Official Samsung UNXXES6100 Thread - Page 29 - AVS Forum
post #841 of 864 Old 02-04-2014, 07:28 PM
ajohn505's Avatar
Im loving this TV other than for a dramatic dimming that occurs during dark scenes. I run primarily in game mode. Anyone have tips?
ajohn505 is offline
post #842 of 864 Old 02-18-2014, 06:42 PM
Hectorcaliente's Avatar
Right balance of brightness and contrast can almost eliminate it completely. Movie mode is the only option that disables the dimming.
Hectorcaliente is offline
post #843 of 864 Old 03-13-2014, 05:58 PM
New firmware 002001 is out. First though, motion quality improved for my set. Firmware 001037 was bad.
post #844 of 864 Old 03-13-2014, 06:30 PM
Edo Glvez's Avatar
Edo Glvez is offline
post #845 of 864 Old 03-14-2014, 07:05 AM
heresnowhy's Avatar
Liked: 33
Sweet! Thanks!
heresnowhy is offline
post #846 of 864 Old 03-14-2014, 05:51 PM
Edo Glvez's Avatar
Change log is up
This firmware is for TV Model(s):EH4500 / EH5300 / ES6100-7150
The version is 2001.3
This firmware update will improve the following:
- Resolves Black when running Netflix.
- Resolves the issue that TV changes the source or picture size after exit from Nextflix.
post #847 of 864 Old 03-14-2014, 06:58 PM
heresnowhy's Avatar
Liked: 33
Originally Posted by Edo Glvez View Post
Change log is up
Now, if only they would release a new firmware for my 6300's....and fix the exit from Netflix source issue no those.....
Is actually quite a long change log...
- Resolves issue Netfilx doesn''t log on
- Support Samsung Link
- Support Verizon Apps
- Support Netflix 3.2 codec
- Resolves picture shaking and line noise on 1080p source.
- Supports Yahoo SyncPlus app..
- Resolves escaping issue while watching movie on VUDU.
- Resolves issue Cinemanow does not play certain title.
- Resolves compatibility issue with DLNA devices.
- Improves picture quality.
- Supports Samsung wireless audio dock (WAD) - * series ES6500 and above only
- Solves the problem closed caption does not show.
post #848 of 864 Old 03-14-2014, 09:59 PM
Edo Glvez's Avatar
They just add the latest changes to a shared change log so actually only the first two items belong to the latest fw.
post #849 of 864 Old 03-17-2014, 06:22 PM
heresnowhy's Avatar
Liked: 33
Looks like they rolled it back. .....
post #850 of 864 Old 04-04-2014, 09:22 AM
heresnowhy's Avatar
Liked: 33
Finally updated the new software. No matter how long I tried to get the online update to get me the new firmware, it refused to find it. Finally did it via USB and low and behold; The New Netflix!
post #851 of 864 Old 04-17-2014, 12:22 PM
mizunox's Avatar
What does the new Netflix look like?
I updated but my netflix looks the same - when I check the version it's from 2013.
mizunox is offline
post #852 of 864 Old 04-17-2014, 12:57 PM
heresnowhy's Avatar
Liked: 33
I have several ES6100/6150 models. Only one of them updated via the online method. The others required me to update via USB as they for reasons unknown couldn't detect an available update, though it was posted on Samsung's website. After said updates, they all now have the new version of Netflix and it functions just fine, though bootup is marginally slower.
post #853 of 864 Old 04-19-2014, 01:51 PM
mizunox's Avatar
Would you mind telling me the version number of your Netflix app?
Mine is 3.10501 and it hasn't changed in a long time.
If you hit the INFO button with Netflix highlighted it'll tell you.
My TV did update to 002001 online.
mizunox is offline
post #854 of 864 Old 04-19-2014, 09:17 PM
heresnowhy's Avatar
Liked: 33
4.004
post #855 of 864 Old 04-21-2014, 12:00 PM
expressmoria's Avatar
I also have v3.10501 version of Netflix, the one does not support multiple user profiles.
Never saw 4.004 so not sure if this recent version is model or country dependent.
My TV smart hub firmware is up to date.
expressmoria is offline
post #856 of 864 Old 04-21-2014, 03:43 PM
heresnowhy's Avatar
Liked: 33
I'm in the U.S. I have a 55ES6150 and a 46 and 50 ES6100 that all have 4.004 on them. I had to download the update from Samsungs website via USB to get them. It is the newest version of Netflix with multiple user profiles.
post #857 of 864 Old 05-07-2014, 01:49 PM
c0nquistad0rian's Avatar
My UN60ES6100 TV stopped recognizing that an Anynet+ device is connected when the soundbar is connected with an HMDI cable via ARC. The soundbar LCD indicator on the soundbar says TV ARC, indicating that it is connected to the TV and audio is coming from the soundbar but I cannot control the soundbar's volume with the TV remote. Background: I have the 6100 connected to a Samsung HW-E450 Soundbar. I have had the TV for over a year and got the soundbar about a month ago.
