Is 2012 LG LS5600 IPS? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-04-2012, 04:20 AM - Thread Starter
Glottiz's Avatar
Hi, anyone know anything about the new LG LS5600? Is it IPS? Does it support 4:4:4? Thanks.
Glottiz is offline
post #2 of 10 Old 04-04-2012, 09:08 AM
Otto Pylot's Avatar
Quoted: 1577 Post(s)
Liked: 984
Have you seen one in a local B&M? If so, just do a loupe test to check out the pixel pattern and note the entire product code in case LG has changed the letter in the fourth position of the product code ("W" for 2010 and "Y" for 2011). Apparently there is also a way to determine the panel type by looking thru the air vents in the back of the tv and noting the panel type code. You can then look it up on a site (don't have the url handy) which is supposed to give a detailed listing of the panel specs based on the panel code. Don't know how accurate it is though.
As far as 4:4:4 goes, you'll probably need the manual so see if it's listed or just call LG support.
Otto Pylot is offline
post #3 of 10 Old 04-14-2012, 12:50 AM
k735123's Avatar
Hi,
I bought 47LS5600. In my opinion it has "<<<" IPS panel (I did loupe test).
SN: 203wrcy2n523 W/O: 231d04cb
hdguru.com/ces-2012-lgs-hdtv-line/7018/
lg.com/ca_en/products/documents/LS5600_Series_Spec_Sheet_ENG%20Final.pdf
k735123 is offline
post #4 of 10 Old 04-14-2012, 11:37 AM - Thread Starter
Glottiz's Avatar
Good to hear. I'm interested in 32LS5600 and using it as computer monitor /movies / pc gaming / consoles. Does it have 4:4:4 and low input lag?
Glottiz is offline
post #5 of 10 Old 04-14-2012, 03:13 PM
Otto Pylot's Avatar
Liked: 984
Originally Posted by k735123 View Post
Yes it is "<<<" IPS
I have 47LS5600.
Excellent! Congratulations What is the complete product code? We need to see what the fourth letter is for reference.
post #6 of 10 Old 04-23-2012, 03:03 PM
Daredevil_pt's Avatar
How about some thoughts about her?? Are you satisfied?? Any light leaks in the frame that you noticed??
Daredevil_pt is offline
post #7 of 10 Old 06-15-2012, 06:11 PM
Iscariath's Avatar
Bumping this, I want to know more about this model. Uniformity, ghosting ?
Iscariath is offline
post #8 of 10 Old 07-08-2012, 12:01 AM
Nemix77's Avatar
I just ordered a LG 37LS5600 Canadian model and the TV should be arriving by Wednesday next week.
Edit:
From what I've read on translated European forums the LS5600 series in PAL 50Hz has a S-MVA/A-MVA panel and not IPS. I'm not sure if these applies to Canadian models since Canada is NTSC 60Hz but I'll check and reply when the TV arrives next week.
Nemix77 is offline
post #9 of 10 Old 07-26-2012, 12:46 AM
nickdc's Avatar
Any news?
nickdc is offline
post #10 of 10 Old 01-13-2014, 05:28 AM
Little Drinker's Avatar
Judging by what it says in the text panel on this TV is IPS. I have this TV and pixels are in this form ">".
http://www.digitalversus.com/tv-television/lg-47ls5600-p14226/test.html
Little Drinker is offline
Reply LCD Flat Panel Displays
