HDCP and my TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-28-2012, 12:34 PM - Thread Starter
Spector1973's Avatar
I have an older (2009) Toshiba 40RV525U tv. Using my providers OD services has become impossible as I get a message that my tv does not support HDCP. It is connected using HDMI cables and there are no other tv's connected to the system. Do I need to go and buy another newer tv or is there a way to get around this? I know what HDCP (the devil) is...and it is really infuriating that it has been implemented. I am paying good money to enjoy all my HD programming and now with the disappearance of the dvd rental places...how am I to watch a movie?
Spector1973 is offline
post #2 of 6 Old 04-29-2012, 08:19 AM
mes444's Avatar
Try switching your HDMI cable for red/green/blue video + red/white audio component cables. No HDCP involved with component and tv broadcast maxes out at 1080i, which component can carry.
mes444 is offline
post #3 of 6 Old 04-29-2012, 01:17 PM
Steve S's Avatar
Liked: 46
HDCP is part of the HDMI spec. If the box is connected straight to the tv and only to the one tv it should work. Maybe check to see if there's a firmware update available from Toshiba for your set.
Steve S.
Steve S is offline
post #4 of 6 Old 04-29-2012, 02:06 PM
Ratman's Avatar
Quoted: 1290 Post(s)
Liked: 1030
Maybe it's not the TV, but a compatibility issue with the cable box (assuming OD services is On Demand) or the providers feed itself.
Again, assuming the "problem" only occurs with On Demand, but all other 720p/1080i HD broadcasts work fine, it's probably not a TV issue.
What's the make/model of the cable box?
Who's the provider?
Have you contacted the provider for assistance?
Ratman is offline
post #5 of 6 Old 04-29-2012, 05:49 PM
walford's Avatar
Are any other devices (disks, ext memory) connected to the STB on which a program could be copied to?
walford is offline
post #6 of 6 Old 04-29-2012, 07:41 PM
topr's Avatar
I think Steve is correct and remember reading something about HDCP with that display so I did a forum search and there were a few other folks that had your issue. From what I read if you have FW version 1.03 you need 1.05
topr is offline
Reply LCD Flat Panel Displays
