Official Sony HX850 Owner's Thread (46HX850, 55HX850) - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 11-20-2012, 09:45 PM
skibum5000's Avatar
Quoted: 48 Post(s)
Liked: 49
Originally Posted by jtown017 View Post
i only have edge bleed on the bottom right/left corners. just like a little bit. this was on both of my sets. it actually is the best out of the lg lm7600 and panny et50
Thanks, that sounds perhaps promising.
What about if you turn off the local dimming? Is the black level still ok and the edges don't light up? Or do you need to have local dimming turned on?
skibum5000 is offline
Old 11-20-2012, 11:00 PM
jtown017's Avatar
Quoted: 13 Post(s)
ummm to be honest i dont really notice a difference. i do however notice a difference with banding if i do. i really like this tv due to the minimal amount of dse/banding i have been experiencing. however, both my sets have had a stuck pixel that i cannot live with it. so hopefully third time is the charm
jtown017 is offline
Old 11-21-2012, 01:05 AM
jtown017's Avatar
Quoted: 13 Post(s)
i was wondering to those who do have edge bleed? is your bleed in the lower corners as well and just in the corners?
jtown017 is offline
Old 11-21-2012, 07:49 AM
Phrawst's Avatar
Quoted: 104 Post(s)
Liked: 33
Still looking for help regarding one set of picture settings that will work for bluray, tv, gaming. Anyone... anyone? Bueler?
TV: Samsung 75HU8550 / SEK-3500U/ZA
AVR: Onkyo TX-NR636
Speakers: KEF T205
Devices: Xbox One S, Nvidia Shield TV, Wii U, Cable Box, NES Classic (coming Soon)
PC: Intel Core i5-4670K, 8GB GTX 1070, 500GB Samsung EVO SSD, 16GB DDR3
Phrawst is offline
Old 11-21-2012, 09:55 AM
rajivr's Avatar
Is the tv content hd or sd?
rajivr is offline
Old 11-21-2012, 11:15 AM
Phrawst's Avatar
Quoted: 104 Post(s)
Liked: 33
My PS3, Xbox and cable box are all connected via HDMI to a sony home theater tuner. The tuner is then connected via HDMI to the TV.
This is the setup I have no at home with my XBR4 and the settings I have on that I am happy with for blurays, tv, gaming, etc.
Now I'm hoping to find some advice on settings for my forth coming 55HX850 using the same setup as above.
AVR: Onkyo TX-NR636
Speakers: KEF T205
Phrawst is offline
Old 11-21-2012, 01:18 PM
rajivr's Avatar
This is what I would recommend.
Use game scene select for xbox and ps3 through the tuner.
Connect the cable directly to tv and use optical out to route the voice to the tuner
This will allow you to have a separate setting for your cable and that is needed so that you can turn on reality Creation etc.
rajivr is offline
videospider's Avatar
Question for experienced buyers: I'd like to buy the HX850 but I don't want to pay more than $1500. Right now it's at $1800 on Amazon but will it get lower after BF? How far into next year will they still be available at major sellers?
videospider is offline
Old 11-21-2012, 01:59 PM
chi_guy50's Avatar
Quoted: 1261 Post(s)
Liked: 747
I think it is very unlikely that the Sony UPP will support a price of less than or even close to $1500 (from an authorized reseller) unless Sony decides to allow a fire sale of their entire line-up. And buying from an unauthorized reseller is an extremely risky proposition.
However, you can actually get the 55HX850 today at Amazon for $1460.35 shipped if you're willing to accept one of the "used" sets offered through Amazon Warehouse Deals. These sets are often practically new and you can always return yours within 30 days if there is some unacceptable defect. There's a good chance that the Sony 1-year limited warranty would not apply, but you can always purchase a third-party warranty, such as the one offered by Square Trade on Amazon for about $45. If anyone here has purchased their set through Amazon Warehouse Deals perhaps they can provide some feedback on their experience.
How long this particular set will be available is unknowable; it depends on how long Sony decides to keep production going and how well they sell. But once next year's line-up hits the market you can expect the superseded 2012 sets to become ever harder to find.
videospider likes this.
