Do any LCD TV's have an external power supply? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-29-2012, 01:02 AM - Thread Starter
ggking7's Avatar
Do any LCD TV's have an external power supply? This means the power cable has a wall wart or a black box built into it. I'd like to try powering a TV via A123 batteries but I need it to have an external power supply so I can provide DC.
If you do know of a TV with an external power supply, do you know the voltage and current it provides? Even an approximation would be helpful.
ggking7 is offline
post #2 of 10 Old 03-29-2012, 05:08 AM
ShopJimmy's Avatar
What size TV are you trying to power? We see a lot of smaller units (<26") with external power supplies, they vary by model from 12v-19v. I'm sure there are some 32" TVs out there as well but I can't think of anything off hand. If you want any info off one of the power supplies let me know.
Jimmy Vosika
Director of Partology
ShopJimmy.com
ShopJimmy is offline
post #3 of 10 Old 03-30-2012, 12:37 AM - Thread Starter
ggking7's Avatar
Thanks a lot for your reply. I'm looking for the biggest TV possible with an external power supply. Do you have any suggestions on how to find these sort of TV's?
ggking7 is offline
post #4 of 10 Old 03-30-2012, 06:07 AM
ShopJimmy's Avatar
Technically Sharp makes them up to 60" now but I dont know if they hit the market yet. We saw these at CES and it was pretty incredible. Google "Sharp FreeStyle".
As for whats currently on the market, I would just walk into a retail store and start peaking behind the units for the external power supply.
post #5 of 10 Old 04-03-2012, 02:25 AM - Thread Starter
ggking7's Avatar
I suppose walking into the store and looking for external power supplies is my best bet, thank you.
It looks like the 20" Sharp Freestyle actually has a built-in battery so the concept isn't too far-fetched.
ggking7 is offline
post #6 of 10 Old 04-03-2012, 05:52 AM
gregzoll's Avatar
Liked: 33
The largest set you are going to find with a external power supply is around 20", and those are usually TV/Computer monitors. There are no larger sets with external power supplies, that you could afford or buy, since most of those are seen in arenas or on billboards.
gregzoll is offline
post #7 of 10 Old 04-03-2012, 07:42 PM
MickeyM's Avatar
How long do you intend to power a TV using the battery you mentioned? If you don't intend to convert the battery voltage, you'll need to wire the batteries in a series/parallel fashion. Even for a small set something on the order of 20" you'll likely going to need a doz batteries and power for ~ 1hr. depending upon what input voltage needs to be, could take more than a doz cells. Not going to be a low cost battery pak, that's for sure.
MickeyM is offline
post #8 of 10 Old 04-03-2012, 08:20 PM
Truckondo's Avatar
Quoted: 13 Post(s)
Most Westinghouse LCD units I setup have a power brick. It's always interesting to wall mount one of those.
Truckondo is offline
post #9 of 10 Old 04-04-2012, 02:21 AM - Thread Starter
ggking7's Avatar
Even large Westinghouse TV's have external power supplies?
ggking7 is offline
post #10 of 10 Old 05-07-2014, 03:25 AM
hunterfield's Avatar
hunterfield is offline
Reply LCD Flat Panel Displays
