AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   LCD Flat Panel Displays (http://www.avsforum.com/forum/166-lcd-flat-panel-displays/)
-   -   LM7600 vs. LM8600 (http://www.avsforum.com/forum/166-lcd-flat-panel-displays/1407843-lm7600-vs-lm8600.html)
kfsaer 04-27-2012 07:33 PM
Looking at these new LG tVs. Both seem to be highly regarded but the 8600 has a dual core processor. Not much information on the 8600.
Does anyone have any opinion on the choice between these sets. My TV just died and I need my first hidef flat screen TV.
eclipsegt 04-27-2012 08:11 PM
I saw the LM7600 at bestbuy and it looked great.
The LM8600 has:
1. Dual core for smoother smart TV.
2. Voice control via a mic on the magic remote.
3. (probably) better PQ due to software (from dual core).
4. Different frame.
IMO the 8600 is not really worth the extra money unless you plan to use the smart TV features a lot. However, no one will really know how good the LM8600 is until some reviews start showing up.
If you want the best PQ, I'd suggest looking at the top of the line LG LM9600, which has backlit LED (the lower models are edge lit) and TRUE local dimming.
4x4Cableman 04-28-2012 01:58 PM
I returned my Samsung 55es7500 today for the lm 8600. I hate to say it but the pq is far less superior. I do liked the 3d better as it seems to be more comfortable. So far no flashlighting, the Sammy was bad and only had it for 7 days.The display is more reflective which means i have to buy some curtains now. If you have any questions please ask.
DWC
kfsaer 04-29-2012 04:41 AM
4x4, are you saying that the picture quality of the Samsung was superior? In what respect?
4x4Cableman 04-29-2012 05:30 PM
Absolutely , I am watching the lg now and its great but the detail in the Sammy was awesome. I'm coming from a Panasonic viera , but so far I don't see any flash lighting on this set. I probably just need to calibrate it but the Sammy was awesome right out of the box. Also there was an issue in the Sammy with motion plus , seemed no matter what it was set on it overcompensated? And lastly the Lg has a pretty reflective surface which is hard to get use to. All in all its seems to be just pq on the es is much better
Iccy 04-29-2012 05:59 PM
So your comparing a calibrated tv to a non calibrated and then saying the picture quality isnt as good? Seems a little fishy
4x4Cableman 04-29-2012 06:16 PM
The Sammy nor the log was calibrated...
4x4Cableman 04-29-2012 06:17 PM
*Lg
Iccy 04-29-2012 07:18 PM
Ah well then, but I have a c8000 and Id have to say the tv was inaccurate compared to what you get after its calibrated. Id assume the es7500 would have the same issue but I havent read a review on it so I couldnt give a definite answer. But if you were to ask me the LG7600 (Im not sure about the 8600) has a teeeeeerible in box setting, but once calibrated correctly it does very well compared to the samsung d8000 in everything but min black levels.
For reference:
D8000 not calibrated
http://www.flatpanelshd.com/pictures...00-foer-1l.jpg
D8000 calibrated
http://www.flatpanelshd.com/pictures...0-efter-2l.jpg
LM7600 not calibrated
LM7600 calibrated
4x4Cableman 04-29-2012 07:20 PM
I'm glad to here that I really like this set ....design,3d , ....should I just buy a wow disc ? What would you recommend for calibration.
Iccy 04-29-2012 07:30 PM
Well as you know, every tv is going to be slightly different so a + or - in a setting may be needed but based on the links I posted used:
Picture preset: Expert1
Backlight 47
Contrast 85
Brightness: 50
V/H Sharpness: 50
Tint 0
Dynamic Contrast Off
Super Resolution Off
Colour Gamut Standard
Edge enhancer Off
Color Filter Off
Noise reduction Off
Mpeg noise reduction Off
Black level Low
LED local dimming Off
TruMotion Off
Color temperature Warm
Gamma 2.2
RGB Method 2 point
R high -6
G high -11
B high 18
R low -1
G low -2
B low 4
A disc is always useful but you can find slides to do your own testing for free everywhere and use a usb instead of a disc (honestly who uses cds anymore? )
Edit: Back to OP, I too would like to know the difference between the 8600 and 7600
4x4Cableman 04-29-2012 07:46 PM
lol thanks I'll give it a shot
ben12345 04-30-2012 02:07 PM
DWC
I am trying to decide between these two sets. My concern with the Sammy was active 3D vs passive 3D on the LG. Everything I read seems to say the LG is much better for 3D with the passive glasses but they say the PQ seems to be a little better on the Samsung. So if you could do it all over again which one you pick now that you have spent some time with both.
4x4Cableman 05-01-2012 07:31 AM
The 3d is more comfortable but I am returning the Lg for the es8000 the shiny screen is just to much for my viewing. But yeah I would have to say the Samsung has better pq.I'm sure others will say different but in my opinion Samsung has better clarity.
4x4Cableman 05-01-2012 07:33 AM
If you plan on watching 3d more than 50 percent of the viewing time then the log is the way to go. My preference is pq For normal viewing , 3d ....I also looked at the Sony xbr 929 but read they are having lots of failures with that model.
ben12345 05-01-2012 10:33 AM
I think you make a very good point. If PQ is the best on the Samsung and you want non 3D most of the time you would go with the Samsung. I think this is the case with a lot of us in that we would not watch 3D the majority of the time. Maybe for some sports, the Olympics and an occasion movie for which the LG would be the best.
