Looking for a 32' LED with Headphone jack - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-08-2012, 07:46 AM - Thread Starter
tooley99's Avatar
Hello,
I'm looking for a 32 ' LED TV with headphone jack for my bedroom. The only one I could find is the LG 32LV2500. Is it a good choice?
Other recommandations?
Thank you!!!
tooley99 is offline
post #2 of 6 Old 04-08-2012, 05:16 PM
topr's Avatar
Anything with analog audio out will work...then just get an, RCA to stereo mini, adapter.
topr is offline
post #3 of 6 Old 04-08-2012, 06:28 PM
Bobby_D's Avatar
Electrically, I don't think that is correct. RCA output will have different impedance output than headphone jack output. And in most cases, heaphone output volume is controlable via TV where RCA output is not (unless your Tv have Variable Audio Output option).
Bobby_D is offline
post #4 of 6 Old 04-08-2012, 08:45 PM
topr's Avatar
I've done it many many times and never had an issue...but you will want the ability to control volume be it with VAO or the headphones.
topr is offline
post #5 of 6 Old 05-03-2013, 12:14 PM
Jan Barnett's Avatar
That only works if you can turn off the speakers on the TV so the sound only goes through the headphones. Otherwise you get sound out of both
Jan Barnett is offline
post #6 of 6 Old 05-03-2013, 12:15 PM
Reply LCD Flat Panel Displays
