I have general tv hook up question? Please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-15-2012, 07:12 PM - Thread Starter
elykoj's Avatar
This is a cable setup question? I am giving my current tv to a friend and I have a general cable hook up question. First off the tv is a Sony 42 KDF-42A10 rear projection LCD. She will be running basic cable from coax straight to tv with no cable box. Will she get local channels from this in digital/HD ? Or do we need to hook up an HD antenna as well? If so what kind of setting do I need to set on the tv to get the cable and the antenna? Thanks guys
elykoj is offline
post #2 of 10 Old 03-15-2012, 08:49 PM
Latinoheat's Avatar
Quoted: 1159 Post(s)
Liked: 962
Depending on your cable provider you will get sd channels with just cable to tv. Usually HD channels need a hd box, assuming the tv is 720p or 1080i. you will get HD channels. If you don't want to pay for cable, an over the air HD antenna will get you digital/HD channels for free depending where you live.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, HTPC, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC,Klipsch Reference R-62II,Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #3 of 10 Old 03-15-2012, 09:11 PM
Phil Tomaskovic's Avatar
Quoted: 175 Post(s)
Liked: 33
Actually you should get local HD channels also. When you hook up the cable, do a scan for digital channels and you should see them.
Phil Tomaskovic
Phil Tomaskovic is online now
post #4 of 10 Old 03-16-2012, 05:46 AM - Thread Starter
elykoj's Avatar
So do a cable scan and dtv scan as well? Do both?
elykoj is offline
post #5 of 10 Old 03-16-2012, 07:16 AM
topr's Avatar
If I'm not mistaken that display is a few years old and this is what you need to know. If the display has an ATSC tuner you can OTA HD with any simple antenna, it doesn't have to be an HD antenna. To get HD with basic cable straight from your wall your TV needs a QAM tuner.
topr is offline
post #6 of 10 Old 03-16-2012, 07:50 AM - Thread Starter
elykoj's Avatar
Sorry..my bad
elykoj is offline
post #7 of 10 Old 03-16-2012, 07:57 AM
mdavej's Avatar
Quoted: 2277 Post(s)
Liked: 992
Originally Posted by elykoj View Post
I have a problem... I just looked at rear panel of this tv and there is no coax port to plug thr cable wire into? I don't have a stb just a cable from wall. Do I have any options beside getting a stb for this?
According to the manual it DOES have coax inputs. Looking at the back of the set they're on the far left. All other connections are on the right.
It also has both ATSC and QAM digital tuners as well as NTSC. So you'll get all basic analog channels and in-the-clear HD channels as well as all digital channels over the air if you connect an antenna. So just connect the coax, do an analog and digital scan, and you'll be good to go.
mdavej is offline
post #8 of 10 Old 03-16-2012, 07:58 AM - Thread Starter
elykoj's Avatar
I see it now.. Sorry. I am at work and just pulled up picture online and didn't show far left of tv...oops
elykoj is offline
post #9 of 10 Old 03-16-2012, 08:03 AM
putox1051's Avatar
Send a message via AIM to putox1051 Send a message via Skype™ to putox1051
I've got the same TV. It does have a coax input, & depending on your service provider, you should be able to receive the local HD channels using the built-in QAM tuner.
putox1051 is offline
post #10 of 10 Old 03-16-2012, 08:04 AM - Thread Starter
elykoj's Avatar
It does have a Clear QAM cable tuner, and 8 VBS,ATSC,NTSC Terrestial tuner.
elykoj is offline
Reply LCD Flat Panel Displays