Now the new flagship LG LM9600 is not out yet and it has full- array dimming and this could improve the PQ to equal the Samsung in which case it would be the clear choice as it would have both PQ and best 3D but that remains to be seen.
mishari84 05-01-2012 10:49 AM
i think HX929 will still a winner because of Gorilla glass, glossy but not reflective. and i think once you watch any full HD movie on HX929 you will hate edge lit TVs
4x4Cableman 05-01-2012 02:46 PM
The Sony was too high priced for me and just couldn't over look the pq of the Samsung .I went with the es 8000 and ordered the wow disc ....wish me luck.
jeffro23 05-22-2012 08:52 AM
Originally Posted by eclipsegt View Post
The LM8600 has:
4. Different frame.
I just returned the 7600 for the 8600 and was pleasantly surprised by the sharper PQ. I was wondering, as you mentioned, If the dual core plays any role in the perceived better PQ/dimming on this set.
The Netflix & YouTube apps are much quicker and streaming from my PC is infinitely faster. Since the 2 are so close in price, Id definitely recommend the 8600
ben12345 05-22-2012 12:49 PM
My feeling is that a faster processor does not affect the PQ. It only affects the speed of applications and steaming/internet would be improved. Just like in a computer, a faster CPU does not always make for a sharper monitor but I could be wrong.
gszczesz 05-23-2012 11:52 AM
IMO, you do not buy the better quality 2D picture T.V. if you watch >50% non 3D content... I can't sit through a whole 3D movie with active glasses because it gives me and my son a headache: too much eye strain. As far as I'm concerned, active 3D is not an option so the question isn't what percentage of time you are going to watch 3D T.V., but rather how much is the option to watch 3D important to you?
That being said, watching the superbowl with my kids in 3D is worth a lot to me, so I'd choose the LG over the Sammy any day.
brahby 05-24-2012 04:13 AM
I have found a few sites stating the 7600 is a 120hz panel and the 8600 is a 240hz panel. I know they both have trumotion 240. But these websites suggest that the panels themselves are different similar to what Sony did with the ex720 and hx820. Can anyone confirm or deny this?
ben12345 05-24-2012 01:01 PM
On LG website they indicate that both models are 240hz panels.
j_m 05-24-2012 03:14 PM
Looks like the LM8600 series has the Plus video resolution upscaler and the LM7600 has the Basic one. Also it looks like there are a few differences in connectivity features too.
Sorry, can't post direct links yet.
LM8600:
edinw DOT com/Spec_Sheets/LG_LM8600_SPEC.PDF
LM7600:
electronics-expo DOT com/media/pdf/Manufacturer-Brochure-1021640430.pdf
ben12345 05-24-2012 06:21 PM
LM8600:
LM7600:
Could not access either one of these. Are these suppose to be web addresses?
j_m 05-25-2012 09:56 AM
Here you go. I can post links now.
LM7600:
http://www.electronics-expo.com/medi...1021640430.pdf
LM8600:
http://www.edinw.com/Spec_Sheets/LG_LM8600_SPEC.PDF
ben12345 05-25-2012 10:08 AM
Here you go. I'm can post links now.
LM7600:
LM8600:
This worked fine. Thanks. Very helpful.
AV-Freak 05-25-2012 10:32 AM
I have seen both devices side by side. After calibration there was absolutely no visual difference.
Also there was no difference in menu speeds or with the apps. We didn't test streaming.
ben12345 05-25-2012 11:11 AM
Well the 8600 is only a couple of dollars more on Amazon so I would assume it price is basically the same one would purchase the 8600.
karlozb 07-03-2012 07:51 AM
I wish I have found this thread earlier. I had the LG47LM8600 for three weeks (bought it from Amazon) and I loved it. Picture quality is great BUT with some big flaws:
CONS:
1) TV relies on edge lit LED technology to light up the LCD panel and uses local dimming to achieve better blacks. This makes group of LEDs to turn on/off independently but it causes to display a band of light (halo effect) on the screen that really shows up on dark scenes. It can be seen when switching between TV inputs, the screen goes black and only the LG logo and the pink cursor from the magic remote shows up and BANG!! here you can see how a band of light follows the cursor wherever it moves. So I said no big deal, but then one night with all lights off and watching a movie (Safe House) suddenly the screen goes black and only the face of the actor shows and BANG!! the band of light is now really really apparent.
TV during the day when room is brighter you might not even notice it but at night when lights are off, you can really notice is and it is not appealing.
2)TrueMotion: I really did not like this feature at all, it comes with multiple set ups (Clear, ClearPlus, Low, Medium, etc). But you always get the "soup opera" effect. I think despite being 240Hz it does not handle very well fast action scenes. I ended up having this option off, even when watching sports.
PROS:
-3D is by far the best I have seen. And I prefer the passive technology, LG uses, than the 3D active technology.
-Media connect is great you can easily connect to other devices such PC and stream movies (MP4, MKV, AVI, etc) directly from there. I also liked it recognized AC3 or ACC encoding to take advantage of 5.1Dolby.
-Good looking, prefer it looks over a samsung.
-Having a dual core processor and a fast ISP made streaming enjoyable. LG app market has Redbull TV and I watched it all the time like if it was pure HD
CONCLUSION:
Despite loving this TV I could not live with the band of light so I had to return it. I have found some people saying they found the LM7600 not having these issues, so I might get one or the Samsung UN55ES6500. Any thoughts?
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
