The *OFFICIAL* 2012 Samsung EH4000/EH5000/EH5300 Owner's Thread... - Page 77 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #2281 of 2431 Old 08-14-2014, 10:09 AM
p5browne's Avatar
Quoted: 1335 Post(s)
Liked: 1043
Samsung UN32EH5300 - June 16,2014 (10 Hours)
Calibrated using iScan Duo for Patterns, Spectracal C6 on tripod profiled off i1Pro, and using Calman 5.3.5 RC4
August 14, 2014 (100 Hours)
Calibrated using iScan Duo for Patterns, i1Display Pro on tripod profiled off i1Pro, and using Calman 5.3.5a Build 1598
Out of the Box Factory Settings Scanned Values: Service Menu White Balance / Calibrated 10 Hours / Calibrated 100 Hours
Sub Brightness: 128 / 112 / 112
Red Offset: 128 / 131 / 131
Green Offset: 128 / 129 / 123
Blue Offset: 128 / 126 / 118
Sub Contrast: 135 / 117 / 117
Red Gain: 148 / 140 / 122
Green Gain: 128 / 128 / 128
Blue Gain: 165 / 152 / 166
Movie Values after calibration:
Backlight: 18
Contrast: 92 / 94
Brightness: 47 / 46
Sharpness: 20 / 34
Colour: 50 / 50
Tint: 50/50 / 50/50
Advanced settings:
Dynamic: Low / Off (If haze is an issue, put on Low, but it does affect specs.
Black Tone: Off
Flesh Tone: 0
RGB Only Mode: Off
colour Space: Native
White Balance: All Values at defaults of 25
Gamma: 0 / -1
Picture Option:
Colour Tone: Warm2
Digital Noise Filter: Off
MPEG Noise Filter: Off
HDMI Black Level: Normal
Film Mode: Off
LED Motion Plus: Off
Notes: Resulted in dE1.4 for setting of 2.4 Warm2 Reading 6560K Warm1 Reading: 7880K
Did everything possible, with what I had to work with, to get a Flat Greyscale
#1 - Set all Service Menu Values (SM) to 128, and Normal Menu White Balances left at defaults of 25
#2 - Adjust SM values to get RGB Gains and Offsets to the Zero Line in the Normal Menu. (100% and 30%)
#3 - Checking 11 Point Greyscale - 100% dead on, 30% not!
#4 - Adjust SM to get 100 and 30% Flat on zero Line.
Issues: Red - 10, 20 and 80% Elevated Green - 10 and 20% dipped Blue - 40 and 50% Peaked
(All the R and G values above under the 3 lines. B - between 4 and 5)
Changes from 10 to 100 hours of usage - Red Gain dropped, Blue Gain & Sharpness Increased, some changes in the Offsets
End result, a MUCH Improved PQ that I can now live with!
p5browne is online now
post #2282 of 2431 Old 08-16-2014, 04:18 PM
johnboy813's Avatar
I have had my UN32EH5300 for several months now and initially set it up with my wireless router (Netgear WGT624) and it does receive updates. Now when I try and connect to something like UTube it says that a network connection is not setup. When I go through the process and enter the password for my router the setup connection fails. When I look at my router status the IP address for the TV shows up as a connected device (but it not not show a name just a '-' dash) as the device name. I have added its MAC address to my Access Card List as I only allow known devices on my network. One message from the Samsung is to check that DHCP is enabled and on my router 'Use router as DHCP server' is checked. One thing I did notice was the IP Address on my network all starts with 192., but the Samsung IP Address starts with 169.