Sony XBR-55HX929 LCD HDTV w/FALD; DarbeeVision DVP 5000S; Oppo UDP-203; Sony BDP-S5200 (multi-region)
Denon AVR-X5200W (Video: Dolby Atmos/DSU 7.1.4; Music: DTS Neo:X 11.1); Dayton Audio MA1260 12-Channel Amplifier (60wpc)
Polk Audio RTiA7 (F/LR), CSiA6 (C), RTiA5 (FW), OWM5 (Sr, SB), 80F/X-RT (FH, TR); SVS SB-2000 (SW); Polk Audio OWM5/BIC America MSR-PRO6 (Zones 2 & 3)
chi_guy50 is online now
Old 11-21-2012, 06:13 PM
PeterPL's Avatar
Does these support 4:4:4?
Does the edge backlighting make it look bad in a dim room on a dark scene with lots of black (the dreaded light bleed on the edges that most edge lit sets apparently have) when you turn off the autobacklight dim stuff (can you even 100% defeat the auto dim backlight on low signal?)?
Can you absolutely 100% turn off all hints of motion smoothing AMP type effects and all forms of DNR 100%?
Does it treat 24p well?
Yes it support 4:4:4 in Game, Graphics Scene mode.
Yes you can disable all feauters like Dynamic control LED responsible for local dimming, and you can also turn off all picture improvers. Black level in a dim room with DCL on on is really impresive for Edge LED, almost as good as in HX920, but with a lot of less blooming/halo effect.
MotionFlow work great reducing judder on 24p movies, and keep natural move on movie with no "theatre" effect. I recomended MF on Standard with Movie mode on Auto.1
PeterPL is offline
Old 11-21-2012, 06:48 PM
Thanks for the response. Yea, I figured about the price. Even last year's HX820 and NX720 are still around the same price as their 2012 replacements.
Old 11-22-2012, 08:46 AM
Phrawst's Avatar
Quoted: 104 Post(s)
Liked: 33
That sounds doable. I've never used an optical audio cable before. I'm a bit of a noob at all this.
AVR: Onkyo TX-NR636
Speakers: KEF T205
Phrawst is offline
Old 11-22-2012, 04:41 PM
Kuro9G's Avatar
Just helped my brother buy one of these last night. I was impressed with the contrast and color reproduction on this unit compared to my Kuro6020.
I was thinking of buying him some accessories as a Christmas gift. Can anyone recommend which slim line wall mount and 3D glasses to pick up? Monoprice or other ID or BM that us Canadian's would have access to purchase.
Thanks in advance.
Kuro9G is offline
Old 11-22-2012, 10:08 PM
Needanewbewbtube's Avatar
So barring any cyber Monday deals, do you guys think the 850 will stay at $1800? Also does the 850 justify the $450.00 price difference between the 750? I'm going to be mainly using this set for console/pc gaming/streaming tv and movies from my pc with that in mind would I be better off with a 750?
Needanewbewbtube is offline
Old 11-23-2012, 05:53 AM
chi_guy50's Avatar
Liked: 747
The HX750 represents excellent bang for the buck IMO and if you are not a demanding videophile it should satisfy most of your needs, but the HX850 is definitely a step up. Which set is best for you depends on a number of subjective factors. Off the top of my head, the biggest advantages of the HX850 are:
1) X-Reality Pro video processor (vs. X-Reality in the HX750). This is the most important factor for me as it should result in an improved overall PQ.
2) "Dynamic Edge LED backlighting with local dimming" (vs. Dynamic Edge with "frame dimming").
3) Motionflow XR 960 (vs. XR 480)
4) OptiContrast Panel
5) Gorilla Glass and "monolithic styling"
Whether the Sony UPP will allow any further reductions in the sale price is anyone's guess. But I doubt it will be lowered more than $100 to $150 at any point unless unusual factors come into play.
Old 11-23-2012, 06:29 AM
HaRd2BeAr's Avatar
Liked: 36
Thank you for this chi_guy, any chance you can re post this in the HX750 thread as some users are disagreeing with me about the 850 having superior backlight dimming to the 750, i knew i wasn't going mad lol
HaRd2BeAr is offline
Old 11-23-2012, 06:59 AM
chi_guy50's Avatar
Liked: 747
I'm just going by my understanding of Sony's marketing specs, which some people may not trust entirely.
I have watched both sets (although not side by side) and, while I most definitely feel the HX850 is a superior TV, I still think the HX750 is a good alternative for most folks.
