AM
Richard Perkins's Avatar
No problems. My app works great.
LG 55 LM7600, LG BP 620, Yamaha RX-V 677, Direct TV HR24-200, NHT Classic Ten sub, TwoC Center, NHT Classic Three's Mains, NHT IC2 surrounds.
Richard Perkins is offline
post #4025 of 4042 Old 01-26-2015, 02:50 PM
flhthemi's Avatar
Android app sux and wont work properly due to Kitkat blocking writes to sdcard so app never worked for me on android execpt for a phone I intentionally rooted.
LG doesn't care a bit.
flhthemi is offline
post #4026 of 4042 Old 02-11-2015, 07:28 AM
Nohoch's Avatar
Originally Posted by nitrojunk View Post
Hey guys, i love my tv but cant stand that when im watching anything fast paced, there is a blur of some sort .. like when a quarterback throws a pass, the ball has a blurr around it ... what settings can I change to help with this ?
Have you tried Game mode?
Nohoch is offline
post #4027 of 4042 Old 03-06-2015, 09:13 PM
neocvera's Avatar
So I'm running v 06.04.07 and notice the latest is 06.05.03
Any worthwhile changes since what I'm running?
neocvera is offline
post #4028 of 4042 Old 03-18-2015, 09:05 PM
Leonheart's Avatar
Quoted: 55 Post(s)
Liked: 24
Which are your settings for PS4?
Leonheart is offline
post #4029 of 4042 Old 04-05-2015, 08:45 PM
Quoted: 67 Post(s)
Liked: 1
Hi. I have galaxy s4. And how come screen mirroring with my thru tv is not working?have u guys tried the screen mirroring features of the tv?
tapsilog is offline
post #4030 of 4042 Old 04-06-2015, 11:50 AM
Quoted: 67 Post(s)
Liked: 1
No screen morroring features on this TV?
tapsilog is offline
post #4031 of 4042 Old 04-17-2015, 11:51 AM
flhthemi's Avatar
If what you're referring to is the Intel (R) WiDi and WiFi Direct, I've tried every thing I own to get it to work. Never see anything other than it connected then loses connection to whatever was connected. Tried with
Samsung Galaxy S10.5
Samsung S3
Samsung S4
Asus TF700 tablet
Toshiba Laptop with Intel Widi
It's about the lamest attempt I've seen at getting video or PC desktop on a TV. Easier to just hook up with a HDMI cable and call it done.
Owning this TV has convinced me that I'll NEVER buy another "smart" TV.
The apps totally suck. It constantly polls DLNA servers in your network for media and info and worst of all, IT WRITES DATA INTO TEXT FILES ON YOUR PC!! It shouldn't have that kind of access unless I grant it.
See, I run Playon media server on a PC. Some of the addons for it store links to streams you have marked as a favorite. This TV accesses those ASCII text files and adds what it finds to them thereby creating a massive bunch of worthless dribble. This was also causing the server to crash! Once I discovered it was the TV doing this to my server I blocked access by the TV to the PC running the server using the TVs static IP and Windows secpol.msc.
LG support, nill to none on this issue because they think I'm some kinda nut. But, this same issue has caused problems with people who use Kodi (XBMC) and Plex Media server and others.
flhthemi is offline
post #4032 of 4042 Old 06-30-2015, 01:11 PM
dennphill's Avatar
I am back again to say just how BAD this g-d 47lm7600 is....again cannot keep a wireless connection! Set it up and ten minutes later it drops the connection. Always having to manually re-configure and connect!!! G-D, I wish I had never paid the g-d $1k for this unit. Tempted to just donate it it Goodwill and then go to Best Buy - who I hate almost worse than LG - and get ANYTHING else. At 70, I don't need this poor product! The ROKU just under the set never looses wireless connection, nor does the really old Sony DVD player under it. It's 20 feet from the wireless router (new!) and 8 feet form a wireless repeater!) and in the next room further away - master bedroom, the ROKU there does not loose wireless connection, nor does my wife's laptop. Crap TV. Will again go to NewEgg - those who care - to re-review this very poor product. And then to Amazon where I bought it. LG, of course, does not care - won't reply. No assistance. G-D Koreans only care about pumping out poorly prepared products every other year. Have avoided LG products now for over a year and will continue to do so. Aggressive in telling others of my poor experiences. (G-D = "gory details" for the purpose of this post. Or let your imagination run wild.) flhthemi, I hear your pain.