I have everything set up like so:
TV:
HDMI 1: comcast DVR
HDMI 2 (ARC): Soundbar
HDMI 3: Netgear Push2TV
Soundbar:
HDMI Out (ARC): to TV
HDMI In: Bluray player
When watching cable TV (HDMI 1) or wirelessly connecting my laptop via the Push2TV (HDMI 3), audio projects through the soundbar via ARC. When watching a Bluray movie (HDMI 2), I change the input on the Soundbar from D. In (ARC) to HDMI and audio projects through the soundbar.
This set up worked fine out of the box and for the first month of having the soundbar. The only hiccup that existed was that the soundbar would not turn on when turning on the TV but that is a known issue when pairing these two specific devices. I would just turn the soundbar on with the soundbar remote. Sometimes it would say D. In rather than switching directly to TV ARC in which case, I would have to press the Anynet+ button on the soundbar remote twice (first to turn off Anynet+ and then again to turn it on).
Last night when trying to adjust the volume with the TV remote, a message popped up on the TV that reads, "Anynet+ device is not connected. Please check connection and retry." This despite the fact that soundbar LCD display still reads "TV ARC" and sound is projecting through the soundbar.
I checked the TV's Anynet+ (HDMI-CEC) settings under the System menu. Anynet+ on the TV is still turned on. Auto Turn Off says yes. Receiver is grayed out and says Off. I pressed the Anynet+ button on the soundbar remote twice (again, first to turn it off and then to turn it back on). When I did this, Anynet+ menu on the TV says Receiver On. However, if I highlight and click on Receiver, the setting just changes to Off and I cannot switch it back to the On setting and I get the same message as above.
Taking things one step further, sometimes I can get to an Anynet+ Device List menu on the TV from which I can refresh the Anynet+ connection, which is either unsuccessful (and results in the same message on the TV) or pulls up an option entitled "Player" which will just switch the input to HDMI 2 if I click on it.
Anyone else have this issue of their Samsung TV 'losing' their Anynet+ soundbar? If so, how do I get it back?
c0nquistad0rian is offline
post #858 of 864 Old 05-07-2014, 07:02 PM
heresnowhy's Avatar
Liked: 33
TV:
HDMI 1: comcast DVR
Soundbar:
Mine randomly drop Anynet devices...sometimes for a day or so. They always start working again. to force it, try disconnecting the Soundbar and powering everything off. Power on the TV by itself and use the TV speakers.... Then plug in the Soundbar and proceed to Tools/Anynet/refresh... usually wakes my stuff up. For what it's worth, all three of my es6100's exhibit this misbehaviour as well as my F6300 and 7100.
post #859 of 864 Old 05-22-2014, 09:44 AM
barbudo2005's Avatar
Hi,
I want to know if it is posible to record a program via antenna (Digital) while viewing a cable program what is Analogic or a digital program stored in a hard disk ( I will use another USB stick to record). I have a UN40ES6100 ?
Thank you very much in advance
barbudo2005 is offline
post #860 of 864 Old 06-04-2014, 02:46 PM
mizunox's Avatar
Has anyone tried using HDMI-CEC with this TV?
I've been told that with HDMI-CEC you can use the TV's IR sensor and remote to control external devices that are connected through HDMI - in this case I'd like to control the PS4 and it's netflix app.
mizunox is offline
post #861 of 864 Old 06-04-2014, 04:52 PM
heresnowhy's Avatar
Liked: 33
Yes. I use ARC and CEC on both of my ES models. Controls my H/K receiver volume with the Samsung remote as well as the Samsung Blu Ray player...There is no IR repeater like the F series therefore you still need an STB remote to change channels...
post #862 of 864 Old 07-02-2014, 06:24 PM
Liked: 0
Dual voltage possible?
Hi, anyone has any idea if this TV can be use with 240 voltage? I am relocating and am not sure if I should bring the TV with me. I had checked with Samsung support and the rep says it is not dual voltage. But I do heard from friends that Samsung TVs are actually dual voltage although it did not indicate as so. I tried opening up the back panel and on one of the circuit board fuse has the writing 110-240v.
Fong Cheng Fong Cheng is offline
post #863 of 864 Old 07-11-2014, 04:02 PM
danzio2020's Avatar
New Netflix Interface
Has anyone been able to get the new Netflix interface with 2001.3 on a UN40EH5300?
Edit: Got new Netflix interface by switching to US as my location in smart hub.
danzio2020 is offline
post #864 of 864 Old Today, 05:19 PM
jbeechuk's Avatar
Wifi problem
We just moved, and I cannot get my 6100 to connect to my wifi. What happens is, I go to Network settings, and start the wireless search, but it does not find my wifi network. If I turn the TV off, then on again and retry, it will see the wifi networks, but only for less than a second, then it goes back to the Network menu screen. It just is not enough time for me to see and select it. It is not my router that is the problem. I just bought a 65" Samsung H8000 curved TV, and it found my wifi network instantly. Any suggestions?
jbeechuk is offline
Reply LCD Flat Panel Displays
Samsung , Samsung Un60es6100 60 Inch 1080p 120 Hz Slim Led Hdtv Black , Led Hdtv , Samsung Un55d6000
