Official LG XXLM7600 Owners Thread... - Page 88 - AVS Forum | Home Theater Discussions And Reviews
post #2611 of 4052 Old 01-18-2013, 12:44 PM
Bitgod's Avatar
Originally Posted by vagoverto View Post
Any updates on changing the audio language when streaming a movie?? Mine still appears greyed out. And I would like to know if there is a way to watch the movies in plex in 24p.
Those are functions of Plex, if both questions are about Plex. As far as the 24p, go into Plex preferences, Videos>Player, and turn on "Adjust display refresh rate to match video".
If you pull up the TV info bar where it says 60hz normally, find a video that Plex says is 24p and play it, then pull up the TV info bar and it should say 24hz. Works for me anyway.
Sorry, I should specify that's me watching the video through Plex on my Mac Mini, not via the TV player. I've never tried that, my backup player is my LG HTIB which does a pretty decent job of playing videos too.
AMP, it's like MSG for your TV!
Bitgod is offline
post #2612 of 4052 Old 01-19-2013, 08:45 AM
James T's Avatar
Location: Toronto Ontario Canada/ Port Charlotte Florida Port Charlotte Florida
I have had a quick look through this forum and did a search and all I could find were some suggested settings in post 121 which I thought were not very complete as the author was attempting to get to know his set a little better.
Is there a post or a place to go to get some picture settings for the set that many of the members have used and enjoyed for the LG LM 7600 55 inch
James T is offline
post #2613 of 4052 Old 01-19-2013, 09:35 AM
cjsiv's Avatar
Liked: 40
Originally Posted by tgm1024 View Post
There *is* a snapping on the 7200. That was a significant "AH HA" moment discussed over there. Beats me how old a concept it is----the 7200 has only been out since, what, November or so? And I'm speculating that the play and/or flex is limited by the facing glass being over that "border" you're talking about. In any case, it's important for fans considering the non-7200 series to know that the 7200 flashlighting has been completely removed by owners. At least the ones who've tried it in the 7200 forum. The 7200 is new enough that many here might not even know it exists, let alone that there was a solution that seems to work. That's a BIG deal for many, and might well move folks over the the 7200 to try it out first.
Look none of this terminology matters. Keep your terminology if you like, I honestly don't care. Just be aware that when you see "bezel" referred to you are almost always going to see it include that border you refer to. Disagree if you like too. That's ok with me.
Let's call that border you're referring to the "thing", and let's pretend for the moment that it's a physical device under the facing glass, but over the lighting apparatus or LCD array. Either.
I'm speculating that that "thing" is preventing the glass from moving inward on the non-7200's.
DO NOT press on the screen or mess with screws holding the screen. I did on one of my sets and it became worse. My bleed was way worse than before. Pressing on the screen to clean it is enough to change the uniformity in my experience. That set got exchanged for other reasons. The new one I got was removed from the box and lifted by the edges. I haven't touched the screen ever. My set is pretty good as far as flash lighting and bleed. I learned my lesson and I won't touch this one. Do so at your own risk.
cjsiv is offline
post #2614 of 4052 Old 01-19-2013, 10:42 AM
Simkins's Avatar
Looks like I got a dud, thoughts on this?
Simkins is offline
post #2615 of 4052 Old 01-19-2013, 12:25 PM
rer420's Avatar
look on the back of tv and see the manufacture date, let us know what that is as well.
your pictures are quite small, any chance of bigger pics to examine?
from what i see, in the top right corner it looks like you have a big flashlight light bleed issue.
also indicate what settings you are using....turning off things like local dimming will make it worse. ...increasing backlight will also make it worse.
make sure you have energy saving turned off...try backlight at 50, local dimming, medium or high.
but if you cant get a decent picture without the bleed bothering you then take it back before your refund policy wears out.....ive seen way better panels out of the box...they do exist, and returning again and again is not uncommon to get a great one, keep trying as a great one is worth it.
if you take it back to get another, look at serial on box and try to get one with the first 3 numbers being 210, 211 or 212...these would be oct, nov, dec build dates respectively.
rer420 is offline
post #2616 of 4052 Old 01-19-2013, 02:14 PM
JBWIII's Avatar
Liked: 44
Every specimen is different, but people like these settings (even for the 55"):
http://forums.cnet.com/7723-19410_102-573198/lg-47lm7600-picture-settings/?tag=contentBody;threadListing
JBWIII is offline
post #2617 of 4052 Old 01-20-2013, 05:33 AM
kalipu's Avatar
Photos of 6700 which I returned....
