LM7600 vs. LM8600 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 39 Old 07-03-2012, 09:02 AM
kwarner's Avatar
Originally Posted by karlozb View Post
This makes group of LEDs to turn on/off independently but it causes to display a band of light (halo effect) on the screen that really shows up on dark scenes.
I think you've described pretty much how local dimming works with any edge lit LED display. You could look for a TV with a full array LED back light. Then you would have blotches of light spots following around the bright images on the screen. Being smaller, they may be less bothersome. And of course you could look at a plasma display that doesn't try to play tricks on your eye.
kwarner is offline
post #32 of 39 Old 07-03-2012, 11:53 AM
ben12345's Avatar
Quoted: 93 Post(s)
Liked: 27
I wish I have found this thread earlier. I had the LG47LM8600 for three weeks (bought it from Amazon) and I loved it. Picture quality is great BUT with some big flaws:
Despite loving this TV I could not live with the band of light so I had to return it. I have found some people saying they found the LM7600 not having these issues, so I might get one or the Samsung UN55ES6500. Any thoughts?
I had the 8600 (from Amazon) and sent it back and got the Samsung 7100. The PQ on the Samsung is much better as is the brightness. Whites were just too dull on the 8600. I will say the 3D was much better on the 8600.
ben12345 is offline
post #33 of 39 Old 07-04-2012, 10:30 AM
karlozb's Avatar
I am already looking at Samsung. Any advice 7100 vs 6500?
How do you like the 7100?
I have read post saying these latest samsungs get a lot of light bleeding/clouding/flashlight, or banding. Is there any?
Can it play mkv, avi, mp4 through directly from PC through media share (wireless)?
karlozb is offline
post #34 of 39 Old 09-01-2012, 08:31 AM
Chica17's Avatar
Hi Guys!!!!!!!!!!!!! Need your suggestions...
I was almost finalized to Purchase LG L8600. However now I am thinking to go for LM9600. Which one is the best choice. I know the price is major difference, which i do not care much.
I am lil confused when I read CNET review for LM9600. IS that some thing which can be ignored??? Pls give your suggestions.....
Answer!!
I have owned this TV for 2 months now and have not had any problems with it. Most of the reviews you read online were done before the TV was officially released or right at the time it was released. A new update came out last month and since then the picture quality has been even better than when I first got it. I am not sure if it is because of the firmware update or the fact my TV went through a break-in period, but I see much less clouding than I did when I first got it. I have been watching a few Blu-ray movies and have not noticed any abnormalities that others have seen in the past. Last night I watched The Grey in 24p, which has many dark and white scenes, and I did not notice any blurring at all. Maybe a few of the problems folks have had in the past were fixed. If you calibrate the TV properly it will look great.
My suggestion is you get the LM9600 rather than the LM8600. The LM9600 is the only one that is full NANO backlit and with the price as low as it is now I believe it is definitely worth getting over the LM8600. Plus if you use the smart TV functions and internet, the LM9600 has a slightly better processor which will help in those areas.
Chica17 is offline
post #35 of 39 Old 10-04-2012, 12:18 AM
matthew88's Avatar
You can test for banding and DSE in that video, I can clearly see dse on my 760s with that video.
Watch the sky, you should se like dirty stripes that dont move, if you have dse
Banding dirty screen effect (DSE) test - YouTube
matthew88 is offline
post #36 of 39 Old 10-04-2012, 09:13 AM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
on my 55LM7600, i have a banding on the right side of the screen. i notice is with the fast panning screen movement while watching, golf,football,baseball,soccer and also on the sky. and i scheduled to return my set and get the replacement tom. i hope the banding will be gone.
caloyzki is offline
post #37 of 39 Old 11-27-2012, 07:25 PM
merlo's Avatar
Originally Posted by j_m View Post
Here you go. I can post links now.
LM7600:
http://www.electronics-expo.com/medi...1021640430.pdf
LM8600:
http://www.edinw.com/Spec_Sheets/LG_LM8600_SPEC.PDF
Anyone knows what "2d TV-ready" means/ is?
Also MHL?
merlo is offline
post #38 of 39 Old 12-29-2012, 03:43 PM
bobpaule's Avatar
Quoted: 42 Post(s)
Liked: 55
After i was dumb enough to impulse buy an LG 47G2 (Google) i read about the atrocious black levels and jaggies around whites and promptly returned it for an LM7600. Even Amazon users quickly weeded out the poor product.
We have had the 47LM7600 for two weeks now and nothing but praise except the occasional ARC hiccup the Marantz 1403. 3D is very nice and bright, i have active LED glasses with my HC9000D in the basement so I am not new to it.
bobpaule is offline
post #39 of 39 Old 01-13-2013, 08:55 AM
tgm1024's Avatar
Location: Sorry, chances are excellent that you're an idiot.
Quoted: 2484 Post(s)
Liked: 2264
Originally Posted by 4x4Cableman View Post
Absolutely , I am watching the lg now and its great but the detail in the Sammy was awesome.
Sometimes in the imaging world, I've seen people attempt to compare cameras and favor the image set with the software sharpness tweaked upwards ever so slightly. It's a very hard to thing to control. Not so far as to approach graininess, but enough to make it feel as though it's standing out.
Similar I suppose to the old stereo salesman trick of selling the expensive receiver by turning the volume up ever so slightly.
You're the wife. You're the dead wife. Give me my @#$%ing coin, dead wife.
-Mad Sweeney
tgm1024 is offline
Reply LCD Flat Panel Displays
Lg Cinema Screen 55lm7600 55 Inch Cinema 3d 1080p 240 Hz Led Lcd Hdtv , Lg Cinema Screen 47lm7600 47 Inch Cinema 3d Led Lcd Hdtv , Lg 47lm8600 Led Lcd Hdtv , Lg Cinema Screen 55lm8600 55 Inch Cinema 3d Led Lcd Hdtv