Any suggestions would be appreciated.
johnboy813 is offline
post #2283 of 2431 Old 08-16-2014, 06:36 PM
p5browne's Avatar
Liked: 1043
169 usually means `No Connection'. Try doing the Normal Menu Reset and redo the Setup. Or, if not wanting to redo any settings, just try the Setup Again.
post #2284 of 2431 Old 08-17-2014, 02:31 PM
johnboy813's Avatar
I have it working now, turns out when I wrote down my router password I transposed 2 characters (a little dyslexia). Thanks for the assist.
post #2285 of 2431 Old 08-18-2014, 04:16 PM
p5browne's Avatar
Liked: 1043
Caught this when redoing the Setup?
post #2286 of 2431 Old 08-18-2014, 07:26 PM
johnboy813's Avatar
Talking
Pretty much.
post #2287 of 2431 Old 08-21-2014, 06:45 AM
Kevin Day's Avatar
So I just been wondering does anyone know the default settings of the ADC result my are currently at
ADC Result:
2nd_R_L 134
2nd_G_L 134
2nd_B_L 134
2nd_R_H 49
2nd_G_H 49
2nd_B_H 49
But I'm not sure if that's how it was in the box
Kevin Day is offline
post #2288 of 2431 Old 08-21-2014, 07:55 AM
Woobieizer's Avatar
Quoted: 322 Post(s)
Liked: 120
Good Morning Kevin:
I hope you can get that answer resolved in a short time.
Here is what Kevin has for those that do not know or remember:
Originally Posted by Kevin Day View Post
I have a un32eh5300 and would like some help with using pc mode or game mode for my xbox one, if this is any of your guys concern.
Also if theres any calibration thats good for gaming.
A recent discussing relating to ADC calibration starts with a similar question:
Originally Posted by mollywhopper View Post
messed up service menu using hdmi calibration. can someone tell me the stock values on the service menu for un32eh5300 im on a TS01 version if that matters. plz help
Woobieizer is offline
post #2289 of 2431 Old 08-22-2014, 03:03 PM
vicrol123's Avatar
I got a solution to connect wifi in my 32" EH5300F
# With the TV off.
mute> 1-8-2
turn on
sub menu to change region wifi- (letter) to A
now it's working perfectly.
regards!
Woobieizer likes this.
vicrol123 is offline
post #2290 of 2431 Old 08-31-2014, 05:47 PM
Liked: 0
Does anyone receive poor audio quality with the EH5300 32" when certain bass frequencies are played? I know there isn't a subwoofer built in to aid with the lows but is there a "fix" to help eliminate the deep humming sound (I'm not sure how to describe it). I'm not really looking to invest in a soundbar or external audio system at the moment.
Algorithm518 is offline
post #2291 of 2431 Old 08-31-2014, 06:40 PM
Woobieizer's Avatar
Quoted: 322 Post(s)
Liked: 120
post #2292 of 2431 Old 09-03-2014, 02:51 AM
capillariancrest's Avatar
Liked: 0
Originally Posted by bcab17 View Post
I just picked up a UN32H5203 for our bedroom (still in the box). My first question is how to update to the latest firmware. When it connects via WIFI will it automatically look for updates, download and install them or is firmware something different?
My second question is about the 60Hz refresh rate (my two other TVs are 120Hz). Is this going to be a big issue? For about the same price, there was a Vizio M3221 next to it that was 1080p / 120Hz. I actually chose the Sammy because in general, it has the perception of being a better built TV than Vizio (of course, this could be completely wrong).
Lastly...viewing angle. I plan to mount this TV relatively high on a wall where we would be watching it "straight on" from bed, but at an upward angle (the head of the bed is about 13' from where the TV will be mounted). How are the off-axis vertical viewing angles?
