Official Sony HX850 Owner's Thread (46HX850, 55HX850) - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 10-01-2012, 09:14 PM
adrman's Avatar
I haven't tried 3d. My avr (Marantz 7001) doesn't support it and truthfully I've never been much of a fan, even in the theater. Eventually I'll pick up a set of glasses to see if I feel like I'm missing anything enough to upgrade the receiver and go from there. Once I get a calibration done, I'll post my settings as well. The picture is good enough at this point though that I'll be doing it mainly out of curiosity, so it might be a while.
adrman is offline
Old 10-01-2012, 10:56 PM
fegam2's Avatar
Ok thank's for your reply.
fegam2 is offline
Old 10-02-2012, 06:26 AM
Srujan Sujju's Avatar
hello , i read all the posts in this thread and finally decided take SONY HX 850 , thanks to all for useful posts smile.gif today i went to sony center but the image was little crispy and blur ,so i think calibration will solve this problem , so please post calibration settings for 1080 i connection in bright room , i read that CNET settings are for blue-ray in dark room , thank you smile.gif
SONY TABLET S - SONY DSC-WX7 - SONY HOME THEATER - SONY MDR XB - 500 - SONY NWZ-A844/T - SONY HX 850 -SONY PlayStation®3 160GB Console( UPCOMING )
Srujan Sujju is offline
Old 10-02-2012, 06:51 AM
steve1971's Avatar
Quoted: 498 Post(s)
Liked: 431
Originally Posted by Sonyboy View Post
Home theaters review is up. Excellent! http://www.hometheater.com/content/sony-kdl-55hx850-3d-lcd-hdtv
Used the Home Theater settings they used on the HX850 for my 46HX750 and I am shocked that the settings look better then Cnets settings. I didnt think they would work being they are different models but I guess I was wrong on that one. Thanks Home Theater Magazine and Tom Norton.
steve1971 is offline
Old 10-02-2012, 07:26 AM
Mysterio's Avatar
In that Home Theater review, it says:
To defeat the overscan, you must go into the Picture and Display menu, select Screen, turn off Auto Display, and set Display Area to Full Pixel.
On my set, when I turn off Auto Display, the only options I have under Display Area are Normal, +1, and -1; I don't have a Full Pixel option. Am I missing something?
Mysterio is offline
Old 10-02-2012, 07:54 AM
adrman's Avatar
That's something I need to explore as well, but haven't had time. I'm currently set to normal. When using the CNET settings, I had a full pixel option.
Sent from my Nexus 7
Mysterio likes this.
adrman is offline
Old 10-02-2012, 12:23 PM
Dizzyboy's Avatar
Quoted: 57 Post(s)
Want to see how badly Sony are screwing Canadians with regards to pricing?
The 850 on Sony's US website, currently selling the 55-inch model at a very reasonable $1999 - http://store.sony.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=8198552921666415300#reviews
The 850 on Sony's Canadian site, selling the same 55-inch model for an absurd $2799! - http://store.sony.ca/webapp/wcs/stores/servlet/CategoryDisplay?storeId=20153&langId=200&catalogId=100803&identifier=S_TV_HX
I don't mind paying an additional $100-$200 over the US price due to taxes, smaller market with higher shipping costs etc, but this big a price difference, especially while the CDN dollar is at par with the US, is just exploitative, imho.
I'd order one in from the US, but I don't want to lose the warranty.
mike50 likes this.
Dizzyboy is offline
Old 10-02-2012, 01:14 PM
fegam2's Avatar
When you turn off auto display: if you feeding your tv a 480i or 480p signal like cable the only options available would be normal, +1 and -1 but when you send a 720p, 1080i or 1080p signal to the tv then there be the Full Pixel option. Full pixell is only for HD signals and be sure to use it.
fegam2 is offline
Old 10-02-2012, 01:19 PM
DoctorM's Avatar
Quoted: 652 Post(s)
Liked: 198
Can these properly handle 24p content? If so, what are the settings? I know a lot of TVs tend to fatten 24p up to 60 or more fps.
The HT magazine review was saying something about the 3d being dubious, that tends to be from 3:2 conversion of 24p material. Can that conversion be bypassed?
