Official Sony HX850 Owner's Thread (46HX850, 55HX850) - Page 76 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #2251 of 2261 Old 09-29-2016, 04:14 AM
Liked: 0
I have a 40HX850 and was would like to calibrate it. Does anyone know if this TV has a Blue Only mode? I've tried looking for it but, surprisingly (shockingly!), there is no definitive information about whether Sony Bravia TVs have a Blue Only mode.
insertsomethingfunny is offline
post #2252 of 2261 Old 09-29-2016, 04:16 AM
mabrandt's Avatar
No, it does not. It doesn't have color or 10 point greyscale either. You do get a great picture with what is there tho.
mabrandt is offline
post #2253 of 2261 Old 09-29-2016, 04:20 AM
Liked: 0
Bummer! Are there any particular blue filters you recommend?
post #2254 of 2261 Old 09-29-2016, 04:25 AM
mabrandt's Avatar
I used the one that came with the Avia disk, but I found that I got better results making sure that measuring the red and adjusting that using the color control was best. I left hue alone at 0.
mabrandt is offline
post #2255 of 2261 Old 09-29-2016, 04:34 AM
Liked: 0
I'm new to all of this and from the cursory reading that I have done (Rtings and elsewhere) it looks like it would be possible to get ~90% picture quality with basic calibration settings and without having to use very expensive equipment. I'd be fine with that. I haven't been able to get a blue filter and so the color and so haven't been able to adjust the color or tint settings. At times I find the skin tones too red but am not touching the Advanced White Balance settings as I'd be eye-balling it and don't have the equipment or experience for it.
Could you please share your settings if it is not a hassle?
post #2256 of 2261 Old 09-29-2016, 04:38 AM
mabrandt's Avatar
Sorry, I just replaced it a month ago with a Samsung 4K. I gave it to my son and don't have access to it. Was always very pleased with Sony. I wanted one of their 4K but they were too big for my Entertainment center. Samsung had one that just fit. It also has all the controls. Just leave tint at 0 and adjust skin tone using color. If I remeber, it was 49 or 50.
mabrandt is offline
post #2257 of 2261 Old 09-29-2016, 04:41 AM
Liked: 0
Sure. Thanks for your help :-)
post #2258 of 2261 Old 09-29-2016, 04:46 AM
mabrandt's Avatar
I know I used the warm2 and movie settings. The other temps were not even close to what you want.Very little adjusting was needed after that.
mabrandt is offline
post #2259 of 2261 Old 10-03-2016, 12:32 PM
eaamon's Avatar
Quoted: 74 Post(s)
Liked: 27
I am not sure about your specific model. but most HX8** models just do a reset and maybe even a -1 on the blue other wise the
picture has perfect color balance after reset. you might not need to go -1 on some.
this was per home theater web site.
eaamon is offline
post #2260 of 2261 Old 08-19-2017, 11:39 AM
AndrewFG's Avatar
Quoted: 28 Post(s)
I have a Swiss model HX850 which I use here in Switzerland with its built in DVB-T cable tuner and a CI card from my cable company. I shall shortly be relocating to U.K. and my question is if this model will work also in U.K.
AndrewFG is offline
post #2261 of 2261 Old 09-07-2017, 03:50 AM
patoberli's Avatar
Quoted: 21 Post(s)
The DVB-C (C for Cable, T for Terrestrical radio) should work there, if you get an -C signal at all. I guess though, that you will receive a receiver box, which offers an HDMI output.
patoberli is offline
Reply LCD Flat Panel Displays
Led Hdtv , Displays , Sony , 3d Hdtv , Sony Bravia 55 Inch Led Tv 3d Support Bravia Hx850 Kdl 55hx850 , Sony 40 Inch 3d Hdtv Kdl46hx850 , Sony Bravia Kdl55hx850 55 Inch Led Hdtv