120 hz refers to the auto motion plus that your tv uses. the tv processes the image and inserts new frames to make it appear smoother. disabling this option is usually recommended. your samsung should download the software once you connect it to your wifi and select system update.
capillariancrest is offline
post #2293 of 2431 Old 09-03-2014, 08:38 PM
Liked: 0
Do all 50" models (UN50EH5000) have the TS** panel, or is it also part of the panel lottery? I'm purchasing one at Best Buy this Sunday.
rpeopler is offline
post #2294 of 2431 Old 09-04-2014, 09:42 AM
codexavellum's Avatar
Does anyone have any configuration settings for the UN32EH5000F? I just got it today and tried to go through the 77 pages but couldn't find it.
codexavellum is offline
post #2295 of 2431 Old 09-04-2014, 10:37 AM
johnboy813's Avatar
Red face
Check out post 2284, that should get you in the right direction. But remember color preference is in the eye of the beholder.
post #2296 of 2431 Old 09-04-2014, 10:52 AM
Do 5300 Settings go fine on a 5000 Set?
post #2297 of 2431 Old 09-04-2014, 12:48 PM
johnboy813's Avatar
The sets are similar (if the look at the title of this thread it mentions both sets); the main difference between the 5000 and the 5300 is as follows:
The 5300 has a 60Hz refresh with the 5000 has a 120Hz refresh and the 5300 has Smart TV and WIFI built in where the 5000 does not.
Having said that to answer your question as I mentioned before it is a good place to start. Do not forget that lighting in the room where the set is located will affect how you set your brightness and contrast. I would recommend writing down the current setting before you start making changes so that if you do not like what you see you can always revert back to how it was.
Good Luck
post #2298 of 2431 Old 09-09-2014, 08:48 AM
Nemix77's Avatar
Thumbs up
p5browne
Been a long time since I've visited this forum to check out your improved calibration settings (did not want to rush you) and man it was worth the wait.
I just applied your calibration settings below to my 37EH5000 and what an improvement in PQ over your last calibration settings even when connected to PC the color temp and colors are spot on perfect to my eyes.
Again thanks for posting up your tweaked calibration settings and hope to hear from you in the future perhaps when your EH5300 hits 200 hours for maybe a final calibration touch up.
Considering your current posted calibration settings @ 100 hours are already in IMHO perfect, it really does not matter to me if you decide not to do a final touch up calibration.
These are the settings I run on my 37EH5000 with a PS3 set to Full RGB and HDMI labeled as PC using p5browne's calibrated settings as guide of reference:
Sub Brightness: 128 (Kept at default because there's no picture settings when watching movies via USB media)
Red Offset: 131
Green Offset: 123
Blue Offset: 117 (Lower because Chi Mei panels are a tiny bit more Blue)
Sub Contrast: 130 (Higher because Movie Mode via USB media is lacking some Contrast)
Red Gain: 122
Green Gain: 128
Blue Gain: 166
Standard Mode with HDMI labeled as PC:
Backlight: 20
Contrast: 93/94
Brightness: 44
Sharpness: 70
Advanced Settings:
White Balance: All Defaults 25
Gamma: +1 (Higher gives my Chi Mei panel just about 2.2 Gamma measured with PNG images and Gamma correection guides found online in order to correspond with Full RGB Gamma)
Picture Options:
Color Tone: Warm2
Thanks again,
Nemix77 is offline
post #2299 of 2431 Old 09-15-2014, 05:14 PM
p5browne's Avatar
Liked: 1043
Calman has a new Software out, and I've come up with a small change on how I calibrate. Will probably get another go at things later this week.
Just checked - set only has 142 hours on it. Will wait for 200. Wife's current Contract over end of September, so she'll be back home racking up more hours. Problem then will be getting it to re-calibrate when she's Not Here!
post #2300 of 2431 Old 09-27-2014, 11:19 AM
vicrol123's Avatar
I would like to know your opinions on which 2.0 or 2.1 speakers would use in a eh5300. between 80~120$
omg, that inbuild speakers...just cause
Regards!
post #2301 of 2431 Old 09-27-2014, 07:55 PM
Woobieizer's Avatar
Quoted: 322 Post(s)
Liked: 120
Regards!
I'd trust whatever you get. After I padded the inside of my 46" I've not had any rattle. I did pick up a real cheap soundbar from Big Lots. It worked fine but it lacked LFE.
