Official Samsung UNXXES6100 Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #61 of 883 Old 04-22-2012, 11:55 AM
Centinul's Avatar
Originally Posted by InsuranceWhiz View Post
My settings using Avia. Will calibrate with Disney WOW Friday and post those results.
Settings in Movie mode:
Backlight: 15
Contrast: 95
Brightness: 50
Sharpness: 50
Color: 50
Tint: 50
Dynamic Contrast: off
Black tone: dark
Flesh tone: 0
RGB only: off
Color Space: Auto
Gamma:0
Color tone: Warm 2
Digital Noise filter: low
MPEG Noise filter: low
Film Mode: off
Auto Motion: clear
LED Motion: off
I'm not sure if this is normal or a problem but I have an 40" version of this TV and I set it to the calibration settings mentioned above. I'm noticing something odd now. If I'm watching a scene in a movie or TV that quickly goes from dark to light or vice versa it looks like I can see the backlight turning up and down. It looks like a flicker almost. It looks unnatural. I don't see anything in scenes that have consistent lighting. I looked in the settings and I don't see any dynamic setting on or anything.
This TV is hooked up to a HTPC via HDMI.
The only other change I can think of is I adjusted the input on the TV such that it doesn't think it's a PC. This allowed me to calibrate the settings that are disabled when the TV thinks it is a PC input.
Thoughts?
Centinul is offline
post #62 of 883 Old 04-22-2012, 01:19 PM - Thread Starter
InsuranceWhiz's Avatar
Thoughts?
I haven't noticed it on mine. Some of these Samsungs have an auto-dimming feature. Can anyone confirm if this model has it?
InsuranceWhiz is offline
post #63 of 883 Old 04-23-2012, 05:58 AM
Pirateghost's Avatar
What is SmartView 1 and 2? Thanks.
Pirateghost is offline
post #64 of 883 Old 04-23-2012, 06:55 AM
jmt9779's Avatar
Originally Posted by ghostsup View Post
JMT, what are your router settings? Can you D/L updates? I know the way I have my router setup is that I have to manually input the MAC address under acceptions.
apparently, i couldn't connect because i didn't have the samsung allshare software installed on my computer. so i installed it, but now it's having a problem getting started because of my antivirus firewall on my computer...or something. whatever. i messed with it for a bit last night and thought it would have been a cool feature, but i'm over it at this point.
and i tried my hand at calibrating the display settings with my DVE disc, and i ultimately reverted to InsuranceWhiz's settings. (i really don't know what i'm doing with that stuff and i didn't find DVE to be terribly user friendly to a noob like me, and after all was said and done, my picture just didn't look as good as with InsuranceWhiz's settings.)
jmt9779 is offline
post #65 of 883 Old 04-23-2012, 06:15 PM
Centinul's Avatar
So I did a bit of fiddling tonight. Leaving the settings per my original post if I edit the HDMI input type and set it to "---" the colors look great but there is an annoying flicker and it looks like the backlight auto changes brightness.
However if I set the HDMI input type to "PC" the annoying flicker goes away but the picture looks awful even when using the same settings identified above. There is noticeable clouding for example.
What kind of internal processing is changing just by varying the HDMI input type? I've double checked the settings for each and I can't find any differences.
Centinul is offline
post #66 of 883 Old 04-23-2012, 07:28 PM - Thread Starter
Firmware update available. Not sure what this fixes but it may fix some of the issues above.
post #67 of 883 Old 04-24-2012, 05:35 AM
Centinul's Avatar
I'll try a firmware upgrade tonight. Samsung support recommended I reset the television.
Do these TVs update the firmware over the web? I haven't had a chance to heck the manual yet.
Centinul is offline
post #68 of 883 Old 04-24-2012, 08:11 AM - Thread Starter
Yes. Go to Help and the update option is there.
post #69 of 883 Old 04-24-2012, 08:42 AM
Originally Posted by wlan_router View Post
I am using a Iogear GKM561R without any problem.
I bought that keyboard but was unable to get it to work. I recognized the mouse but not the keyboard.
Update: I did get it working, akwardly, but it does work. I think I was looking for a smooth process but to use the kybd for web browsing, I had to his a yellow key on the remote which brought up a small keyboard on the google page, which allowed for entries vie my wireless keyboard.
post #70 of 883 Old 04-24-2012, 11:03 AM
Do you now what the firmware does? I looked on the Samsung site but it didn't show. Thanks.
post #71 of 883 Old 04-24-2012, 01:08 PM - Thread Starter
Couldn't say for sure. I just upgraded mine last night.
post #72 of 883 Old 04-24-2012, 01:47 PM
KevinH's Avatar
Quoted: 192 Post(s)
Liked: 71
Does firmware upgrade wipe your settings so that you have to re-enter them?
