Bad power supply on a iLo LCT42HA36? - AVS Forum | Home Theater Discussions And Reviews
Old 04-23-2012, 05:16 PM - Thread Starter
rage4order's Avatar
I'm trying to fix a friend of mine's Tv. The brand and model are in the title. The problem is it turns on but just shows a blue screen with a "no signal" on it. I'm unable to change inputs nor do any of the buttons on the Tv do anything(other than the power button). The remote does nothing. I will say that when I plug in the tv to an electrical outlet a high pitched noise comes from the board/power supply. Would I be correct in thinking I need to replace this board?
rage4order is offline
Old 04-24-2012, 05:58 PM
sjetski71's Avatar
Free bump for the OP.
Powersupply? video mainboard? T-con?
sjetski71 is offline
Old 04-25-2012, 05:48 PM - Thread Starter
rage4order's Avatar
Thanks for the bump.
I've seen the power board online for about $80 and I'd really like to know whether to take a chance on swapping it out to see if it fixes the problem. As I said, there is a definite high-pitched hum coming directly from the board but I'd like to be a bit more sure before making the purchase. The weird thing is, the sound goes away when I turn on the TV.