What have you considered?
post #2302 of 2431 Old 09-28-2014, 10:55 AM
vicrol123's Avatar
vizio s3820w
rca rts735e
phillips css2123/f7
integrated speakers are dying recently watching transformers age of extintion and godzilla.
during the "roaring"? godzilla my ears almost bleed how speakers are heard.
crappy speakers...(do not blame samsung, in search of thinness that gets more audio.)
regards!
post #2303 of 2431 Old 09-30-2014, 10:45 PM
bjarmon's Avatar
Strange question, but i'm sure someone here at AVS has done it.
I am looking at the UN26EH4000 model but the issue is that the space that I must fit it in is only 23.9" and the measurements of this set are 24.2". Does anyone think that by removing the bezel and just having the panel + (components behind it), will help me to lose that extra 0.3" ? Thanks for any help guys/girls
bjarmon is offline
post #2304 of 2431 Old 10-01-2014, 02:18 PM
crashbot's Avatar
Quoted: 16 Post(s)
I don't think it is a practical proposition to remove the bezel.
crashbot is offline
post #2305 of 2431 Old 10-01-2014, 04:16 PM
p5browne's Avatar
Liked: 1043
Bezel holds panel in place - but then, there's always Duct Tape! Of course, voids warrantee!
post #2306 of 2431 Old 10-01-2014, 05:41 PM
bjarmon's Avatar
I've never been afraid of some duct tape
I really don't have too many options, seeing as the only TV that would fit (dimensions wise) would be the Samsung P2570HD, which is a Monitor that has a TV tuner built in. The problem going that route is that I cannot find the P2570HD anywhere but there are a few UN26EH4000 on ebay. So if anyone has taken one of these apart and knows if removing the bezel would help to achieve the right width I would be grateful.
bjarmon is offline
post #2307 of 2431 Old 10-03-2014, 08:32 AM
bjarmon's Avatar
Does anyone know where to find a service manual for these models? Hopefully there would be some images that would show how much room there was behind the bezel.
bjarmon is offline
post #2308 of 2431 Old 10-03-2014, 11:21 AM
rperlberg's Avatar
Interactive quiz
I was watching Gracepoint on my Samsung 5300 and an interactive quiz came up at the bottom of the screen that I had to dismiss with the Exit button. As if it weren't bad enough that the networks are putting all kinds of annoying graphics on the screen, now my own TV is generating more annoying unwanted crap. Is there any way to disable this misfeature?
rperlberg is offline
post #2309 of 2431 Old 10-03-2014, 05:30 PM
Woobieizer's Avatar
Quoted: 322 Post(s)
Liked: 120
Can you keep an eye out and be more specific, as to what the message was, and how long or if it had a count down timer. Take a picture next time and share it here. Does your firmware need an update?
You're right that is "misfeature".
Obviously you can disable the network interface, but who besides me would do that? I got tired of seeing "Smart Hub has been updated" messages.
Thanks for posting that..
post #2310 of 2431 Old 10-04-2014, 12:56 AM
rperlberg's Avatar
You should be able to see the message in the attached picture. The text is:
"Go deeper into Gracepoint. Take part in
our exclusive polls and quizzes throughout
the episode!
Press [ENTER] on your Samsung TV remote
YAHOO!"
"[ENTER]" is displayed as the Enter symbol on the Samsung remote.
If I don't respond to or dismiss the message, it goes away after about 1 minute.
The set updated itself just before I watched this.
I also got disgusted and disabled the network once, but I put it back on. I don't know if this function uses the network connection or gets everything from the video. I have the program recorded on DVD and the quiz function comes up while I'm watching the DVD. The message doesn't always come up in the same places on repeated plays.
Reply LCD Flat Panel Displays
<<. , Displays , Led Hdtv , Samsung , Samsung Un32eh4000 32 Inch 720p 60 Hz Led Hdtv , Samsung Un40eh5300 40 Inch 1080p 60 Hz Led Hdtv , Samsung Un46eh5000 Led Hdtv