Here are pictures of my new 7600 tv set
on my Sammy refrigerator
Ghost Protocol on Netflix
This is something I noticed when I removed the protective pads from the screen before installing tv stand....I didn't see this on 6700 tv...some sort assembly process?....its a pixel size...but not on viewing area though...so I don't have a problem...its on top left and top right corners
Let me know if your 7600 has similar spot on top corners...
kalipu is offline
post #2618 of 4052 Old 01-20-2013, 06:12 AM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
^^^^^ mine have spot too. Did u remove the sticker on the screen?
caloyzki is offline
post #2619 of 4052 Old 01-20-2013, 06:18 AM
kalipu's Avatar
By sticker you mean the coating? If it is the thin coating on the screen I read in the LG manual not to remove it.......
kalipu is offline
post #2620 of 4052 Old 01-20-2013, 06:35 AM
tgm1024's Avatar
Location: Sorry, chances are excellent that you're an idiot.
Quoted: 2484 Post(s)
Liked: 2264
You're the wife. You're the dead wife. Give me my @#$%ing coin, dead wife.
-Mad Sweeney
tgm1024 is offline
post #2621 of 4052 Old 01-20-2013, 06:36 AM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
Ok. I didnt remove mine too. Why you put youre tv on top of the fridge? I think that is very hard to watch because you always look up. The best recommendation is you should be watching tvs eye level. imo.
caloyzki is offline
post #2622 of 4052 Old 01-20-2013, 06:37 AM
tgm1024's Avatar
Liked: 2264
That thing looks sort of like an ambient light sensor I've seen on various devices. My phone, for instance, has a dinky "spot" under the glass that just senses the amount of room light when the brightness is set to variable.
-Mad Sweeney
tgm1024 is offline
post #2623 of 4052 Old 01-20-2013, 06:49 AM
kalipu's Avatar
Ohh ok.....got it...tks
kalipu is offline
post #2624 of 4052 Old 01-20-2013, 08:13 AM
mustang_52's Avatar
Does anyone know how to turn off the standby light? I've unchecked the box to turn it off in settings but it's still there.
Sent from my EVO using Tapatalk 2
mustang_52 is offline
post #2625 of 4052 Old 01-20-2013, 09:51 AM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
^^^ i just turn off mine. And the light was gone.
caloyzki is offline
post #2626 of 4052 Old 01-20-2013, 10:00 AM
kalipu's Avatar
kalipu is offline
post #2627 of 4052 Old 01-20-2013, 10:33 AM
tampa8's Avatar
Quoted: 225 Post(s)
Liked: 153
A few software versions back it was hit and miss getting the light to go out it turned mine on and turning it off did nothing. Subsequent updates fixed it.
tampa8 is offline
post #2628 of 4052 Old 01-20-2013, 01:29 PM
rer420's Avatar
yep, futureshop just dropped their price on my 7600 by 300.00 and i was able to get that 300 back too. wink.gif
rer420 is offline
post #2629 of 4052 Old 01-20-2013, 01:46 PM
rer420's Avatar
yes, that little dot is normal...im assuming that is the ambient light sensor for the energy saver mode.
rer420 is offline
post #2630 of 4052 Old 01-20-2013, 02:14 PM
kalipu's Avatar
Yes you are right....screen should be at eye level...but I wanted to keep tv away from my son's hot wheels car (or toys) trajectory biggrin.gif
we have an open kitchen layout and so keeping tv on top of the refrigerator is not an issue......I think PQ has not changed overall by watching it from a distance...
for night time movie watching I use my projector....
kalipu is offline
post #2631 of 4052 Old 01-20-2013, 04:58 PM
Mayjer's Avatar
What the heck is PQ? I see it in a number of posts here.
Is that some US way of saying pic ( picture ) ?
Makes no sense...P and Q...sound nothing like pic or picture....rant over.
Presently still have 04.31.30
Hopefully I don't get the .31 dud ( I have auto update on )
And yes...Televisions should not be too high. Above fireplaces and such is just stupid. It may be "Fasionable"...but just wrong.