post #4033 of 4042 Old 06-30-2015, 01:20 PM
dennphill's Avatar
Absolutely the worst buy I've made in the past half-dozen years. Very poor product. No support form LG. Does not keep wireless connection. VERY, VEERRYY, vvveeerrryyyy, slow. Picture's OK and works with my cable connection, but then I could have saved $500 and just bought a regular TV. Lousy pointy thingie (remote) that they should have cut the balls of the engineer that talked them into it. (And I don't want to way which lowest level of Dante's hells should be reserved for the Korean management that let this thing get released with such poor performance. If you lived next sdoor to me I'd buy you a beer to take it away form my house! this review says it all. I won't even give LG a chance with a newer model for my replacement for this 47LM7600. Worst buy I ever made.
post #4034 of 4042 Old 07-21-2015, 02:23 PM
Leonheart's Avatar
Quoted: 55 Post(s)
Liked: 24
Hey guys on CNET settings I have to lower the luminance to 75..............correct?
My calibration of this TV was a bit more successful.than it was for the LM7600. LG's color management system was still less than ideal, plagued in particular by shifting luminance at the reference 75 IRE level and in green, but overall it improved color quite a bit.
post #4035 of 4042 Old 07-21-2015, 02:37 PM
duhmel's Avatar
Loses sound and picture
Over the past year I have beeen having a problem that has gotten progressively worse. After being on for 5-15 minutes the sound starts to sputter and then the picture fades in and out. Most of the time just shutting the TV off and restarting clears the problem but recently it has been getting worse and now takes up to 10 minutes and 5-10 times to clear. Anybody else have this problem or has an idea what is causing it?
duhmel is offline
post #4036 of 4042 Old 07-22-2015, 09:31 AM
DarenG's Avatar
Quoted: 124 Post(s)
Liked: 86
I have not see the problem you mention above. Even the problem with the TV not being able to handle a wireless connection mentioned earlier. I have had this TV going on 4 years I think and never experienced a wireless connectivity issue. We watched streamed shows all the time with no hiccups whatsoever. My biggest issue with the TV is the piss poor remote. I hate that damn thing. Other than that, I felt like I have a decent 3D TV with a decent picture for the price.
DarenG is offline
post #4037 of 4042 Old 07-22-2015, 09:37 AM
duhmel's Avatar
Problem is not related to wireless as I have a wired ethernet connection to the TV
duhmel is offline
post #4038 of 4042 Old 07-22-2015, 09:51 AM
DarenG's Avatar
Quoted: 124 Post(s)
Liked: 86
Originally Posted by duhmel View Post
Problem is not related to wireless as I have a wired Ethernet connection to the TV
I just installed a new entertainment unit and now have it connected via Ethernet as of a few months ago. However, prior to that I had it connected wireless. I have not noticed any change in behavior or performance since switching. Mine is connected via a 4 port switch which is connected to the wall outlet at the same location.
