Samsung brightness - AVS Forum | Home Theater Discussions And Reviews
Old 03-16-2012, 03:28 PM - Thread Starter
Beckler's Avatar
So every time I see Samsungs in the store (6000, 8000 series that I recall), they always seem about twice as bright as anything else, with bright colors too. Is this just some well known fact, and does it come at the expense of picture quality or contrast or something? Or am I just seeing things. If not, then why not automatically all get samsung?
Beckler is offline
Old 03-16-2012, 03:51 PM
HaRd2BeAr's Avatar
Liked: 36
Brightness isn't everything, if it looks bright in a store under heavy lighting then it will be much to bright for comfortable home use.
In store Samsung and most tvs are in shop mode/vivid mode and that has the backlight ramped up and colours to make the picture pop and attract customers. Yes generally vivid/dynamic mode for home use, will show up any uniformity defects in the screen, so edge bleed or clouding. Also it will wash out blacks on the tv making blacks look blue tinted (all of this will not be noticeable in a store under heavy lighting) Usually switching to movie mode and tweaking the backlight will bring a huge improvement over the vivid/dynamic default.
It wont cause any long term damage other than maybe wear to the backlight and extra heat build up for the internal components.
Aaron
HaRd2BeAr is offline
Old 03-16-2012, 06:01 PM - Thread Starter
Beckler's Avatar
Well it's always samsung, no matter what store I go to. Unless they ship with default full brightness or something. And you can't have too much brightness though. You can always turn it down. If your living room is bright from windows, then the brighter the better for your tv, I say...
Beckler is offline
Old 03-16-2012, 06:11 PM
fatuglyguy's Avatar
Quoted: 277 Post(s)
Liked: 606
I think the mistake is equating a "brighter" picture with a "better" picture. All modern LED/LCD sets are more than bright enough for home viewing. Having the brightest possible picture, I suppose, is good if you like an unnatural, washed-out looking image that blows out highlights and fine details in HD images.
desktop Sonus faber Toy monitor| REL T Zero| Sony UDA1|Sony MDR-Z7|Audioquest Nighthawk|Audioquest Dragonfly Red
surround Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Panasonic 60ZT60|Oppo 103D|Sonos Connect + Peachtree Audio DAC•iT
stereo Sonus faber Toy tower|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony BDP-S1700ES|Pro-Ject Debut Carbon DC Esprit + Tube Box S|Sonos Connect|Furman Elite-15 PFi
fatuglyguy is offline
Old 03-16-2012, 06:40 PM
HaRd2BeAr's Avatar
Liked: 36
Not really sure you read my post to be honest.
Exactly, brighter isn't better when it comes to choosing an led - lcd. They have already reached a point where enough is enough ie any more is just plain excessive. Just because the Samsungs look brighter in store doesn't instantly equate to a better tv. There are many more important things to consider and some where Samsung led - lcds fall short.
Aaron
Old 03-16-2012, 07:25 PM
jamesgsxr1000's Avatar
Samsungs inherently also have some of the worst backlight bleeding I have ever seen on a television which is becausE of the excessive brightness....that is why I went with the Sony NX720. Plenty bright with dimming makes a great picture.
jamesgsxr1000 is offline
