Samsung UN40EH6000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-20-2012, 12:22 PM - Thread Starter
White Noise's Avatar
I did a search and didn't find any threads on this TV. I recently bought this to put in my home theater room as a PC monitor (Not for TV and movies as my Epson 8350 handles those duties.)
If you don't want/need 3D, or web connectivity (smart-TV) then this TV might be for you. It doesn't have the super slim body but it does have a slick style and lets face it the picture is whats important. After calibration this TV has greatly impressed me. Very good solid blacks and whites. Colors pop but are natural at the same time.
It's a 120Hz TV and PC gaming is beautiful No issues at all. I have to say I was looking for a monitor to replace my old Westinghouse 37" LCD for PC duties and I couldn't be happier. I own 5 HD TV's now including this new Samsung and one HD projector and its been a very pleasant surprise. I expected a good screen and got more for my money. Sure this model is a more stripped down unit but if you don't need all the bells and whistles then this might be the right TV for you. At $779 you could do worse.
Some specs and pictures:
Features:
40" screen (measured diagonally)
glossy screen with black bezel and cabinet
tuner receives over-the-air HDTV broadcasts (antenna required)
QAM cable TV tuner (subscription required to receive cable channels contact your local service provider for details)
LED edge backlight for high picture contrast
5,000,000:1 dynamic contrast ratio
Clear Motion Rate 240 blur reduction (120Hz refresh rate plus backlight scanning)
built-in stereo speakers (10 watts x 2)
remote control
Anynet+ simplifies control of compatible Samsung components via the HDMI connection (HDMI-CEC)
meets ENERGY STAR® requirements
picture settings memory for each video input
Connections and Dimensions:
3 A/V inputs, including:
1 component video (selectable component/composite)
2 HDMI v1.4
RF input for antenna/cable signals
optical digital audio output
stereo minijack output for connecting a sound bar or home stereo system
USB port for connecting a camera or thumb drive
detachable swivel stand
wall-mountable (bracket not included)
36-1/2"W x 22"H x 3-3/4"D (24"H x 9"D on stand)
weight: 24.7 lbs. with stand; 20.3 lbs. without stand
warranty: 1 year parts & labor in-home service
White Noise is offline
post #2 of 8 Old 03-20-2012, 01:21 PM
Test Pattern's Avatar
Here's the already existing thead for the entire EH6000 series (no need for a separate thread for each available size):
http://www.avsforum.com/avs-vb/showt...ung+unxxeh6000
Test Pattern is offline
post #3 of 8 Old 03-20-2012, 02:20 PM - Thread Starter
What part of "I did a search and didn't find any threads on this TV" did you not understand? I searched the model and nothing came up.
A mod or admin can delete or lock this thread.
And thanks for pointing me at the correct thread.
post #4 of 8 Old 03-20-2012, 03:15 PM
My pleasure.
And I understood every part of "I did a search and didn't find any threads on this TV," which is why I pointed out this forum's convention of threads being devoted to a TV model series without respect to particular screen sizes.
Next time, try substituting "xx" for a particular screen size (e.g., 40) when you search for a TV model number, and you'll be amazed at what turns up.
post #5 of 8 Old 03-20-2012, 03:41 PM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
Or, you can really simplify it by just typing EH6000 into the search box and the "official" thread comes right up.
BoilerJim is offline
post #6 of 8 Old 03-20-2012, 03:59 PM
^ Even better.
post #7 of 8 Old 03-28-2014, 01:51 PM
gloege's Avatar
Quoted: 93 Post(s)
What settings do you have yours at cause hooked up to my pc via nvidia and hdmi has whites that blind me no matter what I do
Strings are attached to my broken kneck holding it up high.
gloege is offline
post #8 of 8 Old 04-16-2014, 08:46 PM
gloege's Avatar
Quoted: 93 Post(s)
found out after talking to samsung that a factory reset wont hold to a picture reset.  if you have updated firmware and/or blown out blacks and whites a picture reset may help.  also a factory reset might be the finishing touch
gloege is offline
Reply LCD Flat Panel Displays
Samsung Un40eh6000 40 Inch 1080p 120 Hz Led Hdtv Black , Samsung Un40eh6000 40 Inch Led Hdtv
