Official Sharp LC-90LE745U Discussion Thread [No Price Talk] d - Page 46 - AVS Forum | Home Theater Discussions And Reviews
post #1351 of 1360 Old 10-15-2013, 04:35 AM
RockmanX's Avatar
Liked: 37
You get warranty from sharp
RockmanX is offline
post #1352 of 1360 Old 10-15-2013, 01:57 PM
lodit's Avatar
Originally Posted by nowknown View Post
Side banding? Do you mean the vertical dark area on green pic?
Yes.
The darker vertical bands that appear on both sides of the screen near the edges, about an inch or so in from each side.
Did they admit that was a defect of the screen and that a replacement panel would alleviate the issue?
Or is that something that just there on all of the 90"s?
lodit is offline
post #1353 of 1360 Old 10-15-2013, 03:49 PM
nowknown's Avatar
Quoted: 192 Post(s)
Liked: 155
Originally Posted by lodit View Post
Yes.
I was confused by the term banding. I thought banding referred to visible gradient lines in TV screen colors from darker to lighter or vice versa. They acknowledged a return only for the orange on white pics - not the dark on green.
Learn all about me in my profile and take it all very seriously.
nowknown is offline
post #1354 of 1360 Old 10-15-2013, 05:37 PM
nowknown's Avatar
Quoted: 192 Post(s)
Liked: 155
I just got the word from Sharp...I'm getting a '745 refurb...be here in a couple weeks.
nowknown is offline
post #1355 of 1360 Old 10-17-2013, 01:35 PM
lodit's Avatar
Congratulations on getting the issue resolved.
So I guess they haven't or they've chosen not to respond to you regarding the darker "bands" down the sides of your tv as being a defect?
lodit is offline
post #1356 of 1360 Old 10-18-2013, 07:28 PM
nowknown's Avatar
Quoted: 192 Post(s)
Liked: 155
I sent Sharp BOTH series of pics - green and white. They said it was within their 'whatever' and they would not fix it. So, I asked about the orange on white pics and they said that there was nothing in their notes about orange on white lines. So, then I sent them only the shots with the orange. That's when I got the approval. I hope this is clear.
nowknown is offline
post #1357 of 1360 Old 10-20-2013, 07:06 PM
lodit's Avatar
Crystal.
lodit is offline
post #1358 of 1360 Old 11-11-2015, 06:50 PM
Davecraze's Avatar
Quoted: 184 Post(s)
Liked: 60
Responding to an old thread, but I will be buying either the 90le745u or the 90le657u for my living room in the next 60-90 days. Seating is 16-17 feet from the screen so 4k really isn't important. I realize that the 745u is the older model, but does have the same built in audio as the 657u? I have read conflicting information on various sites that maybe the 657u doesn't have the same separate stereo speakers and built in sub that the 745u has. I will not be running separate audio with this unit and, all things being [almost] equal, I'd rather have the 745u if the built in audio is better. Yes, blasphemy, I know. Any clarity would be appreciated. Thanks
Davecraze is offline
post #1359 of 1360 Old 11-30-2015, 02:51 PM
stevecarpenter's Avatar
Davecraze, I bought a 90le657 on Thanksgiving 2013 and it broke Thanksgiving 2015. I watch it maybe 5 hours per week so it has about 500-600 hours on it. Repair thought it was the motherboard but put in a new one and discovered that it is a problem with the edge lighting. Can't fix it because the lighting is part of the screen. Called Sharp and they no long make the lighting/screen in the US and wont ship one from overseas. Just bought myself a $7000 anchor.
The repairman said sharp has so many problems with the motherboards. Even BestBuy here in Houston carries only to Sharp models.
I researched this tv for 6 months and was hesitant because I wanted a 90". To be fair I'm still waiting to hear back from Sharp but I'm sure I'm screwed.
Will update when I hear from Sharp.
stevecarpenter is offline
post #1360 of 1360 Old 12-23-2015, 08:18 PM
rapidrezults's Avatar
What exactly was your problem? I am noticing the vertical line on the right side. It has gotten much darker over the years. Not sure what I can do. I do notice a bright orange hue on white backgrounds.
rapidrezults is offline
Reply LCD Flat Panel Displays
Sharp , Displays , Sharp Aquos Lc52le640u Led Hdtv , Led Hdtv , Sharp 90 Inch 3d Led Hdtv Lc 90le745u