DoctorM is offline
Old 10-02-2012, 09:06 PM
adrman's Avatar
I know it doesn't help with the price differential in Canada, but thank you Dizzyboy. Best Buy also dropped their price from the $2199 I paid two weeks ago and I just requested a credit for the difference.
Dizzyboy likes this.
adrman is offline
Old 10-02-2012, 09:10 PM
adrman's Avatar
When I tried to change this setting, I was feeding the display a 720p signal from my dvr, so there must be another variable.
adrman is offline
Old 10-03-2012, 12:47 AM
fegam2's Avatar
Ok, tried feeding the tv an 1080p or 1080i signal and see if it gives you the option then. If so it means that you maybe cannot use it with 720p. I will try with 720p on my cable and see if it give me the option.
fegam2 is offline
Old 10-03-2012, 06:56 AM
HaRd2BeAr's Avatar
Liked: 36
On my 55HX853, full pixel is only available for 1080i/p sources, with 720p full pixel is not available.
Aaron
HaRd2BeAr is offline
Old 10-03-2012, 07:38 AM
ussjtrunks's Avatar
Does that mean you'll need to have to deal with a cropped image when playing ps3 in 720p?
ussjtrunks is offline
Old 10-03-2012, 11:24 AM
HaRd2BeAr's Avatar
Liked: 36
I guess so, but i don't think this is restricted to Sony, Samsung i believe is the same or at least the Samsung i have is.
Understand native/dot-by-dot mode. Some HDTVs, most commonly 1080p displays, also have an aspect ratio mode that doesn't scale the incoming signal at all. Often called dot-by-dot or native, this mode simply takes the signal, whatever resolution it is, and displays it regardless of the display's native resolution. Depending on the signal, this can either fill the screen perfectly, leave black bars on the top or bottom, or leave black bars on all sides. For example, if you have an HDTV with 1080p native resolution and you're watching a 720p HDTV show, a true dot-by-dot mode will be window-boxed--the 1280x720 program will appear as a rectangle within the 1920x1080 display, surrounded by bars on all sides. (Many dot-by-dot modes only apply to 1080i and 1080p sources, however, so lower-resolution sources like 720p and DVD are still automatically scaled to fill the screen.) Regardless, the true advantage of dot-by-dot is that, with 1080p displays, every pixel of 1080i and 1080p sources is shown on the screen with no overscan and all of the detail promised by the source. The only real disadvantage is that some sources don't completely fill the screen, so you might see a solid line or interference along the extreme edges of the display. But in general, if you have a 1080p display and are watching 1080i or 1080p sources, dot-by-dot will give you the best picture quality.
Old 10-03-2012, 12:40 PM
aztony's Avatar
Can anyone tell me if it's possible to use the TV Guide feature when using OTA for reception?
Does anyone actually use the yahoo widgets or any other widgets? Seems to be nothing but a waste of time to me.
aztony is offline
Old 10-03-2012, 03:35 PM
adrman's Avatar
Aaron
Confirmed here as well. The minute I put up a 1080i source, full pixel was available. With a 720p source, it's -1, normal, +1.
adrman is offline
Old 10-03-2012, 09:45 PM
fegam2's Avatar
Thank you Ardman and Hard2bear for your confirmation. Ussjtrunks why would you set your ps3 to 720p when you have an 1080p tv?. If you have some content that is 720p be a video, game or cable hd tv; just set your ps3 or cable box/ dvr to display at 1080p or 1080i and then you'll have the option Full Pixell available to you.
VesNL likes this.
fegam2 is offline
Old 10-04-2012, 06:47 AM
adrman's Avatar
Just tried it. Works like a charm.
adrman is offline
Old 10-04-2012, 11:42 AM
ussjtrunks's Avatar
The ps3 outputs certain game content at 720p on the samsung I have now it can be set to just scan 1:1 in 720p too so that my game huds and stuff are not cut off.
Old 10-04-2012, 01:22 PM
aztony's Avatar
Thanks for letting me know it can work. Please tell me how you got it to work, what settings did you use? TIA
aztony is offline
Old 10-04-2012, 02:17 PM
TyrantII's Avatar
Liked: 833
I believe if you only check only 1080P in the PS3's setting, the unit will upscale the image and send a 1080P signal only. That should allow the TV to do full pixel.
