Damage to HDTV by technician - AVS Forum | Home Theater Discussions And Reviews
post #1 of 40 Old 04-16-2012, 08:29 AM - Thread Starter
CrashPush's Avatar
My brand new UN55D7900 was damaged by the cable technician while installing an internet line. The inner core (conductor) hit the bottom right of the screen and chipped the glass. Now every time the screen turns dark I can see a white dot.
The cable company supervisor is trying to work with me on the problem. When the TV was hit it was barely a month old. I told them that I was looking for a brand new replacement.
Has this happened to anyone here before?
Any tips on how to handle this?
CrashPush is offline
post #2 of 40 Old 04-16-2012, 08:34 AM
jbug's Avatar
Quoted: 259 Post(s)
Liked: 129
Stay the course and accept nothing less than a new replacement. That stuff happens and it's nothing new so the cable company should own up and make it right. If they don't, we'll see you on Judge Judy.
jbug is offline
post #3 of 40 Old 04-16-2012, 08:34 AM
walford's Avatar
Normally when a used TV is replaced it is replacecd with "refurbishedTV" or open box unit of the same model and not with a brand new unit.
walford is offline
post #4 of 40 Old 04-16-2012, 08:37 AM
jbug's Avatar
Quoted: 259 Post(s)
Liked: 129
His set is less than a month old. I wouldn't accept anything but a new one. That would be a rip to get something refurbished or that's been used and abused in a store display.
jbug is offline
post #5 of 40 Old 04-16-2012, 08:39 AM - Thread Starter
CrashPush's Avatar
The set was three weeks old when the technician hit it. It's hardly used.
post #6 of 40 Old 04-16-2012, 08:41 AM
mgkdragn's Avatar
Quoted: 2069 Post(s)
Liked: 2469
I would accept nothing less than a new unit .. and I hope you had the tech make note of the damage on the install order sheet
Uncle Willie
Oddball: Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?
mgkdragn is offline
post #7 of 40 Old 04-16-2012, 08:47 AM
gregzoll's Avatar
Liked: 33
There is no way, if the stinger from a coax line hit the covering glass, that it would chip it. Most likely the damage was there before, but not noticed, until the CATV tech showed up. So, who gets blamed, the last person to touch the set.
gregzoll is offline
post #8 of 40 Old 04-16-2012, 08:54 AM - Thread Starter
CrashPush's Avatar
No not really. He was there when he hit it. He it hit pretty hard. The sound of the wire hitting the glass was heard loud and clear by all in the room. He apologized for it. It was an accident. A report was filed. A supervisor visited my house and took pictures of the damage already.
You're reply was unnecessary. I'm not looking for silly replies like yours. I want advice. Thank you.
post #9 of 40 Old 04-16-2012, 08:54 AM
iatacs19's Avatar
Quoted: 239 Post(s)
Liked: 149
They have insurance when performing work on-site, so don't settle for anything less than the full value of a new TV. Do not comprise.
XBR65X930C, AVR-X4200W, NVIDIA ShieldTV, SVS SB12-NSD, RF-42 II, RC-52 II, RB-41 II
iatacs19 is offline
post #10 of 40 Old 04-16-2012, 09:00 AM
gregzoll's Avatar
Liked: 33
Are you talking about the bit that he cut off, or the actual line, with the stinger sticking out far enough? There still would not be enough force to cause a chip to come off of the glass, in that it would cause the type of damage you are stating.
Without pictures to show what you are talking about, along with the item that supposedly caused the damage, it is hard to realisticly perceive that when the stinger hit it, that there would have to be enough force. It would have had to shoot off like a bullet out of a gun, or off of a sling shot, along with being heavy enough, from a distance to cause any type of visual damage. The person would have to have been standing right against the tv holding the wire close enough within a foot, and that the dykes would have to have enough force to cause the projectile to move fast enough to chip the glass.
Again, without pictures, there is no proof to everyone else that this happened.
gregzoll is offline
post #11 of 40 Old 04-16-2012, 09:05 AM
jbug's Avatar
Quoted: 259 Post(s)
Liked: 129
Pictures for who? The OP said pictures were taken in his last post and the tech guy fessed up in front of witnesses. It doesn't matter if we here see pictures or not. If his cable carrier is honorable it will do the right thing.
jbug is offline
post #12 of 40 Old 04-16-2012, 09:09 AM
mgkdragn's Avatar
Liked: 2469
And you know this because you are psychic ..
Uncle Willie
mgkdragn is offline
post #13 of 40 Old 04-16-2012, 09:12 AM
gregzoll's Avatar
Liked: 33
No, because I have worked with wire and using dykes, there is no way that a cut bit will fly fast enough to do any kind of damage from a distance, unless the person was standing right up against the set, and holding the wire within six inches or less when making the cut. Even then, there is not enough force to chip the glass. If it was plastic, not glass, yes then you can chip it or damage the anti-glare, but nothing like the OP is talking about.
gregzoll is offline
post #14 of 40 Old 04-16-2012, 09:14 AM
gregzoll's Avatar
Liked: 33
Pictures with their post. Just because they have blamed the technician and not knowing if the damage happened before moving the set, it could have happened if the OP was helping the technician and they had their tool pouch on, then yes something could have damaged the set at that point when putting it back.
gregzoll is offline
post #15 of 40 Old 04-16-2012, 09:17 AM - Thread Starter
CrashPush's Avatar
These are the replies I was looking for. Thanks guys.
post #16 of 40 Old 04-16-2012, 09:19 AM
mgkdragn's Avatar
Liked: 2469
Since the OP has agreement with his CATV provider on the damage, I guess I don't understand why calling him essentially a liar makes any sense or difference in the issue ..