A TV stand of no higher than 22" is ideal for this 55"
Mayjer is offline
post #2632 of 4052 Old 01-20-2013, 05:02 PM
ElectronicTonic's Avatar
Quoted: 65 Post(s)
Liked: 106
"Picture Quality" = "PQ"
ElectronicTonic is offline
post #2633 of 4052 Old 01-20-2013, 05:25 PM
tgm1024's Avatar
Liked: 2264
I seem to stand alone in this, but I think that TV's above the fireplace look completely tacky. A fireplace is a quaint idea---a romantic and picturesque throwback to old. A flat screen TV above that? We'll soon look back on this with the same chuckle we now do toward other out-of-vogue ideas like people walking around with bluetooth ear pieces just in case they get a call, people walking around with the radio they pulled out of their car, and big-hair bands dressed up in something close to women's clothing.
-Mad Sweeney
tgm1024 is offline
post #2634 of 4052 Old 01-20-2013, 06:45 PM
tampa8's Avatar
Quoted: 225 Post(s)
Liked: 153
Verne Yip??
tampa8 is offline
post #2635 of 4052 Old 01-20-2013, 08:44 PM
tgm1024's Avatar
Liked: 2264
Originally Posted by tampa8 View Post
Verne Yip??
I had to google that to know the reference. I'm guessing Vern Yip wouldn't like TV's over fireplaces either, given the decorating suggestions I found, but I don't know.
-Mad Sweeney
tgm1024 is offline
post #2636 of 4052 Old 01-20-2013, 10:30 PM
neocvera's Avatar
Do any manufacturers allow custom labels for inputs? Why isn't this feature standard?
neocvera is offline
post #2637 of 4052 Old 01-20-2013, 11:17 PM
rer420's Avatar
some do, some dont, depends on the tv....check the the tvs spec sheet.
features generally are used to bolster a certain models price so arent always standard across all models if they can use it to up-sell you another model higher.
rer420 is offline
post #2638 of 4052 Old 01-21-2013, 10:29 AM
splattered's Avatar
***UPDATE ON MY REPAIR
The Service Center that will be repairing my TV just told me over the phone that they still do not have an ETA on the replacement panel for the television and suggested i call LG again to ask then whats going on with the order.
I called LG a minute ago and they confirmed that the replacement panel is NOT available so they shipped out a "Sub Part" today that "Should also fix the problems on your TV" ... it was explained to me that when an OEM part is not available they have a list of secondary parts they can ship out in their place to fix things.
Uhhhh am i getting some lower end crappier panel put into my brand new TV?
I just called the Service Center and they said they have no idea if that is the case or not and that i have to take it up with LG if i want more specifics on the replacement panel i'm receiving.
Does anyone here have experience with this? I'm worried now... haha
Also,
I occassionally use my 7600 to stream xvid videos from my PC to TV and it works great... but last night i was tinkering around in the settings and i hit erase history of recently watched and recently added.
Then i backed out and discovered that a ton of videos aren't showing up in my list now... all the recent stuff. hahahah Crap!
Is there a way to rebuild the library so i can see all videos again?
splattered is offline
post #2639 of 4052 Old 01-21-2013, 01:48 PM
Mayjer's Avatar
How are you streaming from the PC to the TV? Wired or wifi? I'm just curious as I'd like to try
Mayjer is offline
post #2640 of 4052 Old 01-21-2013, 02:05 PM
tampa8's Avatar
Quoted: 225 Post(s)
Liked: 153
A sub part means they are replacing the actual part that is most likely giving the problem rather then replacing the whole panel. The reason they don't usually do that anymore is it's a guess as to what the problem is, or it can be more than one part giving the problem, where simply replacing the panel addresses most anything that was wrong. The panel then would get back and it's there where they fix the one sub part. It has nothing whatsover do to with it being inferior.
tampa8 is offline
Reply LCD Flat Panel Displays
Lg Cinema Screen 55lm7600 55 Inch Cinema 3d 1080p 240 Hz Led Lcd Hdtv , Led Hdtv , Displays , Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver , Lg Nb3520a Sound Bar Audio System With Wireless Subwoofer Bluetooth Streaming , Samsung Un55d7000 55 Inch 1080p 240 Hz 3d Led Hdtv Silver
