Can anyone help identify this panel? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-10-2012, 02:29 PM - Thread Starter
AMartin56's Avatar
Quoted: 1001 Post(s)
Liked: 402
From a Sony KDL-60NX720. The panel is identified in the service menu as:
FDHY600LT0101
The format would suggest it's a Samsung Panel (Maybe S-PVA?) but I haven't seen any starting with FHDY here on the net via Google.
Thanks in advance.
Home Theater: JVC RS 420, Yamaha RX-V673, NHT Super Ones/Zeroes w/Ten Sub,
Sony BDP-S5500, Darbee Darblet and Monoprice 130 inch 2.35:1 White Material Screen
Living room: Sony 60NX720, VIZIO SB4051-C0 Other: Samsung 51F8500
Displays calibrated with HCFR, i1DisplayPro, and Colormunki Photo.
AMartin56 is online now
post #2 of 7 Old 04-11-2012, 06:47 AM - Thread Starter
AMartin56's Avatar
Liked: 402
My thanks to everyone that viewed my original post. Sounds like this is a pretty big mystery after all! I guess the next step is to dig up a magnifying glass and look at the pixel structure!
post #3 of 7 Old 04-11-2012, 07:06 AM
Racer_J's Avatar
I think most of us are likely stuck using Google and Panelook and this panel is in neither. The panel number should be correct though as that is the "known" panel for the mainboard you have. I couldn't get any further than that though.
Racer_J is offline
post #4 of 7 Old 04-11-2012, 11:23 AM
PlasmaPZ80U's Avatar
Quoted: 1966 Post(s)
Liked: 560
FDHY600LT0101
Thanks in advance.
can you see the panel sticker through the back vents? maybe the actual code is a little different and may show up on panellook if you do so
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #5 of 7 Old 04-11-2012, 11:52 AM - Thread Starter
AMartin56's Avatar
Liked: 402
Thanks for the suggestion. I'll try that.
post #6 of 7 Old 04-11-2012, 04:27 PM
Racer_J's Avatar
I think he's going to see the same code as that is the code listed at shopjimmy for his mainboard. So far that site has been incredibly accurate when it comes to mainboard and panel matches.
Racer_J is offline
post #7 of 7 Old 04-12-2012, 01:58 PM - Thread Starter
AMartin56's Avatar
Liked: 402
Finally found my magnifying glass. Looks like it's a S-PVA Panel. I found a number of sites with close up pixel structure pics and it's closest to the S-PVA found here:
http://www.tftcentral.co.uk/articles...chnologies.htm
I say 'closest' because my glass is only about 15x so it doesn't blow the subpixels up all that much.
Reply LCD Flat Panel Displays
