Anyone gone from a 50 to a 55??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 03-29-2012, 07:28 PM - Thread Starter
6SpeedTA95's Avatar
Quoted: 145 Post(s)
Liked: 45
Just curious if anyone has gone from a 50 to a 55? Was the size jump really worth it?
As some of you know I'm looking to upgrade my 5080HD, I do love the XBR 929 but was ultimately hoping for a 60.
However, it now appears the Sharp 945 may no longer be offered this year. LG's LM9600 may or may not be offered in 60 depending on what you read and will not be NANO. It's looking like my 60 inch options are going ot be quite limited.
Picture quality is extremely important coming from a Pioneer and I can't do a 65 in my living room, it just will not work. Ultimately, if the 60's are not going to be available should I consider a move to a 55? Should I wait it out yet another year?
Full array local dimming is a must and the Elite is just too expensive to justify at this point.
6SpeedTA95 is offline
post #2 of 14 Old 03-29-2012, 10:25 PM
AMartin56's Avatar
Quoted: 1001 Post(s)
Liked: 403
Never in the history of mankind has anyone gone from a 50 to a 55...
Sorry...I couldn't resist.
Home Theater: JVC RS 420, Yamaha RX-V673, NHT Super Ones/Zeroes w/Ten Sub,
Sony BDP-S5500, Darbee Darblet and Monoprice 130 inch 2.35:1 White Material Screen
Living room: Sony 60NX720, VIZIO SB4051-C0 Other: Samsung 51F8500
Displays calibrated with HCFR, i1DisplayPro, and Colormunki Photo.
AMartin56 is online now
post #3 of 14 Old 03-29-2012, 11:39 PM
desol007's Avatar
It makes a difference, but I would go 60 it makes more of a difference
desol007 is offline
post #4 of 14 Old 03-30-2012, 12:05 AM
t-type86's Avatar
I went from a 52 to a 55 and It made a difference. Wish I went to a 60 though but couldnt find a 60 I wanted for the price I was willing to pay.
t-type86 is offline
post #5 of 14 Old 03-30-2012, 05:00 AM - Thread Starter
6SpeedTA95's Avatar
Quoted: 145 Post(s)
Liked: 45
I agree 60 is ideal but I'm not taking a step back in PQ.
post #6 of 14 Old 03-30-2012, 05:31 AM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
So you are asking if anyone has gone from a 50" PLASMA (since there are no 50" LCDs) to a 55" LCD?
God, I hope so.
BoilerJim is offline
post #7 of 14 Old 03-30-2012, 05:35 AM - Thread Starter
6SpeedTA95's Avatar
Quoted: 145 Post(s)
Liked: 45
God, I hope so.
Yeah I have a Plasma, why? I don't really see how relevant that is because I don't want to get sucked into a whole Plasma vs LCD debate at the moment.
They do make 52 inch LCD's and there are a few companies that had 49's at one point. I know the screen size is obviously bigger on the 55 just wondering if it's "Worth it" if that makes sense. The 55 XBR929 is getting pretty cheap and the LM9600 is up in the air as far as size goes...kicking around the idea of picking up a 929 in May if htese other 2012 sets dont materialize.
Panasonic made some pretty big leaps in PQ this year on their Plasma side so that may also be worth looking at...
post #8 of 14 Old 03-30-2012, 06:10 AM
bekindrewind's Avatar
Quoted: 132 Post(s)
Liked: 58
Sony and Samsung starting in April will not allow discounting of their higher end units. If you're thinking about the Sony HX929, that great deal out now, will end in two days. Then it's back to map....minimum acceptable price structure their talking about. No more discounts anywhere, brick and mortar or online. If you can not afford the sharp Elite, then the next best set will be the Sony your thinking about. Always go for the biggest size you can fit, as long as the pq is great.
PRO-70X5FD, McIntosh MC205, Marrantz MM8077, Marantz AV7702MKII (7.1.4), Oppo UDP-203, Oppo BDP-93, JL Audio f113, B&W Nautilus, Richard Gray 400S, Harmony One
bekindrewind is offline
post #9 of 14 Old 03-30-2012, 06:55 AM - Thread Starter
6SpeedTA95's Avatar
Quoted: 145 Post(s)
Liked: 45
I will discuss that with my wife.
post #10 of 14 Old 03-30-2012, 08:58 AM
761-honda's Avatar
I have a 65 Panasonic s2, great size crappy pic
761-honda is offline
post #11 of 14 Old 03-30-2012, 09:31 AM
PlasmaPZ80U's Avatar
Quoted: 1967 Post(s)
Liked: 560
it's better to get a superior 55" than a lesser 60"
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #12 of 14 Old 03-30-2012, 09:57 AM
r2crd's Avatar
I did. From a LG 50" plasma to a 55HX929. To be honest I didn't notice the size increase.
r2crd is offline
post #13 of 14 Old 03-30-2012, 10:02 AM
Liked: 560
5" inches at the size range isn't a whole lot, but PQ should be much better
post #14 of 14 Old 03-30-2012, 12:06 PM
reverse's Avatar
Honestly, your only choice for a full array local dimming 60" is the Elite unless you would like to go with a plasma again. The difference between a 50 / 55 isn't much but should be somewhat noticeable. However if you did get a 55, just keep in mind that the difference between a 55 / 60 isn't much either.
If you're looking at better immersion from a 50 to a 60, you'll get some but in all honesty it's irrelevant until you start getting in the 70"+ range.
reverse is offline
Reply LCD Flat Panel Displays