Old 11-23-2012, 07:17 PM
jtown017's Avatar
Quoted: 13 Post(s)
i am curious as to why Best Buy does not carry this tv anymore......
jtown017 is offline
Old 11-23-2012, 08:10 PM
chi_guy50's Avatar
Liked: 747
They sell them in their Magnolia showrooms. Not every B&M Best Buy has a Magnolia section.
Old 11-24-2012, 12:27 AM
Thanks Chi_guy it sounds like the price difference is worth it. I'm still keeping my eyes open for a cyber Monday deal though!
Old 11-24-2012, 01:43 AM
jtown017's Avatar
Quoted: 13 Post(s)
hmm the website wont let me order it as well :/
jtown017 is offline
Old 11-24-2012, 12:01 PM
spaaceship1's Avatar
Anyone here own both the 55HX850 and the 55HX820 (either currently or at some time or another)? If so, how do the two compare in picture quality? I really like the styling of the HX820 a lot and would like to get one if it isn't sacrificing too much in picture quality.
spaaceship1 is offline
Old 11-24-2012, 01:00 PM
winston9332's Avatar
Liked: 31
Yes, picture quality is more or less the same. 850 has less light dimming fluctuations, but only visible in areas of hard contrast (ie movie credits w small vignettes in frame). 850 is improvement, but still not "plasma good"
winston9332 is offline
Old 11-24-2012, 01:16 PM
DoctorM's Avatar
Quoted: 652 Post(s)
Liked: 198
@Needanewbewbtube - The cheapest I've seen the 55" was $1699. I think it was for Columbus day.
Your best bet is to watch Google Shopping, especially their listings for sites like East Coast TV and PowersellerNYC.
Their pricing suggests they are probably not official Sony dealers (and I wouldn't buy from them), Best Buy is allowed to price match them.
When they hit that low it was $300-400 less than BB. It's worth looking out for, especially this Monday.
DoctorM is offline
Old 11-24-2012, 04:33 PM
m2845's Avatar
I am also looking at buying a Sony 55HX850 now but wondering if they will drop there price or at least offer a free soundbar with a purchase. I noticed the Samsung UN55ES7100 was at the same price point as the Sony HX850 but they lowered their price to about 1,600.00.
Hoping they will lowere this tv again for cyber monday or at least throw in something extra.
m2845 is offline
Old 11-24-2012, 08:05 PM
jtown017's Avatar
Quoted: 13 Post(s)
i managed to grab one on amazon with free soundbar/subwoofer about a month ago
jtown017 is offline
Old 11-24-2012, 09:58 PM
hellotv's Avatar
i need help but dont know if you guys have seen 929 3d. i had a 929 for a month but returned because i thought 850 was a better value. i dont see much of a diff in p/q other than deeper blacks to justify the price diff. HOWEVER i love 3d and i'm not getting the depth or pop that the 929 had while watching 3d. i heard that the 850 has better 3d which maybe true if were talking about the crosstalk but i just dont see much depth or pop like the 929 had. should i do something with the settings or does the full array backlight of the 929 give it more depth and pop? does anyone know the diff in the 3d 850vs929..i want to love this tv and keep it but i watch too much 3d to not have a great picture. any info or something i need to do settings wise to get the depth that the 929 had..thanks guys
hellotv is offline
Old 11-25-2012, 01:29 AM
m2845's Avatar
Try these settings from Hometheater.com
http://www.hometheater.com/content/sony-kdl-55hx850-3d-lcd-hdtv-settings
m2845 is offline
Old 11-25-2012, 01:33 AM
m2845's Avatar
Thanks JTOWN017, This is the exact type of deal I am looking for. I hope they run this again soon.
m2845 is offline
Old 11-25-2012, 10:47 AM
GTZ
GTZ's Avatar
Quoted: 14 Post(s)
The HHGregg website still lists the 55HX850 but shows the 46HX850 as 'Discontinued'.
GTZ is offline
Led Hdtv , Displays , Sony , 3d Hdtv , Sony Bravia 55 Inch Led Tv 3d Support Bravia Hx850 Kdl 55hx850 , Sony 40 Inch 3d Hdtv Kdl46hx850 , Sony Bravia Kdl55hx850 55 Inch Led Hdtv