-Kevin
JVC DLA-X550R projector/GIK Acoustic room treatments
Screen Innovations Black Diamond Zero Edge 1.4 110" 16:9
Marantz AV7702mkii pre-pro/Wyred4Sound 5-channel amp
Oppo BDP-105
JTR 3TX LCRs/Single8 HT-LP surrounds/2 RA Gamma21 master/slave pairs
KevinH is offline
post #73 of 883 Old 04-24-2012, 02:16 PM - Thread Starter
Yes.
post #74 of 883 Old 04-24-2012, 04:32 PM
KevinH's Avatar
Quoted: 192 Post(s)
Liked: 71
I just upgraded firmware(version 1003 right?) and it did not wipe my settings. Wonder if I should do a factory reset?
-Kevin
Oppo BDP-105
KevinH is offline
post #75 of 883 Old 04-24-2012, 05:33 PM
naijai's Avatar
Updated firmware on Saturday, wiped my settings. Updated to version 1009 but not sure what it updated on the Tv
I hope next update enables RVU capabilities.
naijai is offline
post #76 of 883 Old 04-24-2012, 06:06 PM
KevinH's Avatar
Quoted: 192 Post(s)
Liked: 71
I connected my 46ES6100 to my network wirelessly. Tested the connection and it's fine. Went to check for upgrade wirelessly, it connected to server and said there are no updates at this time....and my FW is currently 1003. I downloaded 1009 from website and just upgraded TV via USB. Maybe I needed to disconnect and reconnect TV again to the network? Guess I'll hafta to test that out next FW.
-Kevin
Oppo BDP-105
KevinH is offline
post #77 of 883 Old 04-24-2012, 07:07 PM
Where do you find what FW version is installed.
post #78 of 883 Old 04-24-2012, 07:29 PM - Thread Starter
Help then update. It will tell you which version even if there isn't an update.
post #79 of 883 Old 04-24-2012, 07:57 PM
KevinH's Avatar
Quoted: 192 Post(s)
Liked: 71
Whiz...what "help" are you talking about? I can't find a "help" in the menu or on remote?
-Kevin
Oppo BDP-105
KevinH is offline
post #80 of 883 Old 04-24-2012, 08:18 PM - Thread Starter
Sorry..."support". Was going off memory. It's the support icon with the ?
post #81 of 883 Old 04-25-2012, 06:31 AM
Insurance Whiz - appreciate your settings. How about a recap? I've noticed you put in bits and pieces throughout the running of this topic. Thanks. This is what I show but for some reason and can't adjust judder or blur, what is preventing this? (55" 6100F)
Picture Mode: Standard
BL: 15
Contrast: 95
Bright: 45
Sharp: 50
Color: 36
Tint: 50/50
Advanced:
Black Tone: off
Flesh Ton: 0
RGB only: off
Color Space: Auto
Gamma: +1
Picture Options:
Color Tone: Warm 2
DNR (Digital Noise Filter): low
MPEG (Mpeg Noise Filter): low
Film Mode: Off
Auto Motion: Clear
Blur Reduction: 8
Judder Reduction: 3
post #82 of 883 Old 04-25-2012, 08:05 AM - Thread Starter
Auto Motion needs to be set to custom to adjust those settings. As of right now this is what I have:
BL: 15
CONTRAST: 98
BRIGHT: 45
SHARP: 25
COLOR: 38
TINT: R52
DYNAMIC CONTRAST: LOW
BLACK TONE: OFF
GAMMA: 0
COLOR SPACE: NATIVE
COLOR TONE: WARM 2
DNR: AUTO
MPEG: AUTO
AUTO MOTION: CUSTOM: 8/3
I really like the look of all the settings but I'm still adjusting the auto motion. It may just be a compromise. Sports look great on this setting but movies have a tiny bit of soap opera effect.
post #83 of 883 Old 04-25-2012, 11:56 AM
TimG2's Avatar
Thanks for all of the helpful information. I am new to the forum and am considering buying the UN40ES6100. Does anyone have experience connecting a webcam for the Skype app? Does any webcam work or do you specifically have to purchase the Samsung camera (either STC2000 or STC 1100)?
How is Skype on this set?
Thanks in advance
Tim
TimG2 is offline
post #84 of 883 Old 04-25-2012, 05:47 PM
Centinul's Avatar
I upgraded my firmware and reset the TV to factory settings and the problem still persists.
