LG 47LE5400 won't turn off-help please! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-31-2012, 07:09 PM - Thread Starter
TinaMarie71's Avatar
Please help! My father-in-law has a LG 47LE5400 TV that has suddenly stopped responding to the remote and won't turn off at the screen either. We turned it off at the power supply and when turned back on the menu option comes up momentarily then disappears. You can't change channels etc when it is acting this way or access the menu screen from the tv selection or remote. After some time (maybe 30 minutes or so) the remote will then start responding and the options on tv (volume, on/off, menu) respond if you press them as well.
My husband I have tried everything and have never seen a TV act so odd. Has anyone else had a similar problem? Please post if you have as my elderly father-in-law is going to drive us crazy if we cannot find the source of this problem!!!
TinaMarie71 is offline
post #2 of 13 Old 03-31-2012, 07:15 PM
KONICA TECH's Avatar
Quoted: 30 Post(s)
Liked: 55
Have you tried the buttons on the TV? Do they respond properly?
Smetimes people use spray cleaners on the remotes or TV which can cause this like spilling a soda on a computer keyboard.
KONICA TECH is offline
post #3 of 13 Old 03-31-2012, 08:18 PM - Thread Starter
No response from the buttons on the TV either. Brand new batteries in remote. It just becomes frozen. My husband wonders if his dad didn't accidentally lock something up using the remote. Nothing in the manual helps. We're just stumped.
post #4 of 13 Old 03-31-2012, 09:20 PM
Quoted: 30 Post(s)
Liked: 55
My advice is to call LG and see if there is a set of buttons to reset the factory defaults on that model. Hope this helps
Try searching here as this problem has happened before
http://www.avsforum.com/avs-vb/showt...t#post20252808
post #5 of 13 Old 04-01-2012, 07:47 AM - Thread Starter
Thanks! We'll see if LG can help on Monday and reset it.
post #6 of 13 Old 04-01-2012, 08:10 AM
EG3
EG3's Avatar
It sounds like a button is stuck. It is probably the menu button since when you unplugged/plugged in the set, the menu came up.
EG3 is offline
post #7 of 13 Old 04-02-2012, 01:13 PM
CGGorman's Avatar
I had the same problem (and more) with the same model TV.
Unplug it for a minute and plug it back in.
In my case it was (is) the CEC feature available to all HDMI connected equipment. Disable any feature that allows remote control over HDMI. The feature is called something different by every manufacturer (dammit), but its usually something with a "link" or "net" or "smart" in the name. Once i disabled the HTPC, PS3, and Blu-ray player the problem went away.
CGGorman is offline
post #8 of 13 Old 04-07-2013, 06:00 PM
maine94's Avatar
So what happened because I am having this same exact problem and I dont want to spend a ton of money on a tv.
maine94 is offline
post #9 of 13 Old 04-07-2013, 06:44 PM
RollTide2011's Avatar
Quoted: 118 Post(s)
Liked: 95
You might want to try a cheap universal remote see if you get any response
RollTide2011 is offline
post #10 of 13 Old 07-13-2014, 08:08 AM
kanthn's Avatar
Liked: 0
I have the same problem
I stumbled across this thread while researching to troubleshoot similar problem with the same model LG TV. After lot of digging I found one link where few folks appear to have to found the problem to be with the front bezel of the TV. The IR receiver is embedded in the front bezel. The defect in this IR receiver makes the TV go nuts with all sort of strange behavior - randomly changing input types, volume, channels - anything the remote could control; except it's all random and you can't do anything about it because the remote or the buttons on the bezel will not work anymore. You have to pull the power cord! The solution is replacing the front bezel. Unfortunately I am not under warranty and most likely will end up buying a new TV. It has come to a state that it happens all the time and has become unbearable. I see this third has been dormant for about 2 years. I hope my reply still helps you.
kanthn is offline
post #11 of 13 Old 09-12-2015, 07:48 AM
Liked: 0
Thank you CGGorman for your post. I saw a similar solution on another forum. I have an LG 55LX6500 which had the same problems. I have Time Warner cable connected by HDMI to an Onkyo 5.1 surround sound receiver, then to the LG flat screen. After turning them all on, the TV worked fine for a while, then all buttons would light up on the TV and I was unable to use any TV functions - volume, input, power, etc. Sometimes the volume would increase to the maximum on its own. I was unable to turn off the TV even after turning off the Cable and Receiver, and was forced to unplug it. After plugging it back in it turned on by itself. Leaving the other units off, I selected the Simplink button which showed the option "On" - I switched this to "Off" and turned off the TV. Turning everything back on, the TV now works and I have not had the problem recur. I'm still monitoring it as I did this only last night, but so far no issues.
Moose1125 is offline
post #12 of 13 Old 09-23-2015, 05:34 PM
Liked: 0
Spoke too soon - Simplink turn off not the answer.
Still having turn off issues. No longer having volume increase randomly but it seems if I change channels or use the Cable guide, it lights up all buttons on the LG and won't turn off - have to unplug.
post #13 of 13 Old 12-21-2015, 10:48 AM
Liked: 0
Did you manage to find the real issue, i am also having the same problem, can't turn on/off from magic remote or tv physical buttons. Everything seems same in my case also.
Earlier had Uverse from AT&T from last few years never had this issue, moved to TWC last month and started having this issue from last 2 weeks.
I did take it to a repair shop and on their shop everything started working magically.
I do remember earlier i had magic remote configured to use the Uverse cable box not sure if it uses the simple link.
I will try the simple link option and will keep the cable box disconnected and turned off to see it it works.
sanddeepkumar08 is offline
Reply LCD Flat Panel Displays
Lg 47le5400 47 Inch 1080p 120 Hz Led Hdtv With Internet Applications , Blu Ray Players , Playstation 3 160gb System