He came here asking for advice .. which is in the spirit of AVS ..
Uncle Willie
mgkdragn is offline
post #17 of 40 Old 04-16-2012, 09:24 AM
Boidster's Avatar
OP: Event E happened and I'd like advice on how to handle it.
Gregzoll: I deny that event E happened.
WTF?
Boidster is offline
post #18 of 40 Old 04-16-2012, 09:28 AM
jbug's Avatar
Quoted: 259 Post(s)
Liked: 129
Gregzoll, that's a big if. The OP said that after the tech incident was when he saw the spot unless you accuse him of lying. For this to happen in the same area the tech was working on would lead me to believe the tech caused the damage somehow. I can't see the owner saying to himself, "My set is damaged in that area. I know what I'll do, I'll call a the cable company and have their tech come out and work in the area where the damage is and then he'll hit something and confess that he just made a mistake. The tech guy couldn't say anything but I'm sorry as others heard the mistake and his, oops confession. If I was a Judge, I'd side with the set owner and tell everyone else to go home and sit on a garbage can in the alley and eat crackers n cheese.
jbug is offline
post #19 of 40 Old 04-16-2012, 10:46 AM
Ross Ridge's Avatar
Liked: 81
Sheesh. Give gregroll a break. The original poster in his original post in this thread described his set getting damaged in circumstances that were hard to believe, and all gregroll did was point that out that the damage could've been caused by something else. He didn't accuse anyone of lying. Even after the original poster's explained the situtation in more detail, it's still hard to believe that the conducting wire at the centre of a CATV cable could've possibly caused the loud noise and damage he described.
It's a good thing that the cable company admits their responsibility for the damage, however it was caused. If the original poster were to take the advice of some people in this thread and take the cable company to court then their lawyers and experts could easily tear him a new one if he tried to use the explaination given here. My advice would be avoid the courts at all costs, but if it turns out to be necessary then don't hurt your case by bothering to try to explain how it happened.
Ross Ridge is offline
post #20 of 40 Old 04-16-2012, 10:49 AM
SAM64's Avatar
Liked: 78
Not hard to believe at all, it's steel.
Maybe he could take a break from posting his garbage.
SAM64 is offline
post #21 of 40 Old 04-16-2012, 11:00 AM
maximuslcd's Avatar
Quoted: 118 Post(s)
Liked: 121
+1
Accept nothing less than a new in box replacment. Oh and also put gregroll on the ignore list....
I work to live and live for the beach.
Amateur HT enthusiast.
Samsung 65KS8500/Onkyo 656 AVR, Dolby 5.1, Samsung UBD 8500 4K blu Ray player
Sharp Quatron 3D 60" Onkyo 705 Bonus room
Sharp Quatron 60" Bedroom
maximuslcd is offline
post #22 of 40 Old 04-16-2012, 11:02 AM
AMartin56's Avatar
Quoted: 2166 Post(s)
Liked: 1137
Should of bought a Sony with Gorilla Glass.
AMartin56 is offline
post #23 of 40 Old 04-16-2012, 01:04 PM
wxthomson's Avatar
Just the sort of helpful advice the OP was looking for!
wxthomson is offline
post #24 of 40 Old 04-16-2012, 01:37 PM
PlasmaPZ80U's Avatar
Quoted: 2317 Post(s)
Liked: 716
+1, accept nothing less than a brand new replacement
ignore those other replies that would try to suggest it is your fault or that a used/refurbished TV is acceptable
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
post #25 of 40 Old 04-16-2012, 03:29 PM
EG3
EG3's Avatar
I was really trying to stay out of this one, but, I couldn't help it.
Since the set is an LCD, there is no glass. The screen is made of plastic layers. The outer plastic layer of the screen could easily be damaged by a metal object.
EG3 is offline
post #26 of 40 Old 04-16-2012, 03:57 PM
Liked: 716
yes LCD panels are fragile and most sets don't have a layer of glass over the panel; that is typically only on plasma and crt sets
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #27 of 40 Old 04-16-2012, 04:29 PM
el_smurfo's Avatar
Seems a lot of folks missed the point on this one...It's the cable installer who damaged it, so Samsung is totally out of the loop. The chances of a cable company paying for anything seem slim to me (you should see the damage installers have done to my friend's houses, drilling through arts and crafts trim, open holes through stucco, etc). I wonder if there's a kit you could use to fill in the hole, reducing the odd light refraction you're seeing...maybe something to repair auto glass or lens?
el_smurfo is offline
post #28 of 40 Old 04-16-2012, 06:24 PM
Ross Ridge's Avatar
Liked: 81
No, LCD panels used in TVs use glass substrates. The outer protective layer of the TV probably made of plastic, but the panel itself is largely made of glass.
post #29 of 40 Old 04-16-2012, 06:57 PM
Liked: 716
the surface is plastic though
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #30 of 40 Old 04-16-2012, 09:57 PM
Gregck's Avatar
it's not like the cable company sells tvs, so they don't magically have "stock" of any tvs and it's not like they are gonna go fishing for a refurbished model. As stated earlier, cable companies have insurance for accidents like this, especially if the person who damaged your television was an employee. I say this because a lot of companies use contractors. Sounds like you will be getting a new TV, don't settle for less.
Gregck is offline
Reply LCD Flat Panel Displays