Centinul is offline
post #85 of 883 Old 04-30-2012, 01:32 PM
drmax's Avatar
Originally Posted by jmt9779 View Post
while we're all trying to figure out the optimal display settings...
has anyone tried streaming music or videos from their home computer to the tv over your wifi? my tv recognizes my laptop, but when i try to select the laptop as an input source, it doesn't let me - i forget what the exact message is that pops up (i'm at the office right now). i was playing with some of built-in features the other day and they seem neat, but after the next week, i probably won't use any of them except for this ability to view/listen to content on the tv from my laptop (or my cell phone or tablet or whatever else i have linked up to my home wifi).
and, out of curiosity, what are your guys' thoughts on the "auto-motion" setting? when set to "standard", the images on the screen look so life-like that it kinda creeps me out (i watched 5 minutes of a rerun of Seinfeld like that last night), so i have mine set to "clear" like InsuranceWhiz. but I do watch A LOT of action movies with crazy special effects and lots of fast-moving action sequences, so that "standard" setting may come in handy for those, right?
no other useful information in this post - just excitement. ha! (sorry - thanks for putting up with me guys. this is my first flat screen tv which replaced a 32" 10-year-old tube tv and i'm loving it so far!) i probably won't have time to shop locally for a calibration disc this weekend, so i just ordered the Blu Ray DVE disc (on sale on amazon.com is anyone else needs it).
Yes, works amazingly well. I have several avi movie files and works nicely...wifi.
drmax is offline
post #86 of 883 Old 04-30-2012, 01:35 PM
drmax's Avatar
Originally Posted by Maverickaim9 View Post
Hi everyone, how is the uniformity for this TV, do you notice flashlighting or clouding when watching in a dark room?
Yes and is noticeable. I have mine in the bedroom. Each corner has some lighting and then puffy clouds in the middle bottom end. I turned down my back lighting some and it's barely noticeable. Folks I need advice on this. I have 28 more days to return this (just got 2 days ago) I really like the TV, but is there a chance I'll get another one like it? Please advise. DM
drmax is offline
post #87 of 883 Old 04-30-2012, 04:28 PM
pinpon2000's Avatar
Hello, my Samsung 55ES6100w exhibits stuttering and frame skipping problems when using AMP in anything other than "Clear" or "Off".
I have observed that the stuttering only appears to happen when using HDMI sources and 23.976fps content.
Auto Motion Plus Options Working OK when using HDMI Sources:
Auto motion Plus - "Clear" -Ok
Auto motion Plus - "OFF" when using Game mode or HDMI as "PC" - Ok
Auto motion Plus, all modes working OK using USB Playback
Auto motion Plus - Standar, Smooth, Custom - Fail Stuttering/Frame Drops
anyone have this problem?
pinpon2000 is offline
post #88 of 883 Old 05-01-2012, 01:45 PM
I ended up just using factory settings for standard mode, except I turned down the backlighting a bit.nn Edit: No, factory setting suck. I went with the ones posted by whiz on page 3. Mine were close to that anyway.
The only thing I do not like at all with this TV is the source mode shuffle, as I call it. Whenever I select another device, the source modes cycle through, and I usually end up have to manually select the source even after my Harmony remote called for HDMI2 for example, the TV may end up on TV or HDMI1. It is annoying.
post #89 of 883 Old 05-01-2012, 01:57 PM
drmax's Avatar
From my earlier plea for advice...is it possible to get one of these model of tv that "do not" have the clouds/flashlighting effect...or is this just the nature of this beast? I still have the option of exchanging. Is there a certain number on the set, or somewhere to know what a person is getting? I'm not gonna go through 10 sets to get one good one, without knowing what I'm doing.
Also, unsure if this effect gets worse over time? If thats the case, it's going back.
Please advise. Thx, DM
drmax is offline
post #90 of 883 Old 05-01-2012, 07:32 PM
Centinul's Avatar
Just a bit of an update.
Problem
I have a PC hooked up to the TV via HDMI. When the HDMI input type is set to "---" the picture looks great but there is extremely noticeable flickering when transitioning between light and dark scenes.
When the HDMI input is set to "PC" the flickering disappears but I can't configure the TV settings to get an acceptable picture. There is very noticeable clouding.
Things I've tried:
  1. Updated the firmware
  2. Updated my GPU drivers
  3. Switched HDMI cables
  4. Switched HDMI ports
I tried hooking up my Roku LT. This did not exhibit any problems whatsoever. I'd be inclined to say it's my PC but I disagree for two reasons:
  1. Before I had this TV I had it hooked up to a Samsung LNT3242H with no problems
  2. I would expect the flickering to be present regardless of the HDMI input type selected on the TV
Anyone have any input? What different type of processing does the TV do when the HDMI input type is changed?
Centinul is offline
Reply LCD Flat Panel Displays
Samsung , Samsung Un60es6100 60 Inch 1080p 120 Hz Slim Led Hdtv Black , Led Hdtv , Samsung Un55d6000