DarenG is offline
post #4039 of 4042 Old 07-27-2015, 06:22 AM
dennphill's Avatar
Well, bye, guys. Selling this very poor quality TV,,,Actually, I'll be donating it to the local Goodwill. Let somebody else have the problems. 47 inches EXACTLY fits the hole in my wall shelving, so that is one reason I bought it in 2013. (Wall shelves already on the whole wall and a complex installation, pretty difficult to modify.) Never been happy with it. It's OK for cable TV and DVD playing, and my old ROKU is a better streaming device. A waste of money and my effort. Holds record as WORST tech purchase I've made after due searching. Replacing it with a 55 inch or larger, and will just let is sit on a console on the floor and be in front of the 'hole' where the LG now sits. You can BET on me buying something other than LG next week. I have really hated this 'smart' TV buy. Absolutely will not recommend LG, and will never buy in the future. Unsubscribing this tread. Good luck all. You guys are an education in yourselves and I've enjoyed the forum.
post #4040 of 4042 Old 10-10-2015, 07:22 AM
Quoted: 74 Post(s)
Liked: 1
Originally Posted by writtensarcasm View Post
I was hoping someone here would know this. I lost the screws for attaching the tv stand to the television because I have had it mounted since I bought it. I was hoping to just go to the hardware store and pick up replacement screws. Does anyone know what size the screws are?
Edit: Found the owners manual online. It looks like the stand uses M4 0.7 x 20mm screws.
Hi. May i asked if did you get any replacing screws for the tv stand? If yes, where did you get it? I lost my screws too for the tv. Thanks
Sent from my SGH-M919 using Tapatalk
parekoy is online now
post #4041 of 4042 Old 11-10-2015, 11:14 PM
Liked: 0
Question 55lm7600 rs-232
G'day,
I'm developing a home automation system I intend on commercialising, making billions from and then buying an island... on Mars once terraformed*.
My only hurdle is the lack of RS-232 port on the 55LM7600. I believe I have read that after 2011, LG stopped including 232 interface ports with their tele's... however, I have also read that serial commanding can be done via the USB Apps port with the right DB9 to USB adapter. Could anyone confirm this?
There doesn't appear to be much information about controlling the TV via ethernet connection except with the Android/Apple app. My biggest concern is the ability to power on/off the TV from standby, something the apps don't do. I have looked into LG APIs but with no power on/off support, its useless to me. It is quite frustrating that this TV is my main TV, I have 2 other older LG TVs (32" LCD and 50" plasma) which are connected back to a serial terminal server and controlled without issue with my home automation software. *Turns TV off downstairs using own software... laughs at his kids confusion*
Apologies if this has already been discussed, but I would greatly appreciate any information on commanding this TV preferably with serial or another method provided it supports power on/off as per previous LG TV serial commands ka 01 01<cr> etc.
*: Dream - may or may not happen.
Neried is offline
post #4042 of 4042 Old 06-09-2016, 07:29 AM
dennphill's Avatar
Well - no luck selling...too many poor reviews...so decided just to replace the 47LM7600 with a ROKU TV TCL UP120U 55". Good price at Sam's. The LM7600 will go on the wall in the bedroom, replacing a (many year old) Vizeo 40" that originally had 4 HDMI inputs, but VA and FL storms resulted in the HDMI 1 and HDMI 2 getting fried (don't work anyway) but the HDMI 3 and 4 qre OK. We'll sell that one for pennies or donate to Goodwill, or such. The $200 camera I got for the LG from a source in Korea to use Skype seems to be a wasted deal since MS is stopping TV Skype support this month - June 2016! Looking for a blog on the TCL ROKU TV now. Still think the LG is the worst buy of mine in recent times, and LG in general is a lousy company for any support. This may be of interest: interesting how the (old) Vizio 42" VO42L weighs 44.6# with stand, and the larger LG 47: 47LM7600 weighs 38.6# with stand, and the new 55" TCL ROKU UP120U weighs 32# with stand. Larger >> weighs less!
Reply LCD Flat Panel Displays
Lg Cinema Screen 55lm7600 55 Inch Cinema 3d 1080p 240 Hz Led Lcd Hdtv , Led Hdtv , Displays , Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver , Lg Nb3520a Sound Bar Audio System With Wireless Subwoofer Bluetooth Streaming , Samsung Un55d7000 55 Inch 1080p 240 Hz 3d Led Hdtv Silver