Question becomes what does the better upscaling job of the native resolution, your TV or the PS3.
TyrantII is offline
Old 10-04-2012, 07:26 PM
fegam2's Avatar
TyrantII is correct, set the ps3 to only output 1080p so that you have the option Full Pixell. In my experience with many brands of upscalers, i have to say that sony and samsung are the best upscalers out there, and the PS3 has an excelent upcaler, so don´t worry a let the ps3 do the upscale and use the full pixell option so you have 1:1 maping. If you have doubts, play any PS3 game that is natively 720p (almost all of them are!) like killzone or uncharted, first with the PS3 sending the 720p signal to the tv and then triy with the PS3 sending the 1080p signal, so you can see the difference and decide what metod to used. I play all 720p native games this way, same thing with the xbox360 and. My cable dvr is set to play all hd channels in 1080i so is the same thing, I get Full Pixell even in 720p football, soccer and baseball games.
fegam2 is offline
Old 10-05-2012, 07:15 AM
adrman's Avatar
I don't recall doing anything special to enable it. When I did the initial setup of the television, I did a hardwire connection to my network switch, hooked up my ota antenna and let the channel scan proceed. Until I saw your question, I hadn't messed around with the guide functionality other than to know it was there. I switched over to ota, called up the guide, my ota channels were there and I was able to use the guide to switch among them and get programming information. I think you just need to scan for channels and make sure you're connected to the Internet.
adrman is offline
Old 10-05-2012, 10:05 AM
jakirk's Avatar
I've had mine for about 2 months now and starting to notice some serious clouding/flashlighting- particularly when gaming. Its really starting to bug me. Is it possible this stuff gets worse over time?
jakirk is offline
Old 10-05-2012, 01:21 PM
aztony's Avatar
Of course it's possible it will get worse, it's also possible that it won't. If it's bugging you now, why wait to see if it gets worse, just call Sony while it is still under warranty.
aztony is offline
Old 10-06-2012, 12:08 AM
DoctorM's Avatar
Quoted: 652 Post(s)
Liked: 198
So what is the consensus on the best glasses?
I understand the Sony TDGBR750 Titanium are better than the standard (lighter and with less crosstalk), but expensive.
I read somewhere on Amazon that the PS3 3D glasses have better performance than the standard Sony glasses as well.
How do the Xpand X103 (and X104) stack up? Better, worse or the same as the Titanium?
I'm sort of leaving towards the Xpand so I can take them to my 2nd TV, but I'd like them to not suck.
DoctorM is offline
Old 10-06-2012, 11:51 AM
hello ,
recently i went to Sony centre to have a look on this model , its monolithic design is fantastic ,and i also carried some FULL HD videos and pics just for testing , but went i tried to play images , its just saying some thing like " preview not available " what could be the problem ? i downloaded these pics from internet just for testing
Old 10-06-2012, 11:53 AM
aztony's Avatar
I figured out what was causing the Guide not to work. It was my zip code that was causing the guide not to find any data. I live on the outskirts of Phoenix so I changed the zip to a Phoenix zip code.
aztony is offline
Old 10-06-2012, 06:59 PM
replicant21's Avatar
Was hoping for a little help. I'm trying to purchase my first HDTV. Mostly bluray/streaming with the occasional sports match or gaming. I will sit about 8 feet from the tv with completely controlled and dark room. My budget is ~$2000.
My final choices are the sony hx850, the lg lm7600 or one of the panasonic plasmas like the 60gt50. Everyone rates the plasmas really high, but I just don't know if I can deal with any potential burn in and am not a fan of darker whites. I went to best buy to look at all the tvs, but only the LG looks ok. Just about every other tv, including the supposed best tv available in the panasonic vt50, look ridiculously bad at this best buy. I did like the design of the hx850 a lot though. Is the hx850 worth the extra money vs the LG or panasonic plasmas? I'm leaning towards it right now despite how bad it looked at best buy.
replicant21 is offline
Led Hdtv , Displays , Sony , 3d Hdtv , Sony Bravia 55 Inch Led Tv 3d Support Bravia Hx850 Kdl 55hx850 , Sony 40 Inch 3d Hdtv Kdl46hx850 , Sony Bravia Kdl55hx850 55 Inch Led Hdtv
